Assistance Needed: Locating NVIDIA L4T GCC 11.3 Toolchain for Jetson Linux R36.4.3 (ARM64)
Hello NVIDIA Support/Community,
I’m working on a project using the NVIDIA Jetson Orin Nano with Jetson Linux R36.4.3 (part of JetPack 6.2) and Ubuntu 22.04, running kernel 5.15.148-tegra. My goal is to compile the pl2303.ko kernel module to enable USB-to-serial functionality (ttyUSB), but I’ve encountered issues with the PLT/GOT sections missing when using the Bootlin toolchain (aarch64–glibc–stable-2022.08-1.tar.bz2). Based on the Jetson Linux Developer Guide (version 36.4.3, updated February 25, 2025), I understand that the recommended solution is to use the NVIDIA L4T GCC 11.3 native ARM64 toolchain (l4t-gcc-11-3-aarch64.tar.xz), as it avoids emulation issues with Box64 and ensures compatibility with the kernel.
However, I’ve been unable to locate l4t-gcc-11-3-aarch64.tar.xz on the NVIDIA Jetson Linux home page (Jetson Linux | NVIDIA Developer) or the Jetson Download Center (Jetson Download Center | NVIDIA Developer). I’ve checked the “Tools” section and the Jetson Linux Developer Guide’s “Appendix T: Jetson Linux Toolchain,” but I only find references to the Bootlin toolchain or older versions. The guide mentions downloading the toolchain from the Jetson Linux home page, but the file isn’t listed explicitly.
Could you please provide:
A direct link or clear instructions on where to download l4t-gcc-11-3-aarch64.tar.xz for Jetson Linux R36.4.3.
Confirmation that this is the correct native ARM64 toolchain for compiling kernel modules like pl2303.ko on Jetson Orin Nano with JetPack 6.0.
Any additional steps or prerequisites I might have missed to ensure successful compilation and loading of the module.
I’m following the steps in the guide to extract the toolchain, set CROSS_COMPILE, and build the kernel module, but I need the correct toolchain to proceed. Any assistance or clarification would be greatly appreciated.
Thank you in advance for your help!
I don’t know if this has all you want, but this is the list of L4T releases:
https://developer.nvidia.com/linux-tegra
Within that is the L4T R36.4.3 URL:
https://developer.nvidia.com/embedded/jetson-linux-r3643
Further down in that URL I see a “TOOLS” section. This has:
Bootlin Toolchain gcc 11.3
Probably the rule of thumb is to start with the specific L4T page, and then check the downloads URL outside of that (especially for design documentation).
I have not checked if this is the native (aarch64) compiler or a cross compiler. Thus, this might run on the desktop PC and produce cross compiled code, but perhaps it is the compiler that runs natively on the Jetson itself. Give that a try and see if it is what you are looking for.
Note: Procedures change slightly between cross compile and native compile. Both work, but there are differences; the use of CROSS_COMPILE would simply go away if natively compiling. I’m thinking this is cross compile software since the tools provided are rarely native compile tools. There would also be a need to export the ARCH for cross compile, and one would never use ARCH if native compiling.
Hi linuxdev,
Thank you so much for your kind and thoughtful response—I really appreciate you taking the time to help me with this! Your pointers to the L4T releases archive (Jetson Linux Archive | NVIDIA Developer) and the Jetson Linux R36.4.3 page (Jetson Linux | NVIDIA Developer), as well as highlighting the “Bootlin Toolchain gcc 11.3” in the “TOOLS” section, have been incredibly valuable.
I’ve reviewed the information you shared, and I wanted to provide a bit more context and ask for your further insights, if possible. The “Bootlin Toolchain gcc 11.3” (aarch64–glibc–stable-2022.08-1.tar.bz2) I’ve already tried is built for x86_64, which requires Box64 emulation on my Jetson Orin Nano (ARM64) running Jetson Linux R36.4.3 (JetPack 6.2) and Ubuntu 22.04. Unfortunately, this leads to issues with missing x86_64 dependencies (e.g., /lib64/ld-linux-x86-64.so.2), causing compilation failures for the pl2303.ko kernel module natively, including missing PLT/GOT sections.
Based on the Jetson Linux Developer Guide (version 36.4.3, updated February 25, 2025), I’m specifically looking for the NVIDIA L4T GCC 11.3 native ARM64 toolchain (l4t-gcc-11-3-aarch64.tar.xz), which should run natively on the Jetson and avoid these emulation challenges. However, I haven’t been able to find this file on the URLs you provided or in the Jetson Download Center (Jetson Download Center | NVIDIA Developer). Your suggestion about checking whether it’s a cross-compiler or native compiler was spot-on, and I confirmed the Bootlin toolchain is a cross-compiler, not ideal for my needs of native compilation on the Jetson.
I’m wondering if you have any additional advice or know where I might locate the native ARM64 toolchain for Jetson Linux R36.4.3? I’m also planning to reach out to NVIDIA support for further assistance, but I’d be so grateful for any extra guidance you could offer. Your help has already made a big difference, and I’m truly thankful for your support!
The toolchain for Jetpack 6 is:
https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v3.0/toolchain/aarch64--glibc--stable-2022.08-1.tar.bz2
If should be good to build kernel image if you follow:
Kernel Customization — NVIDIA Jetson Linux Developer Guide
If you need later version of toolchain, would see if other users or community can share it.
FYI, I am pointing a URL at the actual bootlin URL, which is the same content @DaneLLL is giving. Keep reading below, but realize there will be more information at the bootlin site. I’m starting with cross tool information, but it will help with looking for native content (perhaps at the bootlin web site, but it might be elsewhere). Technically, you could skip this first part which is cross compile, but the information is rather useful in understanding the difference between cross tools and native tools. You could skip to the end for the short question list.
A lot of this is just because other people look for the same information, so verbosity is on the high side.
For background, any program which uses a linked library needs a linker and it needs the library to link against. In the case of an x86 cross compile to aarch64 this implies (A) a cross linker, and (B) the aarch64 library in a proper location to find it. If you were to clone your Jetson and then loopback mount the raw clone on the host PC, I suspect that this would contain the libraries themselves. The cross linker is likely available via an apt-get, although you might need to find the repository which has this and add it to the host PC (if you use the cross compile method). A raw clone is a very good idea even if you don’t cross compile.
Files which execute on x86_64, but produce aarch64 output will usually have a name prefix of “aarch64-something”. The file gcc is not a cross compiler, the file aarch64-linux-gcc has the same output, but from another environment. The output won’t care if you use gcc from that release or aarch64-linux-gcc.
You can look at a binary executable like this (using the unpack location for a starting point):
./objdump -f ./aarch64--glibc--stable-2022.08-1/bin/aarch64-linux-gcc
(you will see “architecture: i386:x86-64”; this is the execution environment, and the name prefix aarch64- tells you the output format)
For native compile I found someone else who uses this, and they listed the URL (this is the same content which @DaneLLL just gave the URL for, but this one is at the bootlin provider’s web site):
https://toolchains.bootlin.com/downloads/releases/toolchains/aarch64/tarballs/aarch64–glibc–stable-2022.08-1.tar.bz2
If you download and unpack that you will find a “sysroot/” subdirectory. Everything in sysroot/ is arm64/aarch64, and is what the linker would link against. Linking against a clone which has the actual files is better, although you are still in a cross compile environment. The sysroot/ is a bare bones subset of what the Jetson already has on it. If your Jetson is updated or customized, then the clone becomes a superior cross compile compared to a sysroot. Native compile and sysroot/ are the same thing if the bootlin content is a match for the libraries and linkers in the bootlin content.
The content outside of sysroot/ is used by the executables and utilities which produce aarch64, but run on x86_64. I haven’t looked at that documentation in quite some time, but basically a cross compile has a way to mention an alternate sysroot (with an environment variable for the prefix to the path), and thus you could point at either the sysroot/ of the above unpacked tool, or you could point at a loopback mounted clone for the cross compile case.
If you compile natively on the Jetson, then you should already have the correct linker for aarch64/arm64, and no cross tool is required. Even the sysroot/ is present on the actual Jetson, but it is the o/s itself (everything related to a library or linker in the sysroot/ is in “/” if going native). If something is missing, then it is either due to (A) needing a different major release version of something, or (B) needing a file to link against. The actual error you see when natively or cross compiling is important to knowing what is missing. Specific error messages can help look this up.
The trouble is that the compiler itself is of course x86_64, and not aarch64. You already have a clue though because we know this is gcc version 11. If you cd to the “aarch64--glibc--stable-2022.08-1/bin/” subdirectory of the unpack, then you can run these commands (or for any other executable):
  • ./aarch64-linux-gcc --version
  • ./aarch64-buildroot-linux-gnu-gcc --version
Both will tell you:
(Buildroot 2021.11-4428-g6b6741b) 11.3.0
The date part is only important when multiple releases are available; usually anything 11.3.0 (or even 11.x) will work, but getting actual 11.3.0 is best. When monthly builds are available, look for 2021.11. As to the actual release version (this is native from an Orin, but it is using L4T R35.x and not R36.x):
# gcc --version
gcc (Ubuntu 9.4.0-1ubuntu1~20.04.2) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
So the version is way too old under L4T R35.x. I do not have one with R36.x on it, so can you post the output on your R36.x of “gcc --version”? Also, can you attach a copy of your Orin’s file “/etc/apt/sources.list”? The goal is to find an Ubuntu repository which has what you need, and only then, if not found, move on to a native 11.3.0 (which may not exist without compiling the entire chain yourself from scratch).
