I’m trying to cross-compile Fortran code on a system without any GPU and CUDA installation to run on another system with GPUs. As far as I understand, this should be easily done e.g. by
nvfortran -mp=gpu -gpu=cc80 test.f90
or -acc=gpu
for OpenACC, and so on. I am using the nvhpc
module of the Nvidia HPC SDK, version 24.9. I have also set CUDA_HOME
to point to the cuda
directory therein. However, the compilation fails with
nvfortran-Error-A CUDA toolkit matching the current driver version (0) or a supported older version (11.8) was not installed with this HPC SDK.
It makes sense that no CUDA driver is found, since none is installed. But this shouldn’t matter for cross-compilation, shouldn’t it?
What am I missing out on here? As far as I understand, there is no additional flag required for cross compilation.
Regards,
Christian
