Hey Dusty,
So I launched the container on the nano and input:
‘video-viewer csi://0 rtp://<MY HOST PC’S IP>:1234’
from within the container. The terminal began “capturing” frames and a video window popped up. I then unplugged my hdmi cord from my nano and plugged that into my PC. I opened a terminal window and ssh’d into my nano-no problem there. I then input:
" video-viewer csi://0 rtp://:1234"
and I got this error:
“-bash: video-viewer: command not found”
Should I have contacted the nano’s IP address? If the stream is running on the nano and all I did was swap out the cable I’m confused why I wouldn’t be able to see the same frames being captured now over ssh on my host machine. Obviously I’m doing something wrong still?
I also tried to input the gstreamer launch command from the documentation in a different terminal window that I hadn’t ssh’d into. I got this output:
"gst-launch-1.0 -v udpsrc port=1234 \
caps = “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96” !
rtph264depay ! decodebin ! videoconvert ! autovideosink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000a6742402895a014016e4001000468ce3c80, level=(string)4, profile=(string)constrained-baseline
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000a6742402895a014016e4001000468ce3c80, level=(string)4, profile=(string)constrained-baseline
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000a6742402895a014016e4001000468ce3c80, level=(string)4, profile=(string)constrained-baseline
Missing element: H.264 (Constrained Baseline Profile) decoder
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0: Your GStreamer installation is missing a plug-in.
Additional debug info:
gstdecodebin2.c(4679): gst_decode_bin_expose (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0:
no suitable plugins found:
Missing decoder: H.264 (Constrained Baseline Profile) (video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000a6742402895a014016e4001000468ce3c80, level=(string)4, profile=(string)constrained-baseline)
Execution ended after 0:00:01.074374442
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Are the “missing decoder” lines relevant? Are these two separate problems or are they linked? Thanks again for your patience…
