I repeated the start/stop experiment for several batches of 1000 repetitions.
There seem to be a different issue now, affecting “start” rather than “stop” (waitForIdle) phase.
Example of failure log from argus_syncsensor (e.g. 59 of 1000 runs):
# Runs 0 to 58 succeeded
[2026-08-10 12:47:17] Run 59/10000: -t 5
Executing Argus Sample: argus_syncsensor
Argus Version: 0.99.3.3 (multi-process)
PRODUCER: Creating left stream.
PRODUCER: Creating right stream.
PRODUCER: Launching disparity checking consumer
Initializing CUDA
CONSUMER: Connecting CUDA consumer to left stream
CONSUMER: Connecting CUDA consumer to right stream
CONSUMER: Waiting for Argus producer to connect to left stream.
PRODUCER: Starting repeat capture requests.
CONSUMER: Waiting for Argus producer to connect to right stream.
CONSUMER: Streams connected, processing frames.
PRODUCER: Captures complete, disconnecting producer.
# My script kills process if hangs for more than a minute
./repeat.sh: line 22: 173667 Killed timeout --signal=KILL "${timeout_s}" ${program} "$@"
[2026-08-10 12:48:17] TIMEOUT on run 59/10000 after 60: -t 5
And corresponding failure in nvargus-daemon for the failed run:
=== argus_syncsensor[173668]: Connection established (FFFF83FAB840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
LSC: LSC surface is not based on full res!
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 455)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 382)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 554)
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
=== argus_syncsensor[173668]: CameraProvider initialized (0xffff7db8d830)LSC: LSC surface is not based on full res!
SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 145)
SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
SCF: Error Timeout: Sending critical error event for Session 4
(in src/api/Session.cpp, function sendErrorEvent(), line 1039)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDeviceViCsi.cpp, function waitCompletion(), line 368)
SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceDevice.cpp, function pause(), line 1069)
SCF: Error Timeout: During capture abort, syncpoint wait timeout waiting for current frame to finish (in src/services/capture/CaptureServiceDevice.cpp, function handleCancelSourceRequests(), line 1164)
SCF: Error InvalidState: Sensor 2 already in same state
(in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 0 draining session frameEnd events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 646)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 0 draining session frameStart events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 529)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 1 draining session frameEnd events 2
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 2 draining session frameEnd events 1
SCF: Error InvalidState: Sensor GUID 2 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 543)
SCF: Error BadParameter: CC has already been disposed (in src/components/CaptureContainerManager.cpp, function dispose(), line 161)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 2, capture sequence ID = 2 draining session frameStart events 1
=== argus_syncsensor[173668]: Connection closed (FFFF83FAB840)=== argus_syncsensor[173668]: WARNING: CameraProvider was not destroyed before client connection terminated.=== argus_syncsensor[173668]: The client may have abnormally terminated. Destroying CameraProvider...=== argus_syncsensor[173668]: CameraProvider destroyed (0xffff7db8d830)=== argus_syncsensor[173668]: WARNING: Cleaning up 1 outstanding requests...=== argus_syncsensor[173668]: WARNING: Cleaning up 1 outstanding stream settings...=== argus_syncsensor[173668]: WARNING: Cleaning up 1 outstanding sessions...PowerServiceCore:handleRequests: timePassed = 56041
=== argus_syncsensor[173668]: WARNING: Cleaning up 2 outstanding streams...(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 1106)
=== argus_syncsensor[173668]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.=== argus_syncsensor[173668]: Connection cleaned up (FFFF83FAB840)
