I noticed when I run the yuvJpeg sample, frames 2 and 3 are always missing. In other words I get “1.JPG”, “4.JPG”, “5.JPG”, etc. Why is this the case?
hello randyzhg,
would like to have more details from your side.
sudo /usr/sbin/argus_daemon
I have the stock TX2 evaluation kit, so OV5693 I think.
Running ./jetsonclocks.sh before running the sample fixed the issue. I thought I already did that yesterday but I guess apparently not. Thanks.
hello randyzhg,
there’s timing issue in the yuvJpeg application, please set the stream to FIFO to fix the issue.
thanks
diff --git a/public/samples/yuvJpeg/main.cpp b/public/samples/yuvJpeg/main.cpp
index 7ed6d0e..ab649e8 100644
--- a/public/samples/yuvJpeg/main.cpp
+++ b/public/samples/yuvJpeg/main.cpp
@@ -228,6 +228,7 @@ static bool execute(const ExecuteOptions& options)
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(STREAM_SIZE);
+ iStreamSettings->setMode(STREAM_MODE_FIFO);
iStreamSettings->setMetadataEnable(true);
Ok thanks! I will try it.
I also have a general question. What are the advantages of using the Argus API over using nvcamerasrc with GStreamer?
