i have a Rezer Blade 15 Laptop which is running the newest driver for it (Linux x64 Display Driver Version 430.50) as recommended by NVIDIA. Unfortunately i cant connect a external monitor and it seems like the computer doesnt know that i got:
- 1x Displayport,
1x HDMI,
1x USB-C with Thunderbold 3 and
3x USB-A ports.
GPU: GTX 1060 Max-Q Design
OS: Ubuntu 19.04
Monitor: LG 24MB67PY (works perfectly with other Devices)
Here is the Outout of xrandr:
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
As you can see there are beside the eDP-1 there are only two other ports.
Log report created with
sudo nvidia-bug-report.sh
nvidia-bug-report.log.gz (80.6 KB)
The nvidia driver is not loaded.
Please try this:
- install nvidia-prime (sudo apt install nvidia-prime)
- switch to nvidia (sudo prime-select nvidia)
- remove stray blacklist files (sudo rm /lib/modprobe.d/blacklist-nvidia.conf /etc/modprobe.d/blacklist-nvidia.conf)
- update the initrd (sudo update-initramfs -u)
- reboot
Maybe i did something wrong but when i type in the 3rd command
the terminal responds this:
rm: cannot remove '/lib/modprobe.d/blacklist-nvidia.conf': No such file or directory
rm: cannot remove '/etc/modprobe.d/blacklist-nvidia.conf': No such file or directory
after this, i typed in the other commands correctly and rebootet my laptop but there where no changes. Should i attach a new nvidia-bug report maybe?
Thank you for you help :)
You have secure boot enabled, so the nvidia driver doesn’t load. Please disable secure boot in bios.
IT WORKS!!! Thank you a lot! In the past 7 days i read posts in aproximately 30 forums and tried everything but nothing worked for me. Again thanks a lot, this is very important for me.
