Assign Multi GPU on XenServer 6.2 with SLES 11?
can somebody provide me information how to assign a second NVIDIA Quadro K5000 card to a SLES 11 VM? For the moment I can assign only 1 GPU to a VM but my host has 2 Quadro K5000 which I would like to use in one VM.
Solved!
Detected 2 CUDA Capable device(s)
Device 0: "Quadro K5000"
  CUDA Driver Version / Runtime Version          7.0 / 7.0
  CUDA Capability Major/Minor version number:    3.0
  Total amount of global memory:                 4096 MBytes (4294770688 bytes)
  ( 8) Multiprocessors, (192) CUDA Cores/MP:     1536 CUDA Cores
  GPU Clock rate:                                706 MHz (0.71 GHz)
  Memory Clock rate:                             2700 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 524288 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
  Maximum Layered 1D Texture Size, (num) layers  1D=(16384), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(16384, 16384), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 5
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "Quadro K5000"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 6
  Compute Mode:
> Peer access from Quadro K5000 (GPU0) -> Quadro K5000 (GPU1) : No
> Peer access from Quadro K5000 (GPU1) -> Quadro K5000 (GPU0) : No
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.0, CUDA Runtime Version = 7.0, NumDevs = 2, Device0 = Quadro K5000, Device1 = Quadro K5000
Result = PASS
