Is there a list of NVIDIA GPUs that support CUDA’s dual copy engine?
I have an application that benefits from dual copy engine, but I’m finding it difficult to find a list of which cards support this feature. I think that most NVIDIA Quadro GPUs have dual copy engines for CUDA and GeForce do not, but there are exceptions.
Exceptions to this rule of thumb:
Quadro K2200M does not have dual copy engines.
GeForce GTX 950 and GTX TITAN X do have dual copy engines.
Alternatively, can I simulate a particular GPU model, and use CUDA to query all of its properties?
Look at the deviceQuery sample application on how to check for the number of copy engines on a particular GPU (sample output below). There is no GPU simulation that I am aware of, you will need to test actual GPUs to find out.
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Quadro K2200"
CUDA Driver Version / Runtime Version 9.0 / 8.0
CUDA Capability Major/Minor version number: 5.0
Total amount of global memory: 4096 MBytes (4294967296 bytes)
( 5) Multiprocessors, (128) CUDA Cores/MP: 640 CUDA Cores
GPU Max Clock rate: 1124 MHz (1.12 GHz)
Memory Clock rate: 2505 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s) <<<<<<<<<<<<<<<<<<<<<<<<<
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
