• Hardware Platform (Jetson / GPU) x86 RTX-3060
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only) 525.125.06
• Issue Type( questions, new requirements, bugs) questions
I have a specific requirement to modify the existing deepstream-app in order to skip or avoid inference for pgie element for specific stream ID this is because in one of the use-case i don’t need primary detector to generate bounding boxes instead pre-defined ROI will be used and in follow-up to this sgie will be used as a secondary classifier, however this can be easily achieved by implementing a separate app and mimicking pgie as a dummy element but i want a single pipeline solution which deals with multiple RTSP streams, out of which few stream’s will work with regular pipeline elements like pgie(detector) -> Tracker -> sgie(classifier) but other streams don’t require pgie as mentioned earlier , one solution that i tried by directly appending the ROI as a desired bounding boxes in the custom post-processing function and the pipeline does the rest as below,
static std::vector<NvDsInferParseObjectInfo> decodeYoloTensor(const int* num_dets,
const float* bboxes,
const float* scores,
const int* labels,
const unsigned int& img_w,
const unsigned int& img_h)
std::vector<NvDsInferParseObjectInfo> bboxInfo;
size_t nums = num_dets[0];
for (size_t i = 0; i < nums; i++) {
/* extract the bbox from object detected from output layer of the pgie network model and append it to bboxInfo*/
if(asset_roi_cord && shm_fd > 0)
// Process the list of structs as needed
roi_len = asset_roi_cord->roi_len;
for (int i = 0; i < roi_len; i++) {
NvDsInferParseObjectInfo obj;
obj.left = asset_roi_cord->roi[i * 4];
obj.top = asset_roi_cord->roi[i * 4 + 1];
obj.width = asset_roi_cord->roi[i * 4 + 2];
obj.height = asset_roi_cord->roi[i * 4 + 3];
obj.classId = 9;
bboxInfo.push_back(obj);
return bboxInfo;
but in this case i don’t want to add additional unnecessary toll in latency for pgie element , so as a quick work around i was thinking to some how skip primary inference for given stream ID in gstnvinfer.cpp code, but i don’t know how to do these changes in order to handle with multiple batch scenario which is often a case while dealing with multiple streams.
So what could be the possible work around for this issue.
Thank you.
