Hello everyone.
I’m trying to follow the directions in this video (Jetson AI Fundamentals - S3E1 - Hello AI World Setup - YouTube) to stream my webcam (connected to jetson nano) on rtp.
I have followed a lot of directions on this forum but have not solved my problem.
After giving the following command (on the jetson nano):
$ video-viewer --bitrate = 1000000 csi: // 0 rtp: //192.168.1.53: 1234
streaming seems to start.
Now, I move to my macbook to be able to view the content on the rtp, using VLC, creating an .sdp file with the following parameters:
c = IN IP4 127.0.0.1
m = video 1234 RTP / AVP 96
a = rtpmap: 96 H264 / 90000
Unfortunately when I go to open this file nothing happens.
I tried to put the broadcast ip too but nothing happens.
Hello. Thanks for the reply but unfortunately setting the port to 51372 did not solve the problem.
Specifically, the commands I have given are the following:
On the nano jetson:
video-viewer --bitrate = 1000000 csi: // 0 rtp: //192.168.1.53: 51372
or:
video-viewer / dev / video1 rtp: //192.168.1.53: 51372
VLC configuration file on the macbook:
m = video 51372 RTP / AVP 96
UPDATE: I was able to stream a video between two different computers with VLC on both devices (via rtp). I have selected the broadcast address and port 5004. Unfortunately, if I run the video-viewer with the same parameters, nothing happens.
Do you have any ideas?
Hi @forflafor, can you confirm the video-video command that you are running? Please use <code></code> tags to avoid formatting issues with the web browser.
Yes. The command is as follows: $ video-viewer csi://0 rtp://192.168.216.255:5004
I tried to run GStreamer with the same command reported in the guide: gst-launch-1.0 -v udpsrc port=5004
caps = “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96” !
rtph264depay ! decodebin ! videoconvert ! autovideosink
Now when I run this command: gst-launch-1.0 -v udpsrc port=5005 \
everything stands still with the following output:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Got context from element ‘autovideosink0’: gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)“(GstGLDisplayCocoa)\ gldisplaycocoa0”;
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
/GstPipeline:pipeline0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96
New clock: GstSystemClock
After giving the command, frame acquisition starts correctly but my PC terminal is blocked showing me the following message:
SOLVED: the solution is based on giving the following commands:
On the jetson nano:
streaming from csi camera: video-viewer csi://0 rtp://192.168.1.53:5005
or streaming from USB camera: video-viewer /dev/video1 rtp://192.168.1.53:5005
