Thanks @yuweiw.
simple demo would be nice, but here’s code based on a modified version of deepstream-image-meta-test which also uses ds_image_meta_pgie_config.txt from that example:
#include <stdio.h>
#include <gst/gst.h>
#include <glib.h>
#include <stdlib.h>
#include <string.h>
#include <gmodule.h>
#include <math.h>
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#include "gst-nvmessage.h"
#include "nvdsmeta.h"
#include "nvbufsurface.h"
#include "nvbufsurftransform.h"
#include "nvds_obj_encode.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
#define SGIE_CLASS_ID_LPD 0
#define PRIMARY_DETECTOR_UID 1
#define SECONDARY_DETECTOR_UID 2
#define SECONDARY_CLASSIFIER_UID 3
/** set the user metadata type */
#define NVDS_USER_FRAME_META_EXAMPLE (nvds_get_user_meta_type("NVIDIA.NVINFER.USER_META"))
#define USER_ARRAY_SIZE 16
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
"Roadsign"
#define MAX_META_BUFFS 128
typedef enum {
OBJECT_NONE = 0,
OBJECT_VHICLE = 0x1,
OBJECT_PERSON = 0x2
} object_type;
typedef struct _deepstream_meta_object {
guint cameranumber;
guint dtop;
guint dleft;
object_type objecttype;
guint confidence;
char lc_string[MAX_LABEL_SIZE];
} deepstream_meta_object;
typedef struct _deepstream_meta_output {
char cpuid[32];
guint num_objects;
guint person_count;
guint vehicle_count;
guint plate_count;
guint extracted_plate_count;
GstClockTime frame_time;
deepstream_meta_object object[MAX_ELEMENTS_IN_DISPLAY_META];
} deepstream_meta_output;
deepstream_meta_output meta_buff[MAX_META_BUFFS];
int deep_meta_buff_head = 0;
int deep_meta_buff_tail = 0;
static NvDsObjEncCtxHandle ctx;
static gpointer
copy_user_meta(gpointer data, gpointer user_data)
NvDsUserMeta *user_meta = (NvDsUserMeta *)data;
NvDsObjEncOutParams *enc_jpeg_image = (NvDsObjEncOutParams *) user_meta->user_meta_data;
NvDsObjEncOutParams *dst_enc_jpeg_image = (NvDsObjEncOutParams *)g_malloc0(sizeof(NvDsObjEncOutParams));
if (dst_enc_jpeg_image) memcpy(dst_enc_jpeg_image, enc_jpeg_image, sizeof(NvDsObjEncOutParams));
return (gpointer)dst_enc_jpeg_image;
static void
release_user_meta(gpointer data, gpointer user_data)
if(user_meta->user_meta_data)
g_free(user_meta->user_meta_data);
user_meta->user_meta_data = NULL;
static void
cvt_nvbufsurf_rgba_to_nv12(GstBuffer *buf, NvDsFrameMeta *frame_meta, NvDsBatchMeta *batch_meta)
GstMapInfo in_map_info;
memset (&in_map_info, 0, sizeof (in_map_info));
if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
g_print ("Error: Failed to map gst buffer\n");
gst_buffer_unmap (buf, &in_map_info);
return; // GST_PAD_PROBE_OK;
cudaError_t cuda_err;
NvBufSurfTransformRect src_rect, dst_rect;
NvBufSurface *surface = NULL;
NvDsUserMeta *user_meta = nvds_acquire_user_meta_from_pool(batch_meta);
surface = (NvBufSurface *) in_map_info.data;
int batch_size= surface->batchSize;
printf("\ncvt_nvbufsurf_rgba_to_nv12() called. Batch Size : %d, resolution : %dx%d \n",batch_size,
surface->surfaceList[0].width, surface->surfaceList[0].height);
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[0].width;
src_rect.height= (guint) surface->surfaceList[0].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[0].width;
dst_rect.height= (guint) surface->surfaceList[0].height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurface *dst_surface = NULL;
NvBufSurfaceCreateParams nvbufsurface_create_params;
/* An intermediate buffer for NV12/RGBA to BGR conversion will be
* required. Can be skipped if custom algorithm can work directly on NV12/RGBA. */
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (gint) surface->surfaceList[0].width;
nvbufsurface_create_params.height = (gint) surface->surfaceList[0].height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_NV12; // NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
cuda_err = cudaSetDevice (surface->gpuId);
cudaStream_t cuda_stream;
cuda_err=cudaStreamCreate (&cuda_stream);
int create_result = NvBufSurfaceCreate(&dst_surface, batch_size, &nvbufsurface_create_params);
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
NvBufSurfaceMemSet (dst_surface, 0, 0, 0);
err = NvBufSurfTransform (surface, dst_surface, &nvbufsurface_params);
if (err != NvBufSurfTransformError_Success) {
g_print ("NvBufSurfTransform failed with error %d while converting buffer\n", err);
NvBufSurfaceMap (dst_surface, 0, 0, NVBUF_MAP_READ);
// NvBufSurfaceSyncForCpu(dst_surface, 0, 0);
NvDsObjectMeta obj_meta;
NvDsObjEncUsrArgs userData = { 0 };
userData.saveImg = FALSE;
// strcpy(userData.fileNameImg, "/tmp/junk.jpg");
userData.attachUsrMeta = TRUE;
userData.quality = 80;
userData.scaleImg = FALSE;
userData.scaledWidth = surface->surfaceList[0].width;
userData.scaledHeight = surface->surfaceList[0].height;
userData.objNum = 1; // num_rects;
memset(&obj_meta, 0, sizeof(obj_meta));
obj_meta.rect_params.width = surface->surfaceList[0].width;
obj_meta.rect_params.height = surface->surfaceList[0].height;
obj_meta.rect_params.top = 0;
obj_meta.rect_params.left = 0;
obj_meta.base_meta.meta_type = NVDS_CROP_IMAGE_META;
NvDsUserMetaList usrMetaList = { 0 };
// NvDsUserMeta usrMetaData = { 0 } ;
NvDsObjEncOutParams enc_jpeg_image;
memset(&enc_jpeg_image, 0, sizeof(enc_jpeg_image));
// usrMetaData.base_meta.meta_type = NVDS_CROP_IMAGE_META;
user_meta->base_meta.meta_type = NVDS_CROP_IMAGE_META;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc)copy_user_meta;
user_meta->base_meta.release_func = (NvDsMetaReleaseFunc)release_user_meta;
user_meta->user_meta_data = (NvDsObjEncOutParams *)&enc_jpeg_image;
obj_meta.obj_user_meta_list = &usrMetaList;
usrMetaList.data = user_meta; // &usrMetaData;
// usrMetaData.base_meta.copy_func = (NvDsMetaCopyFunc)copy_user_meta;
// usrMetaData.base_meta.release_func = (NvDsMetaReleaseFunc)release_user_meta;
// nvds_add_user_meta_to_obj(&obj_meta, &usrMetaData); // SIGSEGV probably assert from locked mutex.
// nvds_add_user_meta_to_batch(batch_meta, &usrMetaData); // SIGSEGV probably assert from locked mutex.
// nvds_add_user_meta_to_batch(batch_meta, user_meta); // SIGSEGV probably assert from locked mutex.
// nvds_add_user_meta_to_frame(frame_meta, &usrMetaData);
nvds_add_user_meta_to_frame(frame_meta, user_meta);
// nvds_add_user_meta_to_obj(&obj_meta, user_meta);
g_print("cvt_nvbufsurf_rgba_to_nv12: Converted surface to NV12 color format. Encoding JPEG image.\n");
if (ctx == NULL) ctx = nvds_obj_enc_create_context();
g_print("cvt_nvbufsurf_rgba_to_nv12: Created JPEG Context for Encoding JPEG image.\n");
nvds_obj_enc_process((NvDsObjEncCtxHandle)ctx, &userData, dst_surface, &obj_meta, frame_meta);
g_print("cvt_nvbufsurf_rgba_to_nv12: Finalizing Encoding JPEG image.\n");
nvds_obj_enc_finish((NvDsObjEncCtxHandle)ctx);
g_print("cvt_nvbufsurf_rgba_to_nv12: Encoding JPEG image completed.\n");
// // NvDsUserMetaList *usrMetaList = obj_meta->obj_user_meta_list;
// for (NvDsUserMetaList *usrMetaList_p = &usrMetaList; usrMetaList_p != NULL; usrMetaList_p = usrMetaList_p->next)
// g_print(" Got usrMetaList after JPEG encoding.\n");
// NvDsUserMeta *usrMetaData_p = (NvDsUserMeta *) usrMetaList_p->data;
// if (usrMetaData.base_meta.meta_type == NVDS_CROP_IMAGE_META)
// NvDsObjEncOutParams *enc_jpeg_image =
// (NvDsObjEncOutParams *) usrMetaData.user_meta_data;
// enc_jpeg_image->outBuffer << -- Encoded JPEG image
// enc_jpeg_image->outLen << -- Encoded JPEG image length
g_print(" usrMetaList after JPEG encoding HAS AN IMAGE!!! %d bytes.\n", enc_jpeg_image.outLen);
// break;
NvBufSurfaceUnMap(dst_surface, 0, 0);
NvBufSurfaceDestroy(dst_surface);
cudaStreamDestroy(cuda_stream);
gst_buffer_unmap(buf, &in_map_info);
/* osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsObjectMeta *obj_meta = NULL;
NvDsObjectMeta *temp_meta = NULL;
NvDsObjectMeta *obj_meta_inrecord[MAX_ELEMENTS_IN_DISPLAY_META] = { NULL };
// guint vehicle_count = 0;
// guint person_count = 0;
// guint lp_count = 0;
guint label_i = 0;
guint current_object = 0;
guint source_id = 0;
// guint temptop = 0, templeft = 0;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsMetaList * l_class = NULL;
NvDsMetaList * l_label = NULL;
NvDsDisplayMeta *display_meta = NULL;
NvDsClassifierMeta * class_meta = NULL;
NvDsLabelInfo * label_info = NULL;
GstClockTime now;
// perf_measure * perf = (perf_measure *)(u_data);
deepstream_meta_output probe_output;
bool got_jpeg = false;
struct cudaDeviceProp prop;
int current_device = -1;
cudaGetDevice(¤t_device);
cudaGetDeviceProperties(&prop, current_device);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
// guint cam_width = MUXER_OUTPUT_WIDTH/tiler_columns;
// guint cam_height = MUXER_OUTPUT_HEIGHT/tiler_rows;
now = g_get_monotonic_time(); // maybe should use gst_date_time_new_now_local_time?
//g_print ("---- Entering osd_sink_pad_buffer_probe, time = %lld\n", now);
#if 0
if (perf->pre_time == GST_CLOCK_TIME_NONE)
perf->pre_time = now;
perf->total_time = GST_CLOCK_TIME_NONE;
else
if (perf->total_time == GST_CLOCK_TIME_NONE)
perf->total_time = (now - perf->pre_time);
else
perf->total_time += (now - perf->pre_time);
perf->count++;
#endif
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
int offset = 0;
if (!frame_meta)
continue;
memset(&probe_output, 0, sizeof(probe_output));
// source_id = l_frame->source_id; // might need to use the pad_index instead.
source_id = frame_meta->source_id;
// source_id = ((NvDsFrameMetaList *)(l_frame))->source_id; // might need to use the pad_index instead.
for (l_obj = frame_meta->obj_meta_list; (l_obj != NULL); // && (probe_output.num_objects < MAX_ELEMENTS_IN_DISPLAY_META);
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (!obj_meta)
continue;
current_object = probe_output.num_objects;
/* Check that the object has been detected by the primary detector
* and that the class id is that of vehicles/persons. */
if (obj_meta->unique_component_id == PRIMARY_DETECTOR_UID)
if (current_object < MAX_ELEMENTS_IN_DISPLAY_META && (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) || (obj_meta->class_id == PGIE_CLASS_ID_PERSON))
//record the object pointer so that some child object can find its parent
obj_meta_inrecord[current_object] = obj_meta;
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE)
probe_output.vehicle_count++;
probe_output.object[current_object].objecttype = OBJECT_VHICLE;
else
probe_output.person_count++;
probe_output.object[current_object].objecttype = OBJECT_PERSON;
// get the camera number and location based on the coordinate
probe_output.object[current_object].cameranumber = source_id;
probe_output.object[current_object].dtop = obj_meta->rect_params.top;
probe_output.object[current_object].dleft = obj_meta->rect_params.left;
// memcpy(probe_output.cpuid, mycpuid, sizeof(mycpuid));
probe_output.object[current_object].confidence = obj_meta->confidence;
probe_output.num_objects++;
if (probe_output.num_objects > 0 && probe_output.num_objects < MAX_ELEMENTS_IN_DISPLAY_META)
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next)
if (!obj_meta)
continue;
// Doug - Set bounding box color
obj_meta->rect_params.border_color.blue = ((obj_meta->object_id | 1) |
(obj_meta->object_id >> 8 | 0x1) |
(obj_meta->object_id >> 16 | 0x1) |
(obj_meta->object_id >> 24 | 0x1)) << 4;
obj_meta->rect_params.border_color.green = ((obj_meta->object_id >> 1 | 1) |
(obj_meta->object_id >> 9 | 0x1) |
(obj_meta->object_id >> 17 | 0x1) |
(obj_meta->object_id >> 25 | 0x1)) << 4;
obj_meta->rect_params.border_color.red = ((obj_meta->object_id >> 2 | 1) |
(obj_meta->object_id >> 10 | 0x1) |
(obj_meta->object_id >> 18 | 0x1) |
(obj_meta->object_id >> 26 | 0x1)) << 4;
obj_meta->rect_params.border_color.alpha = 1;
if (obj_meta->unique_component_id == SECONDARY_DETECTOR_UID)
if (obj_meta->class_id == SGIE_CLASS_ID_LPD)
probe_output.plate_count++;
/* Print this info only when operating in secondary model. */
if (obj_meta->parent)
printf("License plate found for parent object %p (type=%s)\n",
obj_meta->parent, pgie_classes_str[obj_meta->parent->class_id]);
obj_meta->text_params.set_bg_clr = 1;
obj_meta->text_params.text_bg_clr.red = 0.0;
obj_meta->text_params.text_bg_clr.green = 0.0;
obj_meta->text_params.text_bg_clr.blue = 0.0;
obj_meta->text_params.text_bg_clr.alpha = 0.0;
obj_meta->text_params.font_params.font_color.red = 1.0;
obj_meta->text_params.font_params.font_color.green = 1.0;
obj_meta->text_params.font_params.font_color.blue = 0.0;
obj_meta->text_params.font_params.font_color.alpha = 1.0;
obj_meta->text_params.font_params.font_size = 12;
for (l_class = obj_meta->classifier_meta_list; l_class != NULL;
l_class = l_class->next)
class_meta = (NvDsClassifierMeta *)(l_class->data);
if (!class_meta)
continue;
if (class_meta->unique_component_id == SECONDARY_CLASSIFIER_UID)
for ( label_i = 0, l_label = class_meta->label_info_list;
label_i < class_meta->num_labels && l_label; label_i++,
l_label = l_label->next)
label_info = (NvDsLabelInfo *)(l_label->data);
if (label_info)
if (label_info->label_id == 0 && label_info->result_class_id == 1)
printf("Plate License %s\n",label_info->result_label);
printf("License plate found for object type=%s\n", pgie_classes_str[obj_meta->class_id]);
temp_meta = (obj_meta->unique_component_id == PRIMARY_DETECTOR_UID) ? obj_meta : obj_meta->parent;
for(current_object = 0; current_object < probe_output.num_objects; current_object++)
if((probe_output.object[current_object].objecttype = OBJECT_VHICLE) && (temp_meta == obj_meta_inrecord[current_object]))
sprintf(probe_output.object[current_object].lc_string, "%s", label_info->result_label);
probe_output.extracted_plate_count++;
break;
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params[0];
display_meta->num_labels = 1;
txt_params->display_text = (char*) g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN,
"Person = %d ", probe_output.person_count);
offset += snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN,
"Vehicle = %d ", probe_output.vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
char font_n[6];
snprintf(font_n, 6, "Serif");
txt_params->font_params.font_name = font_n;
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
if((probe_output.plate_count > 0) || (probe_output.person_count > 0))
g_print ("Frame Number = %d of Stream = %d, Vehicle Count = %d, Person Count = %d, License Plate Count = %d ************* \n\n",
frame_number, frame_meta->pad_index, probe_output.vehicle_count, probe_output.person_count,
probe_output.plate_count);
probe_output.frame_time = now;
// copy the information to a meta data structure, expect the data collection process to process it in time.
if(((deep_meta_buff_head+1)%MAX_META_BUFFS) != deep_meta_buff_tail)
memcpy(&meta_buff[deep_meta_buff_head], &probe_output, sizeof(probe_output));
deep_meta_buff_head++;
if(deep_meta_buff_head >= MAX_META_BUFFS) deep_meta_buff_head = 0;
frame_number++;
// total_plate_number += probe_output.plate_count;
#define CAPTURE_IMAGE_W_OBJ 1
#ifdef CAPTURE_IMAGE_W_OBJ
if (probe_output.person_count > 0)
// nvds_obj_enc_process() requires NV12 color format & nvdsosd element is RGBA
if (got_jpeg == false)
got_jpeg = true;
cvt_nvbufsurf_rgba_to_nv12(buf, frame_meta, batch_meta);
g_print("osd_sink_pad_buffer_probe: Encoded JPEG frame.");
#endif
return GST_PAD_PROBE_OK;
/* pgie_src_pad_buffer_probe will extract metadata received on pgie src pad
* and update params for drawing rectangle, object information etc. We also
* iterate through the object list and encode the cropped objects as jpeg
* images and attach it as user meta to the respective objects.*/
pgie_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer ctx)
GstMapInfo inmap = GST_MAP_INFO_INIT;
if (!gst_buffer_map (buf, &inmap, GST_MAP_READ)) {
GST_ERROR ("input buffer mapinfo failed");
return GST_PAD_PROBE_DROP;
NvBufSurface *ip_surf = (NvBufSurface *) inmap.data;
gst_buffer_unmap (buf, &inmap);
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsObjectMeta image_meta;
bool do_jpeg_enc = TRUE;
l_frame = l_frame->next) {
guint num_rects = 0;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) {
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
/* Conditions that user needs to set to encode the detected objects of
* interest. Here, by default all the detected objects are encoded.
* For demonstration, we will encode the first object in the frame */
if (do_jpeg_enc == TRUE &&
(obj_meta->class_id == PGIE_CLASS_ID_PERSON ||
&& num_rects == 1) {
memset(&image_meta, 0, sizeof(image_meta));
// image_meta.base_meta.batch_meta = obj_meta->base_meta.batch_meta;
image_meta.base_meta.meta_type = NVDS_CROP_IMAGE_META;
image_meta.base_meta.uContext = obj_meta->base_meta.uContext;
image_meta.base_meta.copy_func = obj_meta->base_meta.copy_func;
image_meta.base_meta.release_func = obj_meta->base_meta.release_func;
image_meta.class_id = obj_meta->class_id;
image_meta.confidence = obj_meta->confidence;
image_meta.rect_params.left = 0.0;
image_meta.rect_params.top = 0.0;
image_meta.rect_params.width = 960; // MUXER_OUTPUT_WIDTH;
image_meta.rect_params.height = 540; // MUXER_OUTPUT_HEIGHT;
/* To be set by user */
userData.saveImg = FALSE; // TRUE; // save_img;
userData.attachUsrMeta = FALSE; // TRUE; // attach_user_meta;
/* Set if Image scaling Required */
userData.scaleImg = TRUE;
userData.scaledWidth = 960;
userData.scaledHeight = 540;
/* Preset */
/* Quality */
/*Main Function Call */
nvds_obj_enc_process((NvDsObjEncCtxHandle)ctx, &userData, ip_surf, &image_meta, frame_meta);
g_print ("JPEG Encoding frame with object detected.\n");
g_print ("JPEG FINISHED Encoding frame with object detected.\n");
do_jpeg_enc = FALSE;
// nvds_obj_enc_finish ((NvDsObjEncCtxHandle)ctx);
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos (msg)) {
guint stream_id;
if (gst_nvmessage_parse_stream_eos (msg, &stream_id)) {
g_print ("Got EOS from stream %d\n", stream_id);
break;
default:
break;
return TRUE;
static void
cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *source_bin = (GstElement *) data;
GstCapsFeatures *features = gst_caps_get_features (caps, 0);
/* Need to check if the pad created by the decodebin is for video and not
* audio. */
if (!strncmp (name, "video", 5)) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
decoder_src_pad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref (bin_ghost_pad);
} else {
g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void
decodebin_child_added (GstChildProxy * child_proxy, GObject * object,
gchar * name, gpointer user_data)
if (g_strrstr (name, "decodebin") == name) {
g_signal_connect (G_OBJECT (object), "child-added",
G_CALLBACK (decodebin_child_added), user_data);
static GstElement *
create_source_bin (guint index, gchar * uri)
GstElement *bin = NULL, *uri_decode_bin = NULL;
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new (bin_name);
/* Source element for reading from the uri.
* We will use decodebin and let it figure out the container format of the
* stream and the codec and plug the appropriate demux and decode plugins. */
uri_decode_bin = gst_element_factory_make ("uridecodebin", "uri-decode-bin");
if (!bin || !uri_decode_bin) {
g_printerr ("One element in source bin could not be created.\n");
return NULL;
/* We set the input uri to the source element */
g_object_set (G_OBJECT (uri_decode_bin), "uri", uri, NULL);
/* Connect to the "pad-added" signal of the decodebin which generates a
* callback once a new pad for raw data has beed created by the decodebin */
g_signal_connect (G_OBJECT (uri_decode_bin), "pad-added",
G_CALLBACK (cb_newpad), bin);
g_signal_connect (G_OBJECT (uri_decode_bin), "child-added",
G_CALLBACK (decodebin_child_added), bin);
gst_bin_add (GST_BIN (bin), uri_decode_bin);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad (bin, gst_ghost_pad_new_no_target ("src",
GST_PAD_SRC))) {
g_printerr ("Failed to add ghost pad in source bin\n");
return NULL;
return bin;
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
*nvvidconv = NULL, *nvosd = NULL, *tiler = NULL;
GstElement *transform = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *pgie_src_pad = NULL;
GstPad *osd_sink_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
/* Check input arguments */
if (argc < 2) {
g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
return -1;
num_sources = argc - 1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("ds-image-meta-test-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
GstElement *source_bin = create_source_bin (i, argv[i + 1]);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
if(prop.integrated) {
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
if (!pgie || !tiler || !nvvidconv || !nvosd || !sink) {
return -1;
if(!transform && prop.integrated) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
"config-file-path", "ds_image_meta_pgie_config.txt", NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd,
transform, sink, NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvtiler -> nvvidconv -> nvosd -> video-renderer */
if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd,
transform, sink, NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
else {
gst_bin_add_many (GST_BIN (pipeline), pgie, tiler, nvvidconv, nvosd, sink,
NULL);
if (!gst_element_link_many (streammux, pgie, tiler, nvvidconv, nvosd, sink,
NULL)) {
return -1;
/* Lets add probe to get informed of the meta data generated, we add probe to
* the srd pad of the pgie element, since by that time, the buffer would have
* had got all the nvinfer metadata. */
pgie_src_pad = gst_element_get_static_pad (pgie, "src");
/*Creat Context for Object Encoding */
NvDsObjEncCtxHandle obj_ctx_handle = nvds_obj_enc_create_context ();
if (!obj_ctx_handle) {
g_print ("Unable to create context\n");
return -1;
if (!pgie_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
pgie_src_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
gst_object_unref (pgie_src_pad);
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
if (!osd_sink_pad)
g_print ("Unable to get sink pad\n");
else
gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, (gpointer) obj_ctx_handle, NULL);
gst_object_unref (osd_sink_pad);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 1]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Destroy context for Object Encoding */
nvds_obj_enc_destroy_context (obj_ctx_handle);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
Here’s the command line for compiling/linking:
g++ -o nvdsosd_to_jpeg nvidia_extract.cpp -Wall -std=c++11 -fPIC -Wno-error=deprecated-declarations -D_GLIBCXX_USE_CXX11_ABI=1 -g -DPLATFORM_TEGRA -I/opt/nvidia/deepstream/deepstream/sources/includes -I/usr/include/gstreamer-1.0 -I/usr/include -I/usr/include/glib-2.0 -I/usr/include -I/usr/include/arm-linux-gnueabihf -I/usr/lib/aarch64-linux-gnu/glib-2.0/include -I../src -I/usr/local/cuda/targets/aarch64-linux/include -Wl,--start-group -lnvdsgst_meta -lnvds_meta -lnvbufsurface -lnvbufsurftransform -lnvdsgst_helper -lnvds_batch_jpegenc -lm -lstdc++ -lglib-2.0 -lgio-2.0 -lgstreamer-1.0 -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lgstapp-1.0 -lgstaudio-1.0 -Wl,--end-group -Wl,-rpath,/opt/nvidia/deepstream/deepstream/lib -L/opt/nvidia/deepstream/deepstream/lib -L./ -L/usr/lib/arm-linux-gnueabihf -L../../../bin -L../../../3rdParty/boost/boost_1_79_0/stage/lib -L/usr/local/cuda/targets/aarch64-linux/lib -L/usr/local/cuda-10.2/lib64 -lboost_thread -lnvdsgst_meta -lnvds_meta -lnvbufsurface -lnvbufsurftransform -lnvdsgst_helper -lnvds_batch_jpegenc -lm -lstdc++ -lglib-2.0 -lgio-2.0 -lgstreamer-1.0 -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lgstapp-1.0 -lgstaudio-1.0 -lcudart -lm -lcuda
Thanks,
