Hi, I’m using TX2 NX & JP 4.6.3.
I’m having an issue with video when looking at very high dynamic range area (very bright part in corner, and the rest is dark). I saw some “wavy effect” or “color banding effect”. Try to narrow down where it comes from and see that it starts happening since a Nv Buffer is created from IImageNativeBuffer interface.
EGLStream::NV::IImageNativeBuffer *iNativeBuffer =
Argus::interface_cast<EGLStream::NV::IImageNativeBuffer>(image);
int new_fd = iNativeBuffer->createNvBuffer(size,
NvBufferColorFormat_NV12,
NvBufferLayout_Pitch);
I modified argus_camera code to save two NV12 images from single capture in two ways (using IImageHeaderlessFile::writeHeaderlessFile and using Nv Buffer.
This is the patch file: argus_camera.patch (18.6 KB)
basically, when capturing still image with NV12 type, after NV12 file is stored as original way, I created a Nv Buffer, copy image to this buffer, then save it as NV12 file (referenced from 07_video_convert example How to save YUV420 buffer with Pitch layout into YUV file?). So these two NV12 files are coming from the same capture.
case STILL_FILE_TYPE_HEADERLESS:
// Get the HEADERLESS_FILE interface.
EGLStream::IImageHeaderlessFile *iHeaderlessFile =
Argus::interface_cast<EGLStream::IImageHeaderlessFile>(image);
if (!iHeaderlessFile)
ORIGINATE_ERROR("Failed to get IImageHeaderlessFile interface.");
EGLStream::IImage2D *i2D =
Argus::interface_cast<EGLStream::IImage2D>(image);
if (!i2D)
ORIGINATE_ERROR("Failed to get IImage2D interface.");
const Argus::Size2D<uint32_t> size = i2D->getSize();
// build the file name
std::ostringstream fileName;
fileName << dispatcher.m_outputPath.get();
if (dispatcher.m_outputPath.get() != "/dev/null")
fileName << "/image_" <<
size.width() << "x" << size.height() << "_" <<
std::setfill('0') << std::setw(4) << m_captureIndex <<
"." << dispatcher.m_captureYuvFormat.toString();
PROPAGATE_ERROR(validateOutputPath(fileName.str().c_str()));
// Write a headerless, unencoded image to disk.
if (iHeaderlessFile->writeHeaderlessFile(fileName.str().c_str()) == Argus::STATUS_OK)
PROPAGATE_ERROR(dispatcher.message("Captured a still image to '%s'\n",
else
ORIGINATE_ERROR("Failed to write headerless raw image to '%s'\n",
fileName.str().c_str());
if (!iNativeBuffer) {
PROPAGATE_ERROR(dispatcher.message("IImageNativeBuffer not supported by Image\n"));
fileName.str("");
fileName.clear();
"_nvbuf." << dispatcher.m_captureYuvFormat.toString();
int ret = save_dmabuf_nv12(new_fd, fileName.str().c_str());
printf("buffer fd %d created, saving into '%s' return %d\n", new_fd, fileName.str().c_str(), ret);
NvBufferDestroy(new_fd);
dispatcher.printAllSettings(stillRequest.get(), stillStream.get());
break;
But the output I have is having color difference.
The file named image_1932x1090_0000.nv12 is saved by original way (using IImageHeaderlessFile::writeHeaderlessFile), and the another file image_1932x1090_0000_nvbuf.nv12 is saved from dma buffer as you can see in the code above.
image_1932x1090_0000.nv12 (3.0 MB)
image_1932x1090_0000_nvbuf.nv12 (3.0 MB)
Open these .nv12 files by vooya (Download vooya), I can see the file stored by IImageHeaderlessFile (the later one in these two images) is more smooth and brighter, the other image having some wavy effect on it.
It looks like copying the image into Nv Buffer (by call above) reducing the image quality & light.
Is there any explaination why this happened? And how to avoid the quality lost when copy native buffer into NvBuffer?
Thank you so much.
