I can’t send output signal to a HDMI external monitor.
Can anybody help me please.
Thanks in advance.
nvidia-bug-report.log.gz (222.5 KB)
Thanks in advance.
You fiddled a bit too much at your config files.
Please create
/etc/X11/xorg.conf.d/01-nvidia-prime.conf
Section "OutputClass"
Identifier "AMDgpu"
MatchDriver "amdgpu"
Driver "amdgpu"
EndSection
Identifier "Nvidia-prime"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "PrimaryGPU" "Yes"
EndSection
and set your display manager to run
xrandr --setprovideroutputsource 0 1 && xrandr --auto
https://wiki.archlinux.org/index.php/NVIDIA_Optimus#Display_Managers
yes i try solve it for myself but whithout luck :-(.
For now i not have HDMI signal output.
nvidia-bug-report.log.gz (204.7 KB)
Ok, there’s a path entry missing so it can’t find the nvidia module. How did you install the driver?
BTW, which desktop environment/display manager are you using?
Desktop is MATE and display managet LightDM.
I install drivers from Parrot repository “apt install nvidia-driver”.
Please change /etc/X11/xorg.conf.d/01-nvidia-prime.conf to:
Identifier "AMDgpu"
Driver "amdgpu"
EndSection
Driver "nvidia"
Option "AllowEmptyInitialConfiguration" "true"
ModulePath "/usr/lib/nvidia/current/"
EndSection
and remove the incorrectly modified system config files
/usr/share/X11/xorg.conf.d/10-amdgpu.conf
/usr/share/X11/xorg.conf.d/10-nvidia.conf
so they don’t interfere.
I’ve modified /etc/X11/xorg.conf.d/01-nvidia-prime.conf , remove /usr/share/X11/xorg.conf.d/10-amdgpu.conf and
/usr/share/X11/xorg.conf.d/10-nvidia.conf and rebooted de system but still not have signal output on HDMI.
Any other config that can try?
nvidia-bug-report.log.gz (203.6 KB)
The X config is correct now. There’s one kernel module missing, it only loads
nvidia.ko
nvidia-modeset.ko
missing is
nvidia-drm.ko
Please check if it exist by running
modinfo nvidia-drm
and check if it’s blacklisted
grep “nvidia-drm” /etc/modprobe.d/* /lib/modprobe.d/*
