SSH into the NANO via WiFI (works fine)
Transmit RTP : video-viewer /dev/video0 rtp://pc_ip_address:1234 (works fine)
I then open a new terminal on my laptop to View RTP remotely : I run the GStreamer command jetson-inference/aux-streaming.md at master · dusty-nv/jetson-inference · GitHub
$ gst-launch-1.0 -v udpsrc port=1234
caps = “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96” !
rtph264depay ! decodebin ! videoconvert ! autovideosink
And no video pops up:
This is the message I get in terminal
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
Setting pipeline to PLAYING …
New clock: GstSystemClock
@nanoAI since that video was created, I have also added WebRTC support for streaming video directly to/from web browsers (hopefully this is easier to use than RTP)
Those commands to start WebRTC are run on your Jetson, and then you can navigate your browser to your Jetson’s IP address at the port you are running WebRTC on (as shown in the docs)
I ran this command by SSH into the jetson nano
video-viewer /dev/video0 webrtc://@:8554/my_output , and its running fine , I am getting text from terminal that frames are being captured.
I opened up another terminal in the jetson nano by doing another SSH and ran this command:
video-viewer webrtc://@:8554/my_input webrtc://@:8554/my_output
And got this error message
[OpenGL] failed to open X11 server connection.
[OpenGL] failed to create X11 Window.
[gstreamer] gstDecoder::Capture() – a timeout occurred waiting for the next image buffer
@nanoAI this is normal, the WebRTC /my_input stream is waiting for a client browser to connect and send their camera to it
What I would recommend, is trying video-viewer /dev/video0 webrtc://@:8554/my_output first, and navigate your browser to http://<JETSON-IP>:8554 (or use https instead if you have enabled SSL keys)
