Using OpenCV to create cv::Mat objects from images received by the Argus yuvJpeg sample program
In the yuvJpeg sample code, in method ConsumerThread::threadExecute(), we see the following code snippet:
Image *image = iFrame->getImage();
IImage *iImage = interface_cast<IImage>(image);
IImage2D *iImage2D = interface_cast<IImage2D>(image);
I’d like to convert the image to an OpenCV cv::Mat object (BGR color space), but haven’t found the correct method for doing so. The following code snippet produces cv::Mat objects that, when presented by cv::imshow(), are fairly “scrambled”:
            if (iImage->getBufferCount() == 2) {
                // Convert the YUV image to the RGB color space. Note that OpenCV Matrix objects store the color
                // channels in the order of blue, green, and red (hence the "bgr" naming convention).
                Argus::Size2D<uint32_t> ySize  = iImage2D->getSize(Y);
                Argus::Size2D<uint32_t> uvSize = iImage2D->getSize(UV);
                cv::Mat y(ySize.height(),   ySize.width(),  CV_8UC1, const_cast<void*>(iImage->mapBuffer(Y)),  iImage2D->getStride(Y));
                cv::Mat uv(uvSize.height(), uvSize.width(), CV_8UC2, const_cast<void*>(iImage->mapBuffer(UV)), iImage2D->getStride(UV));
                cv::UMat yUMat = y.getUMat(cv::ACCESS_READ);
                cv::UMat uvUMat = uv.getUMat(cv::ACCESS_READ);
                cv::cvtColorTwoPlane(yUMat, uvUMat, bgr, cv::COLOR_YUV2BGR_NV12);
I’m using the original yuvJpeg sample code on the producer thread for defining the pixel format:
iStreamSettings->setPixelFormat(Argus::PIXEL_FMT_YCbCr_420_888);
Any suggestions would be much appreciated!
Fo rthe use-case, you can call createNvBuffer() an dmap the buffer to cv::Mat, please refer to the patch:
NVBuffer (FD) to opencv Mat - #6 by DaneLLL
And refer to the samples for calling createNvBuffer()/copyToNvBuffer():
/usr/src/jetson_multimedia_api/samples/09_camera_jpeg_capture/
/usr/src/jetson_multimedia_api/samples/13_multi_camera/
DaneLLL:
The following code appears to work correctly:
    bool ConsumerThread::threadExecute() {
        const unsigned int  plane               = 0;
        const std::string   capturedVideoFrames = "Captured video frames";
        const auto          *iStream            = Argus::interface_cast<Argus::IEGLOutputStream>(m_stream);
        const auto          *iEglOutputStream   = Argus::interface_cast<Argus::IEGLOutputStream>(m_stream);
        const Argus::Size2D streamResolution    = iEglOutputStream->getResolution();
        // Wait until the producer has connected to the stream.
        threads::enqueueLoggerMessage(threadName, "Waiting until producer is connected...");
        if (iStream->waitUntilConnected() != Argus::STATUS_OK)
            ORIGINATE_ERROR("Stream failed to connect.");
        threads::enqueueLoggerMessage(threadName, "Producer has connected; continuing.");
        // Continue until this thread is terminated.
        threads::addMetric(capturedVideoFrames);
        auto *iFrameConsumer = Argus::interface_cast<EGLStream::IFrameConsumer>(m_consumer);
        cv::Mat bgr;
        while (true) {
            // The absence of a frame indicates this thread has been terminated.
            Argus::UniqueObj<EGLStream::Frame> frame(iFrameConsumer->acquireFrame());
            if (!frame)
                break;
            // Keep track of how many video frames per second we are consuming.
            threads::incrementMetric(capturedVideoFrames);
            // Create an IFrame interface to gain access to the Image in the Frame.
            auto *iFrame = Argus::interface_cast<EGLStream::IFrame>(frame);
            if (!iFrame) {
                ORIGINATE_ERROR("Failed to get IFrame interface.");
            // Copy the image into an OpenCV Mat object. Note that OpenCV Matrix objects store the color
            auto *iNativeBuffer = Argus::interface_cast<EGLStream::NV::IImageNativeBuffer>(iFrame->getImage());
            if (!iNativeBuffer) {
                ORIGINATE_ERROR("IImageNativeBuffer not supported by Image.");
            if (m_dmabuf == -1) {
                m_dmabuf = iNativeBuffer->createNvBuffer(
                        streamResolution,
                        NvBufferColorFormat_ABGR32,
                        NvBufferLayout_Pitch);
                    ORIGINATE_ERROR("\tFailed to create NvBuffer\n");
            if (iNativeBuffer->copyToNvBuffer(m_dmabuf) != Argus::STATUS_OK) {
                ORIGINATE_ERROR("Failed to copy frame to NvBuffer.");
            void *pdata = nullptr;
            NvBufferParams params;
            NvBufferGetParams(m_dmabuf, &params);
            NvBufferMemMap(m_dmabuf, plane, NvBufferMem_Read, &pdata);
            NvBufferMemSyncForCpu(m_dmabuf, plane, &pdata);
            cv::Mat imgbuf = cv::Mat(streamResolution.height(), streamResolution.width(), CV_8UC4, pdata, params.pitch[0]);
            cv::cvtColor(imgbuf, bgr, cv::COLOR_RGBA2BGR);
            // Notify all listeners that a video frame is available.
            for (auto & listener : ConsumerThread::listeners) {
                cv::Mat clonedImage = bgr.clone();
                listener(clonedImage);
        threads::enqueueLoggerMessage(threadName, "Done.");
        PROPAGATE_ERROR(requestShutdown());
        return true;
Many thanks for the tips identified in this thread.
