My HDMI monitor is detected in Displays but no output is appearing on the monitor. When i navigate to displays i can clearly see the external monitor is detected.
I’m running nvidia-driver-415:
➜ ~ ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001C20sv00001558sd000095E1bc03sc00i00
vendor : NVIDIA Corporation
model : GP106M [GeForce GTX 1060 Mobile]
driver : nvidia-driver-396 - third-party free
driver : nvidia-driver-410 - third-party free
driver : nvidia-driver-415 - third-party free recommended
driver : nvidia-driver-390 - third-party free
driver : xserver-xorg-video-nouveau - distro free builtin
== /sys/devices/pci0000:00/0000:00:1f.3 ==
modalias : pci:v00008086d0000A348sv00001558sd000095E1bc04sc03i00
vendor : Intel Corporation
driver : oem-audio-hda-daily-dkms - third-party free
Output of dmesg:
➜ ~ dmesg | grep -i nvidia
[ 13.073232] nvidia: module license 'NVIDIA' taints kernel.
[ 13.085273] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 13.085526] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[ 13.085625] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 13.184989] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 415.25 Wed Dec 12 10:22:08 CST 2018 (using threaded interrupts)
[ 13.194597] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 415.25 Wed Dec 12 10:02:42 CST 2018
[ 13.197097] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 15.457134] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 15.477130] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 237
Output of xrandr:
➜ ~ xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
XWAYLAND0 connected 1920x1080+0+0 (0x22) normal (normal left inverted right x axis y axis) 340mm x 190mm
Identifier: 0x21
Timestamp: 24171
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 0.0
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
1920x1080 (0x22) 173.000MHz -HSync +VSync *current +preferred
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
I have tried modifying
sudo nano /lib/modprobe.d/nvidia-kms.conf
by setting
options nvidia-drm modeset=0
but this had no effect so i set it back to
options nvidia-drm modeset=1
Is there anything else i can try?
