HDMI output missing in xrandr command and external monitor does not work
i use nvidia driver 410.78 instaled by repository ppa:graphics-drivers/ppa on my ubuntu 18.04.1 fresh install, everything works fine. Few days a go, i don’t know exactly what happend (maybe system updates, i make nothing with system) driver is broken. It is mean external monitor does not work. Does not detect HDMI output.
$ xrandr | grep ’ connected’
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
All output xrandr
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-3 disconnected (normal left inverted right x axis y axis)
Here is missing “HDMI-1-4”
I uninstall nvidia driver and default nouveau use Intel HD Graphics 630 (Kaby Lake GT2) and external monitor works fine.
eDP-1 connected 1920x1080+0+2160 (normal left inverted right x axis y axis) 344mm x 194mm
HDMI-1-4 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
I use nvidia-config and it makes nothing.
GPU: GP106M [GeForce GTX 1060 Mobile]
OS: Ubuntu 18.04
Monitor: 4K LG 27UD69, HDMI cable 2.0
Log report generated by
sudo nvidia-bug-report.sh --safe-mode --extra-system-data
nvidia-bug-report-safe-mode-and-extra-data.log.gz (90.4 KB)
nvidia-bug-report.log.gz (1.03 MB)
That log is truncated and flooded with errors, not really useful. Please reboot, create a new log, then attach it as file. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
Thank you for answer. I added files to first post
That’s rather odd, the monitor is detected but not used.
Two things to try:
run
xrandr --setprovideroutputsource modesetting NVIDIA-0 && xrandr --auto
and see if the external monitor comes alive. If not, run
grep modeset /etc/modprobe.d/*
and
grep modeset /lib/modprobe.d/*
to find the file containing
options nvidia-drm modeset=1
and change it to
options nvidia-drm modeset=0
then run
sudo update-initramfs -u
and reboot, then check if the external monitor works.
First command make nothing
Second way works
here is nothing
and here
$ grep modeset /lib/modprobe.d/*
/lib/modprobe.d/nvidia-kms.conf
$ sudo update-initramfs -u
$ sudo reboot
external monitor works :)
Thank you
