As a beginner in using the Modulus framework, I tried to follow the initial code given in the following link:
https://docs.nvidia.com/deeplearning/modulus/user_guide/notebook/notebook.html
In order to learn, I tried to change the existing code in order to solve the equation of the form u__x__x = x with boundary conditions (BC):
u(0) = 0 and u(2)=1, where x in [0, 2]. Considering that the analytical solution of this equation is u = x*(x^2-1)/6, unfortunately, I did not get even an approximate result using Modulus.
In order to set the appropriate BC, I made the following change:
from modulus.domain.constraint import PointwiseBoundaryConstraint, PointwiseInteriorConstraint
bcs
bc = PointwiseBoundaryConstraint(
nodes=nodes,
geometry=geo,
outvar={“in”: (0, 1)},
batch_size=2,
domain.add_constraint(bc, “bc”)
Considering that I don’t have a good results, can the BC conditions: u(x=0) = 0 and u(x=2) = 1 be set with outvar={“u”: (0, 1)}?
Result is shown below:
Thanks in advance.
