Sounds great, I will wait then, thank you.
Hello Dev-Team,
I’m chiming in to report that I’m facing the exact same problem as @SuperMaximus here: when trying to package a UE project with Omniverse LiveLink enabled, I’m hitting a brick wall with the error “Expecting to find a type to be declared in a module rules named ‘OmniverseAudioMixer’ in UE5Rules.”
Despite following Nvidia’s guide (Audio2Face to UE Live Link Plugin — Omniverse Audio2Face latest documentation) to the letter and following your suggested changes It does not work.(didn’t have to change anything, my .uplugin file looks exactly the same as shown by @SuperMaximus)
I’m reaching out in the hopes that someone from the dev team, or anyone who has navigated through this, could provide some insight or a possible solution. Any help would be deeply valued.
(Edit) In the Log: this Exception is get thrown:
Enabling plugin 'OpenColorIO' (referenced via MetaHumans.uproject -> MovieRenderPipeline.uplugin)
Enabling plugin 'OmniverseLiveLink' (referenced via MetaHumans.uproject)
Expecting to find a type to be declared in a module rules named 'OmniverseAudioMixer' in UE5Rules, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null. This type must derive from the 'ModuleRules' type defined by Unreal Build Tool.
BuildException: Expecting to find a type to be declared in a module rules named 'OmniverseAudioMixer' in UE5Rules, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null. This type must derive from the 'ModuleRules' type defined by Unreal Build Tool.
at UnrealBuildTool.RulesAssembly.CreateModuleRules(String ModuleName, ReadOnlyTargetRules Target, String ReferenceChain, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\System\RulesAssembly.cs:line 476
at UnrealBuildTool.RulesAssembly.CreateModuleRules(String ModuleName, ReadOnlyTargetRules Target, String ReferenceChain, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\System\RulesAssembly.cs:line 408
at UnrealBuildTool.UEBuildTarget.CreateModuleRulesAndSetDefaults(String ModuleName, String ReferenceChain, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 4803
at UnrealBuildTool.UEBuildTarget.FindOrCreateModuleByName(String ModuleName, String ReferenceChain, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 4927
at UnrealBuildTool.UEBuildTarget.FindOrCreateCppModuleByName(String ModuleName, String ReferenceChain, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 5064
at UnrealBuildTool.UEBuildTarget.AddPlugin(PluginReferenceDescriptor Reference, String ReferenceChain, String[] ExcludeFolders, Dictionary`2 NameToInstance, Dictionary`2 NameToInfos, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 4133
at UnrealBuildTool.UEBuildTarget.SetupPlugins(ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 3925
at UnrealBuildTool.UEBuildTarget.PreBuildSetup(ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 3138
at UnrealBuildTool.UEBuildTarget.Create(TargetDescriptor Descriptor, Boolean bSkipRulesCompile, Boolean bForceRulesCompile, Boolean bUsePrecompiled, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Configuration\UEBuildTarget.cs:line 1301
at UnrealBuildTool.BuildMode.CreateMakefile(BuildConfiguration BuildConfiguration, TargetDescriptor TargetDescriptor, ISourceFileWorkingSet WorkingSet, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Modes\BuildMode.cs:line 866
at UnrealBuildTool.BuildMode.Build(List`1 TargetDescriptors, BuildConfiguration BuildConfiguration, ISourceFileWorkingSet WorkingSet, BuildOptions Options, FileReference WriteOutdatedActionsFile, ILogger Logger, Boolean bSkipPreBuildTargets) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Modes\BuildMode.cs:line 392
at UnrealBuildTool.BuildMode.Execute(CommandLineArguments Arguments, ILogger Logger) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\Modes\BuildMode.cs:line 248
at UnrealBuildTool.UnrealBuildTool.Main(String[] ArgumentsArray) in D:\build\++UE5\Sync\Engine\Saved\CsTools\Engine\Source\Programs\UnrealBuildTool\UnrealBuildTool.cs:line 599
WriteFileIfChanged() wrote 0 changed files of 0 requested writes.
Timeline:
From our engineering team:
That error is what the engine says if you installed the plugin to the wrong folder.
If you have a packaged engine installed through the Epic Games Launcher, downloaded engine plugins must be installed under Engine\Plugins\Marketplace. If you try to install it somewhere else (like under Engine\Plugins\Runtime for example), then packaging will fail with this weird error message Expecting to find a type to be declared in a module rules...
Hmmm, do you have some step by step guide, how to compile it?
