Ubuntu 18.04.3 hdmi external monitor problem. nvidia-driver-430.
I have problems connecting my external monitor with Ubuntu 18.04.3. Basically the external screen is just black. I’m using the nvidia-driver-430. I tried to switch to lightdm, but it didn’t solve the problem.
Here are some of my settings:
~$ ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 ==
modalias : pci:v000010DEd00001F10sv00001028sd0000093Bbc03sc00i00
vendor   : NVIDIA Corporation
driver   : nvidia-driver-430 - distro non-free recommended
driver   : xserver-xorg-video-nouveau - distro free builtin
~$ dmesg | grep -i nvidia
[    2.293097] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
[   40.950370] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input28
[   40.950506] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input29
~$ xrandr
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 8192 x 8192
eDP-1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   3840x2160     60.00*+  59.98    59.97
   3200x1800     59.96    59.94
   2880x1620     59.96    59.97
   2560x1600     59.99    59.97
   2560x1440     59.99    59.99    59.96    59.95
   2048x1536     60.00
   1920x1440     60.00
   1856x1392     60.01
   1792x1344     60.01
   2048x1152     59.99    59.98    59.90    59.91
   1920x1200     59.88    59.95
   1920x1080     60.01    59.97    59.96    59.93
   1600x1200     60.00
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      59.99    59.94    59.95    59.82
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1280x800      59.99    59.97    59.81    59.91
   1152x864      60.00
   1280x720      60.00    59.99    59.86    59.74
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   1024x576      59.95    59.96    59.90    59.82
   960x600       59.93    60.00
   960x540       59.96    59.99    59.63    59.82
   800x600       60.00    60.32    56.25
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   640x360       59.86    59.83    59.84    59.32
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
Note that HDMI-1 and HDMI-2 seems to be disconnected when I ran the command xrandr above.
Many thanks if you have any suggestions how to solve this!
Kind regards
nvidia-bug-report.log.gz (91.2 KB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
[url]https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/[/url]
Thanks, I have now uploaded my bug-report in my previous message.
Ok, please try this:
  • install nvidia-prime (sudo apt install nvidia-prime)
  • switch to nvidia (sudo prime-select nvidia)
  • remove stray blacklist files (sudo rm /lib/modprobe.d/blacklist-nvidia.conf /etc/modprobe.d/blacklist-nvidia.conf)
  • update the initrd (sudo update-initramfs -u)
  • reboot
There is no difference and my external monitor is still black. In Ubuntu Displays it’s not possible to see the external monitor.
I don’t have the blacklist files you mention above so I couldn’t remove them.
I include my latest bug-report.
Thanks for your help!
nvidia-bug-report.log.gz (90.9 KB)
You have secure boot enabled so the nvidia driver can’t be loaded. Please disable secure boot in bios.
Thanks a lot! Disabling secure boot in bios solved the problem.
All the best.
