When an adapter is configure for vlan-aware linux bridging, all traffic stops flowing on the bridge. Both, untagged and tagged traffic is affected. The same configuration works as it should with non mellanox cards.
To restore traffic flow on vlan-aware bridge, Mellanox card needs to be manually put in promiscuous mode by issuing: “ip link set dev ens6f0np0 promisc on”
The second interface on the same card on NON vlan-aware bridge enters promisc mode automatically once added to the bridge with no user interaction.
Any ideas will be appreciated.
Configuration details:
OS: Debian 10 Buster + ProxMox (PVE 6.4), latest 5.12.12 Linux kernel
NIC/FW:
root@pve-bfs-1:~# mlxfwmanager
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX4LX
Part Number: MCX4121A-ACU_Ax
Description: ConnectX-4 Lx EN network interface card; 25GbE dual-port SFP28; PCIe3.0 x8; UEFI Enabled; tall bracket
PSID: MT_0000000266
PCI Device Name: /dev/mst/mt4117_pciconf0
Base MAC:
Versions: Current Available
FW 14.30.1004 14.30.1004
PXE 3.6.0301 3.6.0301
UEFI 14.23.0017 14.23.0017
Status: Up to date
Driver:
root@pve-bfs-1:~# modinfo mlx5_core
filename: /lib/modules/5.12.12-1-edge/kernel/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.ko
license: Dual BSD/GPL
description: Mellanox 5th generation network adapters (ConnectX series) core driver
author: Eli Cohen eli@mellanox.com
srcversion: E69AFAD4870C439C8F80D4C
alias: auxiliary:mlx5_core.eth
alias: pci:v000015B3d0000A2DCsvsdbcsci*
alias: pci:v000015B3d0000A2D6svsdbcsci*
alias: pci:v000015B3d0000A2D3svsdbcsci*
alias: pci:v000015B3d0000A2D2svsdbcsci*
alias: pci:v000015B3d00001021svsdbcsci*
alias: pci:v000015B3d0000101Fsvsdbcsci*
alias: pci:v000015B3d0000101Esvsdbcsci*
alias: pci:v000015B3d0000101Dsvsdbcsci*
alias: pci:v000015B3d0000101Csvsdbcsci*
alias: pci:v000015B3d0000101Bsvsdbcsci*
alias: pci:v000015B3d0000101Asvsdbcsci*
alias: pci:v000015B3d00001019svsdbcsci*
alias: pci:v000015B3d00001018svsdbcsci*
alias: pci:v000015B3d00001017svsdbcsci*
alias: pci:v000015B3d00001016svsdbcsci*
alias: pci:v000015B3d00001015svsdbcsci*
alias: pci:v000015B3d00001014svsdbcsci*
alias: pci:v000015B3d00001013svsdbcsci*
alias: pci:v000015B3d00001012svsdbcsci*
alias: pci:v000015B3d00001011svsdbcsci*
alias: auxiliary:mlx5_core.eth-rep
alias: auxiliary:mlx5_core.sf
depends: tls,pci-hyperv-intf,mlxfw
retpoline: Y
intree: Y
vermagic: 5.12.12-1-edge SMP mod_unload modversions
parm: debug_mask:debug mask: 1 = dump cmd data, 2 = dump cmd exec time, 3 = both. Default=0 (uint)
parm: prof_sel:profile selector. Valid range 0 - 2 (uint)
network/interfaces:
auto lo
iface lo inet loopback
iface ens6f0np0 inet manual
iface ens6f1np1 inet manual
mtu 9000
auto vmbr0
iface vmbr0 inet static
address 10.0.0.11/24
gateway 10.0.0.1
bridge-ports ens6f0np0
bridge-stp off
bridge-fd 0
bridge-vlan-aware yes
bridge-vids 2-4094
auto vmbr1
iface vmbr1 inet static
address 10.0.1.11/24
bridge-ports ens6f1np1
bridge-stp off
bridge-fd 0
mtu 9000
