Ok try the following:
sudo (text_editor) /usr/share/X11/xorg.conf.d/10-amdgpu.conf
Section “OutputClass”
Identifier “AMDgpu”
MatchDriver “amdgpu”
Driver “modesetting”
EndSection
sudo (text_editor) /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
Identifier “nvidia”
MatchDriver “nvidia-drm”
Driver “nvidia”
Option “AllowEmptyInitialConfiguration”
ModulePath “/usr/lib/nvidia/xorg”
ModulePath “/usr/lib/xorg/modules”
Option “PrimaryGPU” “Yes”
EndSection
Make sure no other config files interfere (in /etc/X11 or /usr/share/X11).
Display managers (choose yours):
LightDM
create /etc/lightdm/display_setup.sh
#!/bin/sh
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
Make the script executable:
chmod +x /etc/lightdm/display_setup.sh
Now configure lightdm to run the script by editing the [Seat:*] section in /etc/lightdm/lightdm.conf :
[Seat:*] display-setup-script=/etc/lightdm/display_setup.sh
Now reboot and your display manager should start.
If your display dpi is not correct add the following line (applies also to the other display managers):
xrandr --dpi 96
SDDM
/usr/share/sddm/scripts/Xsetup
xrandr --setprovideroutputsource modesetting NVIDIA-0; xrandr --auto
GDM
/usr/share/gdm/greeter/autostart/optimus.desktop /etc/xdg/autostart/optimus.desktop
[Desktop Entry]
Type=Application
Name=Optimus
Exec=sh -c "xrandr --setprovideroutputsource modesetting NVIDIA-0; xrandr --auto"
NoDisplay=true
X-GNOME-Autostart-Phase=DisplayServer
Make sure that GDM use X as default backend.
Enable prime synchronisation
edit or create: /etc/modprobe.d/nvidia.conf:
add:
options nvidia-drm modeset=1
Blacklist nouveau:
sudo bash -c "echo blacklist nouveau > /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
sudo bash -c "echo options nouveau modeset=0 >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf"
Update initramfs:
sudo update-initramfs -u -k all
Reboot.
