Does deepstream gst-nvstreamux uses ntp timestamp for multiple input streams synchronization?
In deepstream gst-nvstreammux the sync-inputs property inside the property table is defined as “Boolean property to sychronization of input frames using PTS”.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvstreammux.html
and in the new streammux documentation, it defines it as "Synchronize Inputs. Boolean property to force timestamp sychronization of input frames.".
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvstreammux2.html
does the new gst-nvstreammux uses the RTCP NTP timestamp for synchronizing the frames from multiple RTSP streams or the PTS time?
• DeepStream Version
• TensorRT Version
Thank you for your answer, it is not actually an issue, just a question.
I want to know how sync-inputs property actually works, does it use RTCP ntp timestamp for synchronization or the PTS timestamp?
We are using deepstream 7, on Jetson Orin, or dGPU.
Hardware Platform (Jetson / GPU) Jetson Orin-nano
DeepStream Version DS v7.1
JetPack Version (valid for Jetson only)
TensorRT Version 8.6.2.3-1+cuda12.2
Issue Type( questions, new requirements, bugs) questions
No, RTCP ntp timestamp is added into meta for custom use. you can get ntp_timestamp in frame meta.
please refer to the doc above. you will get some explanations after finding “sync-inputs”.
new sterammux plugin and low-level are opensource. please refer to synchronize_buffers_in_pad. the “sync-inputs” mechanism will remove and skip late buffer.
