Hi, I applied to the Maxine SDK Early Access program around 11 weeks ago, however the application has still not been reviewed. Is the application process dead?
Hello @antonio,
Welcome to the NVIDIA Developer forums. Someone from the Maxine team will be here to help you ASAP.
Regards,
Tom K
Hi @antonio12,
I'll drop you a message directly. The SDKs are available without early access for many Maxine capabilities. Just being logged into the developer site will give you access to Maxine SDKs. Our early access process is for pre-release capabilities and is mostly focused on getting feedback from partners about pre-release SDKs.
Hello. I’ve also been waiting a while (~1 month) to join the SDK Early Access program. Any idea on how long the queue is/whether I’ll ever get access?
Which SDK early access have you applied for, if its Maxine it is now available without EA access, in which case your application may not be processed.
