Hello
I’ve got a weird issue trying to run the following code.
It works well when I disable CL GL sharing or running on CPU.
Nvidia oclSimpleGL works well with CL GL interop.
Any ideas?
Guillaume
This is part of gnuradio, gr-fosphor.
- cl.c
- OpenCL base routines
- Copyright (C) 2013-2014 Sylvain Munaut
- This program is free software: you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation, either version 3 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program. If not, see http://www.gnu.org/licenses/.
/*! \addtogroup cl
/*! \file cl.c
- \brief OpenCL base routines
include <ctype.h>
include <errno.h>
include <stdlib.h>
include <stdio.h>
include <string.h>
include “cl_platform.h”
include “cl_compat.h”
#if defined(APPLE) || defined(MACOSX)
include <OpenGL/OpenGL.h>
include <OpenGL/gl.h>
#elif defined(_WIN32)
include <windows.h>
include <wingdi.h>
#else
include <GL/glx.h>
include “cl.h”
include “gl.h”
include “private.h”
include “resource.h”
struct fosphor_cl_features
define FLG_CL_GL_SHARING (1<<0)
define FLG_CL_NVIDIA_SM11 (1<<1)
define FLG_CL_OPENCL_11 (1<<2)
define FLG_CL_LOCAL_ATOMIC_EXT (1<<3)
cl_device_type type;
char vendor[128];
unsigned long local_mem;
int flags;
int wg_size;
int wg_size_dim[2];
struct fosphor_cl_state
cl_platform_id pl_id;
cl_device_id dev_id;
cl_context ctx;
cl_command_queue cq;
/* Features */
struct fosphor_cl_features feat;
/* FFT */
cl_mem mem_fft_in;
cl_mem mem_fft_out;
cl_mem mem_fft_win;
cl_program prog_fft;
cl_kernel kern_fft;
float *fft_win;
int fft_win_updated;
/* Display */
cl_mem mem_waterfall;
cl_mem mem_histogram;
cl_mem mem_spectrum;
cl_program prog_display;
cl_kernel kern_display;
/* Histogram range */
float histo_scale;
float histo_offset;
/* State */
int waterfall_pos;
enum {
CL_BOOTING = 0,
CL_PENDING,
CL_READY,
} state;
/ Helpers / Internal API /
define MAX_PLATFORMS 16
define MAX_DEVICES 16
define CL_ERR_CHECK(v, msg)
if ((v) != CL_SUCCESS) {
fprintf(stderr, “[!] CL Error (%d, %s:%d): %s\n”,
(v), FILE, LINE, msg);
goto error;
static int
cl_device_query(cl_device_id dev_id, struct fosphor_cl_features *feat)
char txt[2048];
cl_int err;
int has_nv_attr;
memset(feat, 0x00, sizeof(struct fosphor_cl_features));
/* Device type */
err = clGetDeviceInfo(dev_id, CL_DEVICE_TYPE, sizeof(cl_device_type), &feat->type, NULL);
if (err != CL_SUCCESS)
return -1;
/* Vendor */
err = clGetDeviceInfo(dev_id, CL_DEVICE_VENDOR, sizeof(feat->vendor)-1, &feat->vendor, NULL);
return -1;
/* Local memory size */
err = clGetDeviceInfo(dev_id, CL_DEVICE_LOCAL_MEM_SIZE, sizeof(cl_ulong), &feat->local_mem, NULL);
return -1;
/* CL/GL extension */
err = clGetDeviceInfo(dev_id, CL_DEVICE_EXTENSIONS, sizeof(txt)-1, txt, NULL);
return -1;
txt = 0;
/* Check for CL/GL sharing */
if (strstr(txt, "cl_khr_gl_sharing") || strstr(txt, "cl_APPLE_gl_sharing"))
feat->flags |= FLG_CL_GL_SHARING;
/* Check for NV attributes */
has_nv_attr = !!strstr(txt, "cl_nv_device_attribute_query");
/* Check for cl_khr_local_int32_base_atomics extension */
if (strstr(txt, "cl_khr_local_int32_base_atomics"))
feat->flags |= FLG_CL_LOCAL_ATOMIC_EXT;
/* Check OpenCL 1.1 compat */
err = clGetDeviceInfo(dev_id, CL_DEVICE_VERSION, sizeof(txt)-1, txt, NULL);
return -1;
txt = 0;
if (!memcmp(txt, "OpenCL 1.", 9) && txt[9] >= '1')
feat->flags |= FLG_CL_OPENCL_11;
/* Check if a NVidia SM11 architecture */
if (has_nv_attr) {
cl_uint nv_maj, nv_min;
err = clGetDeviceInfo(dev_id, CL_DEVICE_COMPUTE_CAPABILITY_MAJOR_NV,
sizeof(cl_uint), &nv_maj, NULL);
return -1;
err = clGetDeviceInfo(dev_id, CL_DEVICE_COMPUTE_CAPABILITY_MINOR_NV,
sizeof(cl_uint), &nv_min, NULL);
return -1;
if ((nv_maj == 1) && (nv_min == 1))
feat->flags |= FLG_CL_NVIDIA_SM11;
#ifdef APPLE
else if (!(feat->flags & (FLG_CL_OPENCL_11 | FLG_CL_LOCAL_ATOMIC_EXT)))
* OSX doesn’t allow query of NV attributes even on NVidia
* cards so we just assume any non-opencl 1.1 nvidia card
* without cl_khr_local_int32_base_atomics extension
* that does OpenCL is a SM1.1 one
err = clGetDeviceInfo(dev_id, CL_DEVICE_VENDOR, sizeof(txt)-1, txt, NULL);
return -1;
txt = 0;
if (!!strstr(txt, "NVIDIA"))
return 0;
static int
cl_device_score(cl_device_id dev_id, struct fosphor_cl_features *feat)
int rv, score = 0;
/* Query device */
rv = cl_device_query(dev_id, feat);
if (rv)
return rv;
/* Check compatibility */
if (!(feat->flags & (FLG_CL_NVIDIA_SM11 | FLG_CL_OPENCL_11 | FLG_CL_LOCAL_ATOMIC_EXT)))
return -1;
/* Prefer device with CL/GL sharing */
if (feat->flags & FLG_CL_GL_SHARING)
score += 500;
/* Prefer GPU (preferrably NVidia / AMD) */
if (feat->type == CL_DEVICE_TYPE_GPU)
char vendor;
int i;
score += 1000;
for (i=0; i<sizeof(feat->vendor); i++)
vendor[i] = tolower(feat->vendor[i]);
if (strstr(vendor, "nvidia") ||
strstr(vendor, "advanced micro devices") ||
strstr(vendor, "amd"))
score += 500;
/* Bigger local mem */
score += (feat->local_mem < (1<<20)) ? (feat->local_mem >> 11) : (1 << 9);
return score;
static int
cl_find_device(cl_platform_id *pl_id_p, cl_device_id *dev_id_p,
cl_platform_id pl_list[MAX_PLATFORMS], pl_id;
cl_device_id dev_list[MAX_DEVICES], dev_id;
cl_uint pl_count, dev_count, i, j;
cl_int err;
int score = -1;
/* Scan each platforms */
err = clGetPlatformIDs(MAX_PLATFORMS, pl_list, &pl_count);
CL_ERR_CHECK(err, "Unable to fetch platform IDs");
for (i=0; i<pl_count; i++)
/* Scan all devices */
err = clGetDeviceIDs(pl_list[i], CL_DEVICE_TYPE_ALL, MAX_DEVICES, dev_list, &dev_count);
fprintf(stderr, "[w] CL Error (%d, %s:%d): "
"Unable to fetch device IDs for platform %d. Skipping.\n",
err, __FILE__, __LINE__, i);
continue;
for (j=0; j<dev_count; j++)
struct fosphor_cl_features feat_cur;
int s = cl_device_score(dev_list[j], &feat_cur);
if (s > score) {
pl_id = pl_list[i];
dev_id = dev_list[j];
memcpy(feat, &feat_cur, sizeof(struct fosphor_cl_features));
score = s;
/* Did we get a good fit ? */
if (score >= 0) {
*pl_id_p = pl_id;
*dev_id_p = dev_id;
err = 0;
} else {
err = -ENODEV;
error:
return err;
static cl_program
cl_load_program(cl_device_id dev_id, cl_context ctx,
const char *resource_name, const char *opts,
cl_int *err_ptr)
cl_program prog = NULL;
const char *src;
cl_int err;
/* Grab resource */
src = resource_get(resource_name, NULL);
if (!src) {
fprintf(stderr, "[!] Unable to load non-existent resource '%s'\n", resource_name);
err = CL_INVALID_VALUE;
goto error;
/* Create the program from sources */
prog = clCreateProgramWithSource(ctx, 1, (const char **)&src, NULL, &err);
CL_ERR_CHECK(err, "Failed to create program");
/* Build it */
err = clBuildProgram(prog, 0, NULL, opts, NULL, NULL);
#ifndef DEBUG_CL
endif
size_t len;
const int txt_buf_len = 1024 * 1024;
char *txt_buf;
txt_buf = malloc(txt_buf_len);
clGetProgramBuildInfo(prog, dev_id, CL_PROGRAM_BUILD_LOG, txt_buf_len, txt_buf, &len);
fprintf(stderr, "Build log for '%s':\n%s\n\n---\n", resource_name, txt_buf);
free(txt_buf);
CL_ERR_CHECK(err, "Failed to build program");
#ifdef DEBUG_CL
size_t bin_len;
char name_buf[256];
char *bin_buf;
snprintf(name_buf, 256, "prog_%s.bin", resource_name);
clGetProgramInfo(prog, CL_PROGRAM_BINARY_SIZES, sizeof(size_t), &bin_len, NULL);
fprintf(stderr, "Binary length for '%s': %d\n\n", resource_name, (int)bin_len);
bin_buf = malloc(bin_len);
clGetProgramInfo(prog, CL_PROGRAM_BINARIES, sizeof(char *), &bin_buf, NULL );
FILE *fh = fopen(name_buf, "wb");
if (fwrite(bin_buf, bin_len, 1, fh) != 1)
fprintf(stderr, "[w] Binary write failed\n");
fclose(fh);
free(bin_buf);
/* All good */
return prog;
/* Error path */
error:
if (prog)
clReleaseProgram(prog);
if (err_ptr)
*err_ptr = err;
return NULL;
static int
cl_queue_clear_buffers(struct fosphor *self)
struct fosphor_cl_state *cl = self->cl;
float noise_floor, color[4] = {0.0f, 0.0f, 0.0f, 0.0f};
size_t img_origin[3] = {0.0f, 0.0f, 0.0f}, img_region[3];
cl_int err;
/* Configure noise floor to the bottom of the scale */
noise_floor = - self->power.offset;
/* Init spectrum to noise floor */
err = clEnqueueFillBuffer(cl->cq,
cl->mem_spectrum,
&noise_floor, sizeof(float),
0,
2 * 2 * sizeof(cl_float) * FOSPHOR_FFT_LEN,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue clear of spectrum buffer");
/* Init the waterfall image to noise floor */
color[0] = noise_floor;
img_region[0] = FOSPHOR_FFT_LEN;
img_region[1] = 1024;
img_region[2] = 1;
err = clEnqueueFillImage(cl->cq,
cl->mem_waterfall,
color,
img_origin, img_region,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue clear of waterfall image");
/* Init the histogram image to all 0.0f values */
color[0] = 0.0f;
img_region[1] = 128;
img_region[2] = 1;
cl->mem_histogram,
color,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue clear of histogram image");
/* Need to finish because our patterns are on the stack */
clFinish(cl->cq);
return 0;
/* Error path */
error:
return err;
static int
cl_init_buffers_gl(struct fosphor *self)
cl_int err;
/* GL shared objects */
/* Waterfall texture */
cl->mem_waterfall = clCreateFromGLTexture(cl->ctx,
CL_MEM_WRITE_ONLY, GL_TEXTURE_2D, 0,
fosphor_gl_get_shared_id(self, GL_ID_TEX_WATERFALL),
&err
CL_ERR_CHECK(err, "Unable to share waterfall texture into OpenCL context");
/* Histogram texture */
cl->mem_histogram = clCreateFromGLTexture(cl->ctx,
CL_MEM_READ_WRITE, GL_TEXTURE_2D, 0,
fosphor_gl_get_shared_id(self, GL_ID_TEX_HISTOGRAM),
&err
CL_ERR_CHECK(err, "Unable to share histogram texture into OpenCL context");
/* Spectrum VBO */
cl->mem_spectrum = clCreateFromGLBuffer(cl->ctx,
CL_MEM_WRITE_ONLY,
fosphor_gl_get_shared_id(self, GL_ID_VBO_SPECTRUM),
&err
CL_ERR_CHECK(err, "Unable to share spectrum VBO into OpenCL context");
/* All done */
err = 0;
error:
return err;
static int
cl_init_buffers_nogl(struct fosphor *self)
cl_image_format img_fmt;
cl_image_desc img_desc;
cl_int err;
/* Common settings */
img_fmt.image_channel_order = CL_R;
img_fmt.image_channel_data_type = CL_FLOAT;
img_desc.image_type = CL_MEM_OBJECT_IMAGE2D;
img_desc.image_width = FOSPHOR_FFT_LEN;
img_desc.image_depth = 0;
img_desc.image_array_size = 0;
img_desc.image_row_pitch = 0;
img_desc.image_slice_pitch = 0;
img_desc.num_mip_levels = 0;
img_desc.num_samples = 0;
img_desc.buffer = NULL;
img_desc.image_height = 1024;
cl->mem_waterfall = clCreateImage(
cl->ctx,
CL_MEM_WRITE_ONLY,
&img_fmt,
&img_desc,
NULL,
&err
CL_ERR_CHECK(err, "Unable to create waterfall image");
img_desc.image_height = 128;
cl->mem_histogram = clCreateImage(
cl->ctx,
CL_MEM_READ_WRITE,
&img_fmt,
&img_desc,
NULL,
&err
CL_ERR_CHECK(err, "Unable to create histogram image");
/* Spectrum VBO */
cl->mem_spectrum = clCreateBuffer(
cl->ctx,
CL_MEM_READ_WRITE,
NULL,
&err
CL_ERR_CHECK(err, "Unable to create spectrum VBO buffer");
/* All done */
err = 0;
error:
return err;
static int
cl_do_init(struct fosphor *self)
cl_context_properties ctx_props[7];
const char *disp_opts;
cl_int err;
/* Setup some options */
if ((cl->feat.type == CL_DEVICE_TYPE_GPU) &&
(cl->feat.flags & FLG_CL_GL_SHARING))
/* Only use CLGL sharing with GPU. Most CPU impl of it will
* just fail with float textures */
self->flags |= FLG_FOSPHOR_USE_CLGL_SHARING;
/* Context */
ctx_props[0] = 0;
if (self->flags & FLG_FOSPHOR_USE_CLGL_SHARING)
/* Setup context properties */
/* OSX variant */
ctx_props[0] = CL_CONTEXT_PROPERTY_USE_CGL_SHAREGROUP_APPLE;
ctx_props[1] = (cl_context_properties) CGLGetShareGroup(CGLGetCurrentContext());
ctx_props[2] = 0;
/* Win 32 variant */
ctx_props[0] = CL_GL_CONTEXT_KHR;
ctx_props[1] = (cl_context_properties) wglGetCurrentContext();
ctx_props[2] = CL_WGL_HDC_KHR;
ctx_props[3] = (cl_context_properties) wglGetCurrentDC();
ctx_props[4] = CL_CONTEXT_PLATFORM;
ctx_props[5] = (cl_context_properties) cl->pl_id;
ctx_props[6] = 0;
#else
/* Linux variant */
ctx_props[1] = (cl_context_properties) glXGetCurrentContext();
ctx_props[2] = CL_GLX_DISPLAY_KHR;
ctx_props[3] = (cl_context_properties) glXGetCurrentDisplay();
ctx_props[6] = 0;
/* Attempt to create context */
cl->ctx = clCreateContext(ctx_props, 1, &cl->dev_id, NULL, NULL, &err);
if (err != CL_SUCCESS) {
/* Failed, we'll retry again without CL/GL sharing */
"Unable to create context with CL/GL sharing, retrying without\n",
err, __FILE__, __LINE__);
self->flags &= ~FLG_FOSPHOR_USE_CLGL_SHARING;
ctx_props[0] = 0;
if (!(self->flags & FLG_FOSPHOR_USE_CLGL_SHARING))
CL_ERR_CHECK(err, "Unable to create context");
/* Command Queue */
cl->cq = clCreateCommandQueue(cl->ctx, cl->dev_id, 0, &err);
CL_ERR_CHECK(err, "Unable to create command queue");
/* FFT buffers */
cl->mem_fft_in = clCreateBuffer(cl->ctx,
CL_MEM_READ_ONLY,
2 * sizeof(cl_float) * FOSPHOR_FFT_LEN * FOSPHOR_FFT_MAX_BATCH,
NULL,
&err
CL_ERR_CHECK(err, "Unable to allocate FFT input buffer");
cl->mem_fft_out = clCreateBuffer(cl->ctx,
CL_MEM_READ_WRITE,
NULL,
&err
CL_ERR_CHECK(err, "Unable to allocate FFT output buffer");
cl->mem_fft_win = clCreateBuffer(cl->ctx,
CL_MEM_READ_ONLY,
NULL,
&err
CL_ERR_CHECK(err, "Unable to allocate FFT window buffer");
/* FFT program/kernels */
cl->prog_fft = cl_load_program(cl->dev_id, cl->ctx, "fft.cl", NULL, &err);
if (!cl->prog_fft)
goto error;
cl->kern_fft = clCreateKernel(cl->prog_fft, "fft1D_1024", &err);
CL_ERR_CHECK(err, "Unable to create FFT kernel");
/* Configure static FFT kernel args */
err = clSetKernelArg(cl->kern_fft, 0, sizeof(cl_mem), &cl->mem_fft_in);
err |= clSetKernelArg(cl->kern_fft, 1, sizeof(cl_mem), &cl->mem_fft_out);
err |= clSetKernelArg(cl->kern_fft, 2, sizeof(cl_mem), &cl->mem_fft_win);
CL_ERR_CHECK(err, "Unable to configure FFT kernel");
/* Display kernel result memory objects */
err = cl_init_buffers_gl(self);
else
err = cl_init_buffers_nogl(self);
goto error;
/* Display program/kernel */
if (cl->feat.flags & FLG_CL_NVIDIA_SM11)
disp_opts = "-DUSE_NV_SM11_ATOMICS";
else if (!(cl->feat.flags & FLG_CL_OPENCL_11))
disp_opts = "-DUSE_EXT_ATOMICS";
else
disp_opts = NULL;
cl->prog_display = cl_load_program(cl->dev_id, cl->ctx, "display.cl", disp_opts, &err);
if (!cl->prog_display)
goto error;
cl->kern_display = clCreateKernel(cl->prog_display, "display", &err);
CL_ERR_CHECK(err, "Unable to create display kernel");
/* Configure static display kernel args */
cl_uint fft_log2_len = FOSPHOR_FFT_LEN_LOG;
cl_float histo_t0r = 16.0f;
cl_float histo_t0d = 1024.0f;
cl_float live_alpha = 0.002f;
err = clSetKernelArg(cl->kern_display, 0, sizeof(cl_mem), &cl->mem_fft_out);
err |= clSetKernelArg(cl->kern_display, 1, sizeof(cl_int), &fft_log2_len);
err |= clSetKernelArg(cl->kern_display, 3, sizeof(cl_mem), &cl->mem_waterfall);
err |= clSetKernelArg(cl->kern_display, 5, sizeof(cl_mem), &cl->mem_histogram);
err |= clSetKernelArg(cl->kern_display, 6, sizeof(cl_mem), &cl->mem_histogram);
err |= clSetKernelArg(cl->kern_display, 7, sizeof(cl_float), &histo_t0r);
err |= clSetKernelArg(cl->kern_display, 8, sizeof(cl_float), &histo_t0d);
err |= clSetKernelArg(cl->kern_display, 11, sizeof(cl_mem), &cl->mem_spectrum);
err |= clSetKernelArg(cl->kern_display, 12, sizeof(cl_float), &live_alpha);
CL_ERR_CHECK(err, "Unable to configure display kernel");
/* All done */
err = 0;
error:
return err;
static void
cl_do_release(struct fosphor_cl_state *cl)
if (cl->kern_display)
clReleaseKernel(cl->kern_display);
if (cl->prog_display)
clReleaseProgram(cl->prog_display);
if (cl->mem_spectrum)
clReleaseMemObject(cl->mem_spectrum);
if (cl->mem_histogram)
clReleaseMemObject(cl->mem_histogram);
if (cl->mem_waterfall)
clReleaseMemObject(cl->mem_waterfall);
if (cl->kern_fft)
clReleaseKernel(cl->kern_fft);
if (cl->prog_fft)
clReleaseProgram(cl->prog_fft);
if (cl->mem_fft_win)
clReleaseMemObject(cl->mem_fft_win);
if (cl->mem_fft_out)
clReleaseMemObject(cl->mem_fft_out);
if (cl->mem_fft_in)
clReleaseMemObject(cl->mem_fft_in);
if (cl->cq)
clReleaseCommandQueue(cl->cq);
if (cl->ctx)
clReleaseContext(cl->ctx);
/ Exposed API /
int
fosphor_cl_init(struct fosphor *self)
struct fosphor_cl_state *cl;
char dev_name[128];
cl_int err;
/* Allocate structure */
cl = malloc(sizeof(struct fosphor_cl_state));
if (!cl)
return -ENOMEM;
self->cl = cl;
memset(cl, 0, sizeof(struct fosphor_cl_state));
cl->state = CL_BOOTING;
/* Find suitable device */
if (cl_find_device(&cl->pl_id, &cl->dev_id, &cl->feat)) {
fprintf(stderr, "[!] No suitable OpenCL device found\n");
goto error;
/* Report selected device */
err = clGetDeviceInfo(cl->dev_id, CL_DEVICE_NAME, sizeof(dev_name)-1, dev_name, NULL);
CL_ERR_CHECK(err, "Unable to fetch device name");
fprintf(stderr, "[+] Selected device: %s\n", dev_name);
/* Setup compatibility layer for this platform */
cl_compat_init();
cl_compat_check_platform(cl->pl_id);
/* Initialize selected platform / device */
err = cl_do_init(self);
if (err)
goto error;
/* Done */
return 0;
/* Error path */
error:
fosphor_cl_release(self);
return -EIO;
void
fosphor_cl_release(struct fosphor *self)
/* Safety */
if (!cl)
return;
/* Release all allocated OpenCL resources */
cl_do_release(cl);
/* Release structure */
free(cl);
/* Nothing left */
self->cl = NULL;
int
fosphor_cl_process(struct fosphor *self,
void *samples, int len)
cl_int err;
size_t local[2], global[2];
int n_spectra = len / FOSPHOR_FFT_LEN;
/* Validate batch size */
if (len & ((FOSPHOR_FFT_MULT_BATCH*FOSPHOR_FFT_LEN)-1))
return -EINVAL;
if (len > (FOSPHOR_FFT_LEN * FOSPHOR_FFT_MAX_BATCH))
return -EINVAL;
/* Copy new window if needed */
if (cl->fft_win_updated) {
err = clEnqueueWriteBuffer(
cl->cq,
cl->mem_fft_win,
CL_FALSE,
0, sizeof(cl_float) * FOSPHOR_FFT_LEN, cl->fft_win,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to copy data to FFT window buffer");
cl->fft_win_updated = 0;
/* Copy samples data */
cl->cq,
cl->mem_fft_in,
CL_FALSE,
0, 2 * sizeof(cl_float) * len, samples,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to copy data to FFT input buffer");
/* Execute FFT kernel */
global[0] = FOSPHOR_FFT_LEN / 8;
global[1] = n_spectra;
local[0] = global[0];
local[1] = 1;
err = clEnqueueNDRangeKernel(cl->cq, cl->kern_fft, 2, NULL, global, local, 0, NULL, NULL);
CL_ERR_CHECK(err, "Unable to queue FFT kernel execution");
/* Capture all GL objects */
if ((cl->state != CL_PENDING) && (self->flags & FLG_FOSPHOR_USE_CLGL_SHARING)) {
cl_mem objs[3];
objs[0] = cl->mem_waterfall;
objs[1] = cl->mem_histogram;
objs[2] = cl->mem_spectrum;
err = clEnqueueAcquireGLObjects(cl->cq, 3, objs, 0, NULL, NULL);
CL_ERR_CHECK(err, "Unable to acquire GL objects");
/* If this is the first run, make sure to pre-clear the buffers */
if (cl->state == CL_BOOTING) {
err = cl_queue_clear_buffers(self);
goto error;
/* Configure display kernel */
err = 0;
err |= clSetKernelArg(cl->kern_display, 2, sizeof(cl_int), &n_spectra);
err |= clSetKernelArg(cl->kern_display, 4, sizeof(cl_int), &cl->waterfall_pos);
err |= clSetKernelArg(cl->kern_display, 9, sizeof(cl_float), &cl->histo_scale);
err |= clSetKernelArg(cl->kern_display, 10, sizeof(cl_float), &cl->histo_offset);
/* Execute display kernel */
global[0] = FOSPHOR_FFT_LEN;
global[1] = 16;
local[0] = 16;
local[1] = 16;
err = clEnqueueNDRangeKernel(cl->cq, cl->kern_display, 2, NULL, global, local, 0, NULL, NULL);
CL_ERR_CHECK(err, "Unable to queue display kernel execution");
/* Advance waterfall */
cl->waterfall_pos = (cl->waterfall_pos + n_spectra) & 1023;
/* New state */
cl->state = CL_PENDING;
return 0;
error:
return -EIO;
int
fosphor_cl_finish(struct fosphor *self)
cl_int err;
/* Check if we really need to do anything */
if (cl->state == CL_READY)
return 0;
/* If no data was processed, we may need to finish the boot */
/* Acquire GL objects if needed */
cl_mem objs[3];
/* Clear the buffers */
goto error;
/* Act depending on current mode */
/* If we use CL/GL sharing, we need to release the objects */
cl_mem objs[3];
err = clEnqueueReleaseGLObjects(cl->cq, 3, objs, 0, NULL, NULL);
CL_ERR_CHECK(err, "Unable to release GL objects");
else
/* If we don't use CL/GL sharing, we need to fetch the results */
size_t img_origin[3] = { 0, 0, 0 };
size_t img_region[3] = { 1024, 0, 1 };
/* Waterfall */
err = clEnqueueReadImage(cl->cq,
cl->mem_waterfall,
CL_FALSE,
img_origin,
img_region,
0,
0,
self->img_waterfall,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue readback of waterfall image");
/* Histogram */
cl->mem_histogram,
CL_FALSE,
img_origin,
img_region,
0,
0,
self->img_histogram,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue readback of histogram image");
/* Live spectrum */
err = clEnqueueReadBuffer(cl->cq,
cl->mem_spectrum,
CL_FALSE,
0,
self->buf_spectrum,
0, NULL, NULL
CL_ERR_CHECK(err, "Unable to queue readback of spectrum buffer");
/* Ensure CL is done */
clFinish(cl->cq);
/* New state */
cl->state = CL_READY;
return 1;
error:
return -EIO;
void
fosphor_cl_load_fft_window(struct fosphor *self, float *win)
cl->fft_win = win;
cl->fft_win_updated = 1;
int
fosphor_cl_get_waterfall_position(struct fosphor *self)
return cl->waterfall_pos;
void
fosphor_cl_set_histogram_range(struct fosphor *self,
float scale, float offset)
cl->histo_scale = scale * 128.0f;
cl->histo_offset = offset;
