Dear community,
I want to create a robot with 4 wheels and control it with ROS2. So far, I have the robot model, I have the joints and I implemented the ROS2 interface. When I drive it forwards and backwards, it works fine. When I want to rotate it, it does not work properly. I can see the wheels spinning in the right direction, but the robot is barely rotating. It actually moves slightly forwards/backwards depending on the left/right movement I send.
I implemented the node graph as seen below, where I have 2 Articulation Controllers (one for the front wheels and one for the rear wheels).
I am trying to apply the same technique on two different robots: a Husky and a Leo Rover.
In both cases, I have the same behaviour. Unfortunately, all the ROS examples only use 2-wheeled robots, so I have no good reference if this is right the way I am trying to do it.
Are there any suggestions on this?
I am using Omniverse 2022.2.0 on a docker container, running on a remote computer with Ubuntu 20.04 as base.
Thanks for any suggestions.
