OpenCL Driver BUG? clEnqueueReadImage fails to copy data from Image Object
I have written a code snippet that simply allocates an Image Object, launches a kernel to save global thread ID values into this Image object. clEnqueueReadImage gives me all values zeros.
If I use a buffer object instead, I get right results.
Here is the code snippet
// utilities, system and OpenCL includes
#include <oclUtils.h>
//#define USE_BUFFER
// OpenCL Stuff
cl_int ciErrNum;			        // Error code var
cl_platform_id cpPlatform;          // OpenCL platform
cl_device_id* cdDevices = NULL;		// device list
cl_uint uiTargetDevice = 0;	        // Default Device to compute on
cl_context cxGPUContext;				// OpenCL context
cl_command_queue cqCommandQueue;		// OpenCL command queue
cl_uint uiNumDevsUsed = 1;			// Number of devices used in this sample
cl_program cpProgram;						// OpenCL program
char* cPathAndName = NULL;			// var for full paths to data, src, etc.
const char* clSourcefile = "kernels.cl";  // OpenCL kernel source file
size_t szKernelLength;			    // Byte size of kernel code
char* cSourceCL = NULL;				// Buffer to hold source for compilation
void initData(unsigned char *in, int rows, int cols)
	int size  = rows * cols;
	for ( int i = 0; i < size; i++)
		in[i] = (unsigned char) (rand() * 10.0f / (float)RAND_MAX);
void initDataInt(unsigned int *in, int rows, int cols)
void displayImage(unsigned char *in, int rows, int cols)
	for ( int i = 0; i < rows; i++)
		for ( int j = 0; j < cols; j++)
			printf("%d ", in[ i * cols + j ]);
		printf("\n");
	printf("\n");
void displayImageInt(unsigned int *in, int rows, int cols)
		printf("\n");
	printf("\n");
size_t DivUp(size_t dividend, size_t divisor)
	return (dividend % divisor == 0) ? (dividend / divisor) : (dividend / divisor + 1);
void initOpenCL()
// Get the NVIDIA platform
	ciErrNum = oclGetPlatformID(&cpPlatform);
	oclCheckErrorEX(ciErrNum, CL_SUCCESS, NULL);
	printf("clGetPlatformID...\n");
	//Get all the devices
	cl_uint uiNumDevices = 0;           // Number of devices available
	cl_uint uiNumComputeUnits;          // Number of compute units (SM's on NV GPU)
	printf("Get the Device info and select Device...\n");
	ciErrNum = clGetDeviceIDs(cpPlatform, CL_DEVICE_TYPE_GPU, 0, NULL, &uiNumDevices);
	cdDevices = (cl_device_id *)malloc(uiNumDevices * sizeof(cl_device_id) );
	ciErrNum = clGetDeviceIDs(cpPlatform, CL_DEVICE_TYPE_GPU, uiNumDevices, cdDevices, NULL);
	// Set target device and Query number of compute units on uiTargetDevice
	printf("# of Devices Available = %u\n", uiNumDevices);
	printf("Using Device %u: ", uiTargetDevice);
	oclPrintDevName(LOGBOTH, cdDevices[uiTargetDevice]);
	ciErrNum = clGetDeviceInfo(cdDevices[uiTargetDevice], CL_DEVICE_MAX_COMPUTE_UNITS, sizeof(uiNumComputeUnits), &uiNumComputeUnits, NULL);
	printf("\n# of Compute Units = %u\n", uiNumComputeUnits);
	 cxGPUContext = clCreateContext(0, uiNumDevsUsed, &cdDevices[uiTargetDevice], NULL, NULL, &ciErrNum);
	printf("clCreateContext created successfully...\n");
	// Create a command-queue
	cqCommandQueue = clCreateCommandQueue(cxGPUContext, cdDevices[uiTargetDevice], 0, &ciErrNum);
	printf("clCreateCommandQueue...\n");
	cPathAndName = shrFindFilePath(clSourcefile, NULL);
	oclCheckErrorEX(cPathAndName != NULL, shrTRUE, NULL);
	cSourceCL = oclLoadProgSource(cPathAndName, "// My comment\n", &szKernelLength);
	oclCheckErrorEX(cSourceCL != NULL, shrTRUE, NULL);
	printf("oclLoadProgSource...\n");
	// Create the program
	cpProgram = clCreateProgramWithSource(cxGPUContext, 1, (const char **)&cSourceCL, &szKernelLength, &ciErrNum);
	shrLog("clCreateProgramWithSource...\n");
	 // Setup build options string
	std::string sBuildOpts = " -cl-fast-relaxed-math";
	// sBuildOpts  += " -D USE_BUFFER";
	// Build the program
	ciErrNum = clBuildProgram(cpProgram, 0, NULL, sBuildOpts.c_str(), NULL, NULL);
	if (ciErrNum != CL_SUCCESS)
		 shrLogEx(LOGBOTH | ERRORMSG, ciErrNum, STDERROR);
		 oclLogBuildInfo(cpProgram, cdDevices[uiTargetDevice]);
		 oclLogPtx(cpProgram, cdDevices[uiTargetDevice], "oclBoxFilter.ptx");
		printf("FAILURE...\n");
		exit(-1);
	printf("clBuildProgram...\n");
int main(int argc, char ** argv)
	int width = 10;
	int height = 10;
	int sizeInBytes = width * height * sizeof(unsigned int);
	initOpenCL();
	// OpenCL Kernel
	cl_kernel oppKernel;
	oppKernel = clCreateKernel( cpProgram, "filterTex", &ciErrNum);
	printf("clCreateKernel (oppKernel)...\n");
#ifdef USE_BUFFER
	// Result in Buffer Object
	cl_mem cmDevBufOut = clCreateBuffer(cxGPUContext, CL_MEM_WRITE_ONLY, sizeInBytes, NULL, &ciErrNum);
	printf("clCreateBuffer ( Output buffers, device GMEM)...\n");
#else
	// Result in Image Object
	cl_mem imageOut;
	cl_image_format InputFormat;        // OpenCL format descriptor for 2D image useage
	InputFormat.image_channel_order = CL_RGBA;
	InputFormat.image_channel_data_type = CL_UNSIGNED_INT8;
	// clCreateImage2D gives INVALID_IMAGE_SIZE if host_ptr is NULL
	unsigned char *temp = (unsigned char * )malloc ( sizeInBytes );
	imageOut = clCreateImage2D(cxGPUContext, CL_MEM_READ_WRITE, &InputFormat,
								 width, height,
								  width * sizeof(unsigned int), temp, &ciErrNum);
	printf("Device Image allocation SUCCESS to Hold Result...\n");
#endif
	// Setting up Kernel Args
#ifdef USE_BUFFER
	ciErrNum |= clSetKernelArg(oppKernel, 0, sizeof(cl_mem), (void*)&cmDevBufOut);
#else
	ciErrNum |= clSetKernelArg(oppKernel, 0, sizeof(cl_mem), (void*)&imageOut);
#endif
	ciErrNum |= clSetKernelArg(oppKernel, 1, sizeof(unsigned int), (void*)&width);
	ciErrNum |= clSetKernelArg(oppKernel, 2, sizeof(unsigned int), (void*)&height);
	printf("clSetKernelArg (0-2) oppKernel...\n");
	// Set global and local work sizes for row kernel
	size_t szLocalWorkSize[2];
	size_t szGlobalWorkSize[2];
	szLocalWorkSize[0] = 32;
	szLocalWorkSize[1] = 1;
	szGlobalWorkSize[0]= szLocalWorkSize[0] * DivUp((size_t)width * height, szLocalWorkSize[0]);
	szGlobalWorkSize[1] = 1;
	// Sync host and start computation timer
	clFinish(cqCommandQueue);
	 // 2D Image (Texture)
	 ciErrNum = clEnqueueNDRangeKernel(cqCommandQueue, oppKernel, 2, NULL,
										  szGlobalWorkSize, szLocalWorkSize, 0, NULL, NULL);
	printf("KERNEL LAUNCH SUCCESS\n");
	// Copy Result to Host
	unsigned int * res = (unsigned int *)malloc(sizeInBytes);
#ifdef USE_BUFFER
	clEnqueueReadBuffer(cqCommandQueue, cmDevBufOut, CL_TRUE, 0, sizeInBytes, res, 0, NULL, NULL);
	printf("clEnqueueReadBuffer SUCCESS\n");
#else
	// Read Image Object to host memory
	const size_t szTexOrigin[3] = {0, 0, 0};                // Offset of input texture origin relative to host image
	const size_t szTexRegion[3] = {width, height, 1};   // Size of texture region to operate on
	ciErrNum = clEnqueueReadImage(cqCommandQueue, imageOut, CL_TRUE,
								   szTexOrigin, szTexRegion, 0, 0, res, 0, NULL, NULL);
	printf("Device Image Copied to Host SUCEESS\n");
#endif
	displayImageInt(res, height, width);
	free(res);
The kernel code follows :
__kernel void filterTex(
#ifdef USE_BUFFER
						__global unsigned int *uiDest,
#else
                        __write_only image2d_t iDest,
#endif
							unsigned int uiWidth, unsigned int uiHeight)
    size_t globalPosY = get_global_id(0);
	int x = globalPosY % uiWidth;
	int y = globalPosY / uiWidth;
	int2 pos = {x, y};
#ifdef USE_BUFFER
	// Write out to GMEM
	uiDest[ globalPosY ] = globalPosY;
#else
	// Write to Image Object
	int4 val = {globalPosY, 0, 0, 0};
	write_imagei(iDest, pos, val);
#endif
Output using Image object
clGetPlatformID...
# of Devices Available = 1
Using Device 0: GeForce 8800 GTX
# of Compute Units = 16
clBuildProgram...
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
Output using Buffer Object ( uncomment #define USE_BUFFER and sBuildOpts += " -D USE_BUFFER"External Image
clGetPlatformID...
clBuildProgram...
0 1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18 19
20 21 22 23 24 25 26 27 28 29
30 31 32 33 34 35 36 37 38 39
40 41 42 43 44 45 46 47 48 49
50 51 52 53 54 55 56 57 58 59
60 61 62 63 64 65 66 67 68 69
70 71 72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87 88 89
90 91 92 93 94 95 96 97 98 99
Is there anyone else facing this issue. Is this a driver BUG?
Also, I’m forced to allocate a host_ptr while calling clCreateImage2D gives INVALID_IMAGE_SIZE if host_ptr is NULL
								 width, height,
System Details:
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.0 CUDA
3.2.1, SDK Revision = 7027912, NumDevs = 1, Device = GeForce 8800 GTX
System Info:
Local Time/Date = 16:59:50, 4/6/2011
 CPU Arch: 0
 CPU Level: 15
 # of CPU processors: 2
 Windows Build: 7600
 Windows Ver: 6.1 (Windows Vista / Windows 7)
Fixed doing:
  1. NULL can be passed as host_ptr to clCreateImage2D but pitch passed should be zero
image_row_pitch is the scan-line pitch in bytes. This must be 0 if host_ptr is NULL and can be
either 0 or >= image_width * size of element in bytes if host_ptr is not NULL. If host_ptr is not
NULL and image_row_pitch = 0, image_row_pitch is calculated as image_width * size of
element in bytes. If image_row_pitch is not 0, it must be a multiple of the image element size in
bytes.
  1. Writing to Image Object using write_imagei should be write_imageui as the channel used is UNSIGNED_INT8
