recently got a Mellanox Connectx-4 Lx EN to work with and I want to find a way to enable WOL. According to this spec-sheet provided by NVIDIA it should support WOL out of the box but it seems my card is missing the configuration option of WOL.
What exactly could be the reason for this and is there any way to enable it again?
The card is used on Windows 11 23H2. Most options I could find to enable WOL require ethtool a UNIX utility that is available for Windows. The WinOF-2 docs also sadly don’t mention a way of achieving this. Older forum post go mostly without a proper answer, so I would like to reopen this issue anew with up to date information.
Could it be that the option is only available through Linux?
Device and Firmware
mlxfwmanager --query
Querying Mellanox devices firmware ...
Device #1:
Device Type: ConnectX4LX
Part Number: MCX4121A-ACH_Ax
Description: ConnectX-4 Lx EN network interface card; with host management; 25GbE dual-port SFP28; PCIe3.0 x8; UEFI enabled;
PSID: MT_0000000647
PCI Device Name: mt4117_pciconf0
Base MAC: b8cef67485ca
Versions: Current Available
FW 14.32.1900 N/A
PXE 3.6.0502 N/A
UEFI 14.25.0017 N/A
Status: No matching image found
Supported configuration with current firmware
mlxconfig -d mt4117_pciconf0 query
Device #1:
Device type: ConnectX4LX
Device: mt4117_pciconf0
Configurations: Next Boot
FLEX_PARSER_PROFILE_ENABLE 0
FLEX_IPV4_OVER_VXLAN_PORT 0
SWITCH_COMPT_FEATURE_MASK 0x0(0)
PF_NUM_OF_VF_VALID False(0)
NON_PREFETCHABLE_PF_BAR False(0)
VF_VPD_ENABLE False(0)
STRICT_VF_MSIX_NUM False(0)
VF_NODNIC_ENABLE False(0)
NUM_PF_MSIX_VALID True(1)
NUM_OF_VFS 8
NUM_OF_PF 2
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
PCIE_CREDIT_TOKEN_TIMEOUT 0
PCI_BUS0_RESTRICT_SPEED PCI_GEN_1(0)
PCI_BUS0_RESTRICT_ASPM False(0)
PCI_BUS0_RESTRICT_WIDTH PCI_X1(0)
PCI_BUS0_RESTRICT False(0)
PCI_DOWNSTREAM_PORT_OWNER Array[0..15]
LOG_DCR_HASH_TABLE_SIZE 14
MAX_PACKET_LIFETIME 0
DCR_LIFO_SIZE 16384
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
ICM_CACHE_MODE DEVICE_DEFAULT(0)
TX_SCHEDULER_BURST 0
ACCURATE_TX_SCHEDULER False(0)
PARTIAL_RESET_EN False(0)
SW_RECOVERY_ON_ERRORS False(0)
RESET_WITH_HOST_ON_ERRORS False(0)
ROCE_NEXT_PROTOCOL 254
LOG_MAX_QUEUE 17
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
MKEY_BY_NAME False(0)
UCTX_EN True(1)
PCI_ATOMIC_MODE PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
TUNNEL_ECN_COPY_DISABLE False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 13
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
IB_PROTO_WIDTH_EN_MASK_P1 0
IB_PROTO_WIDTH_EN_MASK_P2 0
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
DO_NOT_CLEAR_PORT_STATS_P1 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
KEEP_ETH_LINK_UP_P2 True(1)
KEEP_IB_LINK_UP_P2 False(0)
KEEP_LINK_UP_ON_BOOT_P2 False(0)
KEEP_LINK_UP_ON_STANDBY_P2 False(0)
DO_NOT_CLEAR_PORT_STATS_P2 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P2 False(0)
PHY_FEC_OVERRIDE_P1 DEVICE_DEFAULT(0)
PHY_FEC_OVERRIDE_P2 DEVICE_DEFAULT(0)
LLDP_NB_DCBX_P1 False(0)
LLDP_NB_RX_MODE_P1 OFF(0)
LLDP_NB_TX_MODE_P1 OFF(0)
LLDP_NB_DCBX_P2 False(0)
LLDP_NB_RX_MODE_P2 OFF(0)
LLDP_NB_TX_MODE_P2 OFF(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 True(1)
DCBX_WILLING_P2 True(1)
DUP_MAC_ACTION_P1 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P1 LID(1)
DUP_MAC_ACTION_P2 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P2 LID(1)
NUM_OF_PLANES_P1 0
NUM_OF_PLANES_P2 0
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
VL15_BUFFER_SIZE_P1 0
NUM_OF_VL_P2 _4_VLs(3)
NUM_OF_TC_P2 _8_TCs(0)
NUM_OF_PFC_P2 8
VL15_BUFFER_SIZE_P2 0
ROCE_CC_PRIO_MASK_P1 255
ROCE_CC_CNP_MODERATION_P1 DEVICE_DEFAULT(0)
ROCE_CC_PRIO_MASK_P2 255
ROCE_CC_CNP_MODERATION_P2 DEVICE_DEFAULT(0)
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 4
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
CLAMP_TGT_RATE_AFTER_TIME_INC_P2 True(1)
CLAMP_TGT_RATE_P2 False(0)
RPG_TIME_RESET_P2 300
RPG_BYTE_RESET_P2 32767
RPG_THRESHOLD_P2 1
RPG_MAX_RATE_P2 0
RPG_AI_RATE_P2 5
RPG_HAI_RATE_P2 50
RPG_GD_P2 11
RPG_MIN_DEC_FAC_P2 50
RPG_MIN_RATE_P2 1
RATE_TO_SET_ON_FIRST_CNP_P2 0
DCE_TCP_G_P2 1019
DCE_TCP_RTT_P2 1
RATE_REDUCE_MONITOR_PERIOD_P2 4
INITIAL_ALPHA_VALUE_P2 1023
MIN_TIME_BETWEEN_CNPS_P2 4
CNP_802P_PRIO_P2 6
CNP_DSCP_P2 48
ROCE_RTT_RESP_DSCP_P1 0
ROCE_RTT_RESP_DSCP_MODE_P1 DEVICE_DEFAULT(0)
ROCE_RTT_RESP_DSCP_P2 0
ROCE_RTT_RESP_DSCP_MODE_P2 DEVICE_DEFAULT(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE True(1)
ROCE_CONTROL ROCE_ENABLE(2)
PCI_WR_ORDERING per_mkey(0)
MULTI_PORT_VHCA_EN False(0)
PF_SD_GROUP 0
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_INTERRUPT_DIS False(0)
BOOT_LACP_DIS True(1)
BOOT_VLAN_EN False(0)
IP_VER IPv4(0)
BOOT_UNDI_NETWORK_WAIT 0
BOOT_DBG_LOG False(0)
BOOT_PKEY 0
UEFI_HII_EN True(1)
UEFI_LOGS DISABLED(0)
DYNAMIC_VF_MSIX_TABLE False(0)
EXP_ROM_UEFI_ARM_ENABLE False(0)
EXP_ROM_UEFI_x86_ENABLE True(1)
EXP_ROM_PXE_ENABLE True(1)
ADVANCED_PCI_SETTINGS False(0)
SAFE_MODE_THRESHOLD 10
SAFE_MODE_ENABLE True(1)
