I was wondering if there is a way to enable WOL for the MCX311A-XCAT HCA? Right now I’m using the builtin Linux driver and ethtool only shows d as available WOL option. Do I need to use the mlnx_en driver to activate WOL?
Hello Lennart,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Please the instructions provide through the following link to enable WOL on the ConnectX-3 → https://docs.nvidia.com/networking/display/MFTv4140/MFT+Supported+Configurations+and+Parameters
The table shows the configurable parameter → WOL_MAGIC_EN_P1/P2
Install the MFT tools from our website (Mellanox Firmware Tools (MFT)) and use the ‘mlxconfig’ command to enable WOL on the ConnectX-3. → # mlxconfig -d mt4099_pci_cr0 set WOL_MAGIC_EN_P<port #>=1
After changing this setting please reboot the node to make the setting active.
Please make sure the adapter is running the latest f/w version available.
Thank you and regards,
~NVIDIA Networking Technical Support
So I just tested this, I ran mlxup to update the fw and got
sudo ./mlxup
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX3
Part Number: MCX311A-XCA_Ax
Description: ConnectX-3 EN network interface card; 10GigE; single-port SFP+; PCIe3.0 x4 8GT/s; RoHS R6
PSID: MT_1170110023
PCI Device Name: 0000:07:00.0
Port1 MAC: …
Port2 MAC: …
Versions: Current Available
FW 2.42.5000 2.42.5000
PXE 3.4.0752 3.4.0752
Status: Up to date
So seems to be up to date. however when querying mlxconfig / mstconfig for the flag, it’s not listed and attempting to set the flag, I get
sudo mstconfig -d 07:00.0 set WOL_MAGIC_EN_P1=1 3 ↵
Device #1:
Device type: ConnectX3
Device: 07:00.0
Configurations: Next Boot New
-E- Device doesn’t support WOL_MAGIC_EN_P1 configuration
sudo mstconfig -d 07:00.0 q 3 ↵
Device #1:
Device: 07:00.0
SRIOV_EN False(0)
NUM_OF_VFS 0
LOG_BAR_SIZE 0
BOOT_OPTION_ROM_EN_P1 False(0)
BOOT_VLAN_EN_P1 False(0)
BOOT_RETRY_CNT_P1 0
LEGACY_BOOT_PROTOCOL_P1 None(0)
BOOT_VLAN_P1 0
BOOT_OPTION_ROM_EN_P2 False(0)
BOOT_VLAN_EN_P2 False(0)
BOOT_RETRY_CNT_P2 0
LEGACY_BOOT_PROTOCOL_P2 None(0)
BOOT_VLAN_P2 0
IP_VER_P1 IPv4(0)
IP_VER_P2 IPv4(0)
CQ_TIMESTAMP False(0)
mlxconfig just says that it can’t query the current device configuration. So I guess my card doesn’t support WOL?
