I’m trying to implement this PDE class and I’m having some difficulties, am I doing something wrong?
At the PointwiseInteriorConstraint I get the error: ValueError: C order implies last dim (1) == len(args) (2)
error:
I need the initial condition T(4,1) = 0 and I am not successful
how the network was set
I would be grateful if someone could help me.
Hi @caio.leao
I’m not sure what is causing that error you’re getting. I was not able to reproduce it on my end. However there are a few issues. The first is that the Rectangle geometry object returns x,y, so your ‘z’ variable in your PDE and model won’t be provided. This would cause a graph unrolling error. The fix is simply changing z to y.
The second issue is that in your PointwiseInteriorConstraint you don’t provide a v variable which will also cause a graph unrolling error. Your PDE can’t be calculated without it. To fix this I added v as a parameterized variable.
I created a simple script to test on my end and seems it works fine on my end:
class Eikonal(PDE):
name = "Eikonal"
def __init__(self, T="T", v="v"):
self.T = T
x, y = Symbol('x'), Symbol('y')
input_variables = {"x": x, "y": y}
T = Function(T)(*input_variables)
v = Function(v)(*input_variables)
self.equations = {}
self.equations['Eikonal'] = ((T.diff(x))**2 + (T.diff(y))**2 + (1/v)**2)
@modulus.sym.main(config_path="conf", config_name="config")
def run(cfg: ModulusConfig) -> None:
# make list of nodes to unroll graph on
pde = Eikonal( T="T", v="v")
model = instantiate_arch(
input_keys=[Key("x"), Key("y")],
output_keys=[Key("T")],
cfg=cfg.arch.fully_connected,
nodes = pde.make_nodes() + [model.make_node(name="my_network")]
dLen = 6
rec = Rectangle((0,0), (dLen, dLen))
# add constraints to solver
# make geometry
x, y = Symbol("x"), Symbol("y")
v = Symbol("v")
interior = PointwiseInteriorConstraint(
nodes=nodes,
geometry=rec,
outvar={"Eikonal": 0},
batch_size=128,
parameterization={v: 0}
# ..... more code here
if __name__ == "__main__":
run()
@ngeneva
Dear @ngenevam I’m really grateful for help me with the code, now it is working. However, I would like to ask for another question. Looking in the documentation, I can’t find a good way to make a point restriction on data in two dimensions of two dimensions. I mean, in this case I need T(x,y) to be like this T(4,1) = (0,0). I looked at the criteria but it refers to boundary conditions my problem has no border. I tried this way but I was not successful,
font = PointwiseInteriorConstraint(
nodes = nodes,
geometry = rec,
outvar={"T":0.0},
batch_size = 1,
parameterization= {x:1 , y:4 },
domain.add_constraint(font,"font_position")
or more easy T = 0 for v = 0 using PointwiseConstraint.from_numpy
Could you help me with this?
Hi @caio.leao
Yes, unfortunately we don’t have a 2D point primitive as far as I know. You could try a few things.
Define the input/ output training points for this constraint manually via numpy dictionaries. (See this thread and embedded links). This is probably what I would recommend the most.
Use the criteria to create a small bounding box around the point of interest.
A hacky approach would be to use a 1D point geometry for the x dimension and then parameterize the y variable like what you have here.
Another option I would try is to create a 2D circle geometry with a really small radius so its approximately a point.
@ngeneva
Thanks. I was able to run successfully after the previous suggestion using PointwiseConstraint.from_numpy. I’ll try the other two suggestions as I need to vary this initial condition. A suggestion for Nvidia is to generate the direct possibility of entering these point restriction conditions
