Audio video sync from RTSP source
Jetson Xavier NX + ConnectTech Quark
• DeepStream Version
6.0
4.6
Questions
Our goal is to get audio and video from 1 RTSP input source and get them synchronized.
Audio signal will come in. At that exact point, we want to grab the frame with same/similar timestamp.
And for 2 seconds after that point, we want to collect frames.
• What we are referencing and how we are testing
  1. We set it up so we know we get synchronized stream (AV) - https://docs.nvidia.com/metropolis/deepstream/dev-guide/_static/Nvidia.ico)AV Sync in DeepStream — DeepStream 6.0.1 Release documentation](AV Sync in DeepStream — DeepStream 6.1.1 Release documentation
  2. After that we receive receive an audio signal, we grab the frame with signal because that is the exact one that had audio signal change.
  3. Since we are using Python version, we can’t get NTP timestamp (since configure_source_for_ntp_sync function isn’t available). But we can assign system time as ntp using #1 method shown in this doc - NTP Timestamp in DeepStream — DeepStream 6.1.1 Release documentation
  4. We then grab that image as 1st reference. And start saving, we wait until we get the frame whose timestamp is triggered_timestamp + 2 sec
• Question
  • We want to understand if #1 above allows us to synchronize the sound and the video. In the doc, we saw a sample pipeline (AV Sync in DeepStream — DeepStream 6.1.1 Release documentation) but it seemed like it was grabbing 2 RTSP streams and creating 1 output. In our case, we are looking to get audio and video from 1 RTSP source, and make sure that we grab/find the right frame based on the time we received the audio signal
  • We tried a few things, but we seem be not getting the result we want, so we wanted to see if the community can provide some feedback/guidance.
Thank you
What do you mean? The video and audio in the same rtsp stream is already AV sync. Why do you want to do it again? And where you want to do this?
