Argus NvBuffer to jetson-inference and opencv
I am working on TX2, jetpack 3.3, OpenCV 3.4.5 environment. I found that I can not get video input through gstream because I have to use 6 csi type cameras at the same time. So I am using the camera with the argus library for video input.
  1. It succeeded to input image in nvbuffer format through argus. It also succeeded in converting it to opencv’s cv :: mat type. However, mat data obtained through this method can not be saved via cv :: imwrite and converted to jpg. I do not know what the problem is with this.
My source code is as follows.
// Acquire a frame.
    UniqueObj <Frame> frame (i_consumer _-> acquireFrame ());
    IFrame * IFrame = interface_cast <IFrame> (frame);
    if (! iFrame)
        return false;
    if (iFrame-> getNumber () <skip_frames_)
        return false;
    EGLStream :: Image * image_ = iFrame-> getImage ();
    if (save_image_)
        if ((getTick () - post_save_time_)> = (1000 / save_freq_))
            post_save_time_ = getTick ();
            stringstream save_path;
            save_path << image_file_path_ << image_file_name_ << save_count_ << "." << image_file_type_;
            EGLStream :: IImageJPEG * iImageJPEG_ = interface_cast <EGLStream :: IImageJPEG> (image_);
            status_ = iImageJPEG _-> writeJPEG (save_path.str (). c_str ());
            save_count _ ++;
            cout << "save image success:" << save_path.str () << endl;
    native_buffer_fd_ = -1;
    native_buffer_fd2_ = -1;
    NV :: IImageNativeBuffer * iNativeBuffer = interface_cast <NV :: IImageNativeBuffer> (image_);
    if (native_buffer_fd_ == -1)
        native_buffer_fd_ = iNativeBuffer-> createNvBuffer (i_stream _-> getResolution (),
        NvBufferColorFormat_ABGR32,
        NvBufferLayout_Pitch, & status_);
        native_buffer_fd2_ = iNativeBuffer-> createNvBuffer (i_stream _-> getResolution (),
        NvBufferColorFormat_YUV420,
        NvBufferLayout_BlockLinear, & status_);
            cout << "Failed to create NvBuffer" << endl;
            return false;
        if (native_buffer_fd2_ == -1)
            return false;
    void * pdata = NULL;
    NvBufferMemMap (native_buffer_fd_, 0, NvBufferMem_Read_Write, & pdata);
    NvBufferMemSyncForCpu (native_buffer_fd_, 0, & pdata);
    // NvBufferMemSyncForDevice (native_buffer_fd_, 0, & pdata);
    Matrix imgbuf = Mat (height_, width_,
                     CV_8UC4, pdata);
    if (imgbuf.empty ())
        cout << "imgbuf empty." << endl;
        return false;
    cvtColor (imgbuf, frame_, COLOR_RGBA2BGR);
You can not imwrite any jpg compression with the cv :: Mat frame_ input from the following code. What is the problem with this? I copied the cv :: mat for this, received the input, and tried to input the value rather than the pointer, but all failed.
  1. I also have to do a tensorrt-based inference using this input image. I am referring to jetson-inference as a reference. However, there is no example anywhere in the package to receive images from the argus library. Do you have any examples or source code to refer to?
Please check our tegra_multimedia_api which is located at /usr/src/.
There are some examples to demonstrate the argus utilization and you can get more information from there.
I already checked, but i can’t find.
give me some examples.
thanks.
We don’t have the exact sample for Argus to OpenCV.
But you can find one for Argus to the CPU or CUDA memory, like argus/samples/histogram/ or argus/samples/cudaHistogram/.
And you can create a cvmat object with the buffer directly:
https://docs.opencv.org/3.4.5/d3/d63/classcv_1_1Mat.html#a51615ebf17a64c968df0bf49b4de6a3a
