Problem trying to test a ConnectX-4 LC with switchdev
Hi there,
I’m hoping someone can point out what I’m doing wrong when trying to configure switchdev mode with a Mellanox ConnectX-4 LC adapter.
I also see that the dmesg output states the normal SRIOV mode is listed as “LEGACY”, does this mean it could be removed in future?
For testing switchdev I’m getting the below error:
Error: mlx5_core: Error checking for existing bridge with same ifindex.
I’m testing out on Archlinux on a clean install.
# uname -a
Linux localhost.localdomain 6.14.2-arch1-1 #1 SMP PREEMPT_DYNAMIC Thu, 10 Apr 2025 18:43:59 +0000 x86_64 GNU/Linux
# ip link
2: eno1np0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
     link/ether ec:0d:9a:3a:ce:ca brd ff:ff:ff:ff:ff:ff
     altname enp1s0f0np0
     altname enxec0d9a3aceca
3: eno2np1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
     link/ether ec:0d:9a:3a:ce:cb brd ff:ff:ff:ff:ff:ff
     altname enp1s0f1np1
     altname enxec0d9a3acecb
# lspci -vnn -s 01:00.0; lspci -vnn -s 01:00.1
01:00.0 Ethernet controller [0200]: Mellanox Technologies MT27710 Family [ConnectX-4 Lx] [15b3:1015]
         DeviceName: NIC1
         Subsystem: Mellanox Technologies ConnectX-4 Lx 25 GbE Dual Port SFP28 rNDC [15b3:0025]
         Flags: bus master, fast devsel, latency 0, IRQ 126, NUMA node 0, IOMMU group 40
         Memory at a6000000 (64-bit, prefetchable) [size=32M]
         Expansion ROM at b7e00000 [disabled] [size=1M]
         Capabilities: [60] Express Endpoint, IntMsgNum 0
         Capabilities: [48] Vital Product Data
         Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
         Capabilities: [c0] Vendor Specific Information: Len=18 <?>
         Capabilities: [40] Power Management version 3
         Capabilities: [100] Advanced Error Reporting
         Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
         Capabilities: [180] Single Root I/O Virtualization (SR-IOV)
         Capabilities: [1c0] Secondary PCI Express
         Capabilities: [230] Access Control Services
         Kernel driver in use: mlx5_core
         Kernel modules: mlx5_core
01:00.1 Ethernet controller [0200]: Mellanox Technologies MT27710 Family [ConnectX-4 Lx] [15b3:1015]
         DeviceName: NIC2
         Flags: bus master, fast devsel, latency 0, IRQ 129, NUMA node 0, IOMMU group 41
         Memory at a4000000 (64-bit, prefetchable) [size=32M]
         Expansion ROM at b7f00000 [disabled] [size=1M]
# lspci
01:00.2 Ethernet controller [0200]: Mellanox Technologies MT27710 Family
[ConnectX-4 Lx Virtual Function] [15b3:1016]
01:00.3 Ethernet controller [0200]: Mellanox Technologies MT27710 Family
01:00.4 Ethernet controller [0200]: Mellanox Technologies MT27710 Family
01:00.5 Ethernet controller [0200]: Mellanox Technologies MT27710 Family
I then unbind from mlx5_core…
# echo 0000:01:00.2 > /sys/bus/pci/drivers/mlx5_core/unbind
# echo 0000:01:00.3 > /sys/bus/pci/drivers/mlx5_core/unbind
# echo 0000:01:00.4 > /sys/bus/pci/drivers/mlx5_core/unbind
# echo 0000:01:00.5 > /sys/bus/pci/drivers/mlx5_core/unbind
And set the device into switchdev mode…
# devlink dev eswitch set pci/0000:01:00.0 mode switchdev
# devlink dev eswitch show pci/0000:01:00.0
pci/0000:01:00.0: mode switchdev inline-mode link encap-mode basic
# devlink dev show
pci/0000:01:00.0:
   nested_devlink:
     auxiliary/mlx5_core.eth.0
pci/0000:01:00.1:
   nested_devlink:
     auxiliary/mlx5_core.eth.1
pci/0000:04:00.0:
   nested_devlink:
     auxiliary/mlx5_core.eth.2
pci/0000:04:00.1:
   nested_devlink:
     auxiliary/mlx5_core.eth.3
# dmesg
[ 1184.307616] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(4), necvfs(0), active vports(5)
[ 1187.238127] mlx5_core 0000:01:00.0: E-Switch: Tc chains and priorities offload aren't supported
[ 1187.656245] mlx5_core 0000:01:00.0: sampler_termtbl_create:72:(pid 2002): termination table is not supported
[ 1187.764322] mlx5_core 0000:01:00.0 eno1np0: Dropping C-tag vlan stripping offload due to S-tag vlan
[ 1187.764330] mlx5_core 0000:01:00.0 eno1np0: Disabling HW_VLAN CTAG FILTERING, not supported in switchdev mode
[ 1187.905188] mlx5_core 0000:01:00.0 eno1r0: renamed from eth0
[ 1187.997947] mlx5_core 0000:01:00.0 eno1r1: renamed from eth0
[ 1188.094991] mlx5_core 0000:01:00.0 eno1r2: renamed from eth0
[ 1188.186064] mlx5_core 0000:01:00.0: E-Switch: Enable: mode(OFFLOADS),
nvfs(4), necvfs(0), active vports(4)
[ 1188.188408] mlx5_core 0000:01:00.0 eno1r3: renamed from eth0
All looks good so far…
# ip link
     vf 0     link/ether 42:10:90:00:01:00 brd ff:ff:ff:ff:ff:ff, spoof
checking off, link-state disable, trust off, query_rss off
     vf 1     link/ether 42:10:90:00:01:01 brd ff:ff:ff:ff:ff:ff, spoof
     vf 2     link/ether 42:10:90:00:01:02 brd ff:ff:ff:ff:ff:ff, spoof
     vf 3     link/ether 42:10:90:00:01:03 brd ff:ff:ff:ff:ff:ff, spoof
     altname enp1s0f0np0
11: eno1r0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode
     link/ether 2e:4c:3a:17:70:2e brd ff:ff:ff:ff:ff:ff
     altname enp1s0f0r0
12: eno1r1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode
     link/ether 46:16:78:95:a5:1f brd ff:ff:ff:ff:ff:ff
     altname enp1s0f0r1
13: eno1r2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode
     link/ether 5e:7d:1d:8e:09:d2 brd ff:ff:ff:ff:ff:ff
     altname enp1s0f0r2
14: eno1r3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode
     link/ether 66:28:62:9c:2c:59 brd ff:ff:ff:ff:ff:ff
     altname enp1s0f0r3
The problem comes in when I try add the device to a bridge… from
networking/device_drivers/ethernet/mellanox/mlx5/switchdev.html
# ip link add testbr0 type bridge
# ip link set eno1np0 master testbr0
I get the same error trying to add the representor devices…
# ip link set eno1r0 master testbr0
# dmesg
[ 1515.581631] testbr0: port 1(eno1np0) entered blocking state
[ 1515.581637] testbr0: port 1(eno1np0) entered disabled state
[ 1515.581661] mlx5_core 0000:01:00.0 eno1np0: entered allmulticast mode
[ 1515.581724] mlx5_core 0000:01:00.0 eno1np0: left allmulticast mode
[ 1515.581730] mlx5_core 0000:01:00.0 eno1np0: failed (err=-22) to set
attribute (id=6)
[ 1703.825900] testbr0: port 1(eno1r0) entered blocking state
[ 1703.825906] testbr0: port 1(eno1r0) entered disabled state
[ 1703.825937] mlx5_core 0000:01:00.0 eno1r0: entered allmulticast mode
[ 1703.826043] mlx5_core 0000:01:00.0 eno1r0: left allmulticast mode
[ 1703.826051] mlx5_core 0000:01:00.0 eno1r0: failed (err=-22) to set
attribute (id=6)
Additional details…
# devlink -V
devlink utility, iproute2-6.14.0
# ip -V
ip utility, iproute2-6.14.0, libbpf 1.5.0
# bridge -V
bridge utility, 6.14.0
# mstflint -d 01:00.0 q
Image type:            FS3
FW Version:            14.32.2004
FW Release Date:       13.1.2022
Product Version:       14.32.2004
Rom Info:              type=UEFI version=14.25.18 cpu=AMD64
                        type=PXE version=3.6.502 cpu=IA32
Description:           UID                GuidsNumber
Base GUID:             ec0d9a03003aceca        8
Base MAC:              ec0d9a3aceca            8
Image VSD:             N/A
Device VSD:            N/A
PSID:                  DEL2810000034
Security Attributes:   N/A
Any help or guidance would be greatly appreciated!
Kind Regards
Nigel
Make sure to use our Nvidia MLNX driver, the OS mlx5 Inbox driver is not tested with Nvidia but rather the respective OSs vendor.
Ref to our drivers:
We have multiple solutions with “switchdev” configuration + OVS
Ref https://docs.nvidia.com/networking/display/nvidia-mlnx-ofed-documentation-v24-10-2-1-8-0-lts.0%20LTS.pdf
OVS offload using ASAP2 direct
OVS-kernel hardware offloads
Note: The solutions were implemented for ConnectX-5 onwards, the ConnectX4 LX was not part of these solutions.
You can further consult with the OS vendor for a qualified solution or refer to DELL as I see the PSID is DEL2810000034
I community !
I encounter the same pb
It seems that someting wrong in the sequence of unload VF from VM
my script process in this way:
put the device down and next set it nomaster
I think there is a mistake in the sync of vf state , kernel nomaster is OK but mlx5_core eswitch see the vf already member of a bridge device
have you found a solution ?
perhaps a low-level reset of the vf pci dev (not tested yet) :
echo 1 > /sys/bus/pci/devices/0000:43:1f.7/reset
No luck so far from my side. Official response from Nvidia is just to use OFED.
It’s definitely a bug imho, all docs point to it suppose to working. I also mailed the kernel networking mailing list but didn’t get any response.
hum… I am using ofed, Nvidia solution is a beat confused for me :(
I’d like to give a few details of my experience, if that helps.
in my case, the error occurs in the following circumstances:
a VM fails to start. The VF associated with this VM has been named, put in the bridge and linked up.
when I try a 2nd startup then the error appears
This is normal since the VF is suddenly released without being cleaned.
I clean up and everything goes back to normal.
However, I’ve also seen this error when all the free VFs were in a clean state.
That why I suppose there is a sync error between kernel and eswitch bridge representation
