This release of A2F 2022.2 running on kit 104.1 brings audio2face to Linux. In addition, a headless mode with a REST api supports a more efficient processing pipeline and export of a large quantity of processed A2F files. Plus, many other improvements to tools found within the a2f application are listed below.
Linux Support
Audio2Face and all its features are now fully supported in a Linux application.
Headless Mode and Rest API
Headless Audio2face supports advanced batch export capabilities by exposing a robust REST api enabling deeper integration into production pipelines.
Multi Blendshape Solve node support
A new solution and interface to allow multiple Blendshape solves and Batch exporting.
Additional updates and features.
Deformer UI - A new UI to allow some high-level management of the deformers employed in a stage.
Warp 0.6.1 - Added support for Cuda Streams and Cuda Events and warp.dll update to Cuda Toolkit 11.5
Mesh correspondence display update - Improved rendering of Point Tags with color and numerical indicators to easily find the tag you are looking for.
CharTransfer head template - A new Default charTransfer head template that closely matches the full-face default.
BlendShape Generation - Now includes the option of ARKit blendshape generator.
Pipeline - Default fields for A2F full face pipeline connections.
Fix - Resolved Hotkeys conflict with default kit hotkeys fixes.
Fix - Mesh separate UV fixes and better mesh handling.
Add - Added undo support for tools.
Fix - Improved Audio file path handling.
Fix - USD Exporter fix.
Fix - Mesh Stamp UV fix.
