Goal: Assign a VLAN id to a virtual NIC under SR-IOV
Problem: the putative command “ip link set dev ieth2 vf 0 vlan 153” reports “RTNETLINK answers: Operation not supported.”
Context:
I am able to configure (under Redhat) a ConnectX-6 NIC into SR-IOV mode and make virtual NICs. The NIC is programmed into switch dev mode. I can assign MAC addresses to the virtual functions, including IPV4 addresses. All that works fine.
For the purposes of this question the error arises this way:
Assume NIC configure in HW for SR-IOV OK
Assume host BIOS has SR-IOV, Vt-d ON
Assume Linux box has IOMMU in boot line
Now the next steps are,
devlink dev eswitch set pci/ mode switchdev
echo 4 > /sys/class/net/ieth2/device/sriov_numvfs
echo > /sys/bus/pci/drivers/mlx5_core/unbind
ip link set ieth2 vf 0 mac xx:xx:…xx
Lines 4 through 7 work fine. The next line DOES NOT WORK reporting “Operation not supported”:
The correct order is make SR-IOV VFs, then configure VF mac/qlan etc., then put the link into switchdev mode:
DEV="ieth3"
MLX="mlx5_0"
PCI="0000:12:00.0"
# turn off SR-IOV
echo 0 > /sys/class/net/$DEV/device/sriov_numvfs
# put link into normal, legacy mode
devlink dev eswitch set pci/$PCI mode legacy
devlink dev eswitch show pci/$PCI
# OK, starting in a define state turn on SR-IOV
set -x
# make four virtual NICs
echo 4 > /sys/class/net/$DEV/device/sriov_numvfs
# unbind the VF0 on 0000:12:00.2
echo 0000:12:00.2 > /sys/bus/pci/drivers/mlx5_core/unbind
# turn trust on, spookchk on, and assign qlan plus mac
ip link set $DEV vf 0 trust on
ip link set $DEV vf 0 spoofchk on
ip link set $DEV vf 0 vlan 153
ip link set $DEV vf 0 mac 80:37:57:17:44:00
# rebind it to MLX5 driver
echo 0000:12:00.2 > /sys/bus/pci/drivers/mlx5_core/bind
set +x
# and end with putting ieth3 (the physical function) into switchdev mode
devlink dev eswitch set pci/$PCI mode switchdev encap-mode none
ip -d link show $DEV
I use connectx-6 in switchdev mode
I m testing passing VF to a virtual machine on proxmox (with VFIO)
it s work fine
At boot , before switch to eswitch switchdev mode , I set mac address and “spoofchk on”
settings are here :
11: ens1f1np1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc mq state UP mode DEFAULT group default qlen 10000
link/ether b8:3f:d2:e9:b1:07 brd ff:ff:ff:ff:ff:ff
vf 0 link/ether a4:da:22:6a:90:00 brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state disable, trust off, query_rss off
but the eswitch filter nothing, if I change the (vm) mac-address
so VF connectivity in eswitch is working good but we cant filter any mac without tc rules
It seems eswitch does not honor VF featureset so I m not surprise you can t set vlan on VF iface
do you know what is the difference beytween legacy and switchdev modes ?
