I got the image2D creation steps to work by choosing RGBA. It calls the kernel, but it doesn’t seem to be doing anything.
I create the output image using one of the following:
// outputImage = clCreateImage2D(context, CL_MEM_WRITE_ONLY, &imageFormat, pOutImage->width, pOutImage->height, 0, NULL, &err);
outputImage = clCreateImage2D(context, CL_MEM_WRITE_ONLY | CL_MEM_USE_HOST_PTR, &imageFormat, pOutImage->width, pOutImage->height, pOutImage->stride, pOutImage->image, &err);
if (err != CL_SUCCESS) {
printf(“Error creating output image rc=%d\n”,err);
rc=11;
goto cleanup;
I enqueue the kernel with the following code:
// since I am not trying to share stuff between work items in the work group,
// we can just pass in NULL and let OpenCL divide stuff up
globalSizes[0]=pInImage->width;
globalSizes[1]=pInImage->height;
err = clEnqueueNDRangeKernel(commands, kernel, 2, NULL, globalSizes, NULL, 0, NULL, NULL);
printf("Error Enqueueing Kernel rc=%d\n",err);
rc=14;
goto cleanup;
I use the following Kernel, which should set the output image to a solid color (not black).
const sampler_t kernelSampler = CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP | CLK_FILTER_NEAREST;
__kernel void kernelFunc(__read_only image2d_t inImage, __write_only image2d_t outImage,
int width, int height, int stride, int bpp)
size_t id = get_global_id(0);
int x,y;
int2 pos;
uint4 pixel;
x = id % width;
y = id / width;
if (y >= height)
y=0;
pos.x = x;
pos.y = y;
/* pixel = read_imageui(inImage, kernelSampler, pos); */
pixel.x = 128;
pixel.y = 128;
pixel.z = 64;
pixel.w = 255;
write_imageui(outImage, pos, pixel);
return;
If I don’t use CL_MEM_*_PTR when creating the output image, then I get a black image.
If I do use CL_MEM*_PTR when creating the output image, then I get the original contents of the output image (from host memory).
Any suggestions?
Dean
