Hi all,
I already posted in “DirectX / OpenGL & other APIs” but now I’ve seen that here it is better.
I’m trying to set up a Mandelbrot on OpenCL.
The CL C code in compiling correct and the execution begins without any issues.
But when I call event.wait() an CL_OUT_OF_RESOURCES occures. I can’t imagine why.
My host code (N = 512 an M = 512):
// Initialize OpenCL
cl_int error;
cl::vector< cl::Platform > platformList;
cl::Platform::get(&platformList);
checkErr(platformList.size()!=0 ? CL_SUCCESS : -1, "cl::Platform::get");
std::cout << "Platform number is: " << platformList.size() << std::endl;
std::string platformVendor;
platformList[0].getInfo((cl_platform_info)CL_PLATFORM_VENDOR, &platformVendor);
std::cout << "Platform is by: " << platformVendor << "\n";
cl_context_properties cprops[3] = {CL_CONTEXT_PLATFORM, (cl_context_properties)(platformList[0])(), 0};
cl::Context context(CL_DEVICE_TYPE_GPU/*CL_DEVICE_TYPE_CPU*/, cprops, NULL, NULL, &error);
checkErr(error, "Conext::Context()");
/** Allocate Buffers **/
/** integers ************************************************************************************************/
cl::Buffer maxCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(int), &max, &error);
checkErr(error, "Buffer::outCL(max)");
/** floats **************************************************************************************************/
cl::Buffer mCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &m, &error);
checkErr(error, "Buffer::outCL(m)");
cl::Buffer nCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &n, &error);
checkErr(error, "Buffer::outCL(n)");
cl::Buffer cxCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &cx, &error);
checkErr(error, "Buffer::outCL(cx)");
cl::Buffer cyCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &cy, &error);
checkErr(error, "Buffer::outCL(cy)");
cl::Buffer widthCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &width, &error);
checkErr(error, "Buffer::outCL(width)");
cl::Buffer heightCL( context, CL_MEM_READ_ONLY/*CL_MEM_READ_WRITE*/ | CL_MEM_USE_HOST_PTR, sizeof(float), &height, &error);
checkErr(error, "Buffer::outCL(height)");
/** image ***************************************************************************************************/
cl::Buffer imageCL( context, CL_MEM_READ_WRITE | CL_MEM_USE_HOST_PTR, M*N*sizeof(GLubyte), image, &error);
checkErr(error, "Buffer::outCL(image)"); /*****/
// get OpenCL devices
cl::vector<cl::Device> devices;
devices = context.getInfo<CL_CONTEXT_DEVICES>();
checkErr(devices.size() > 0 ? CL_SUCCESS : -1, "devices.size() > 0");
// read OpenCL C file
#ifdef __APPLE__
std::ifstream file("../../mandelbrot.cl");
#else
std::ifstream file("mandelbrot.cl");
#endif
std::ios_base::iostate state = file.rdstate();
checkErr(file.is_open() ? CL_SUCCESS:-1, "read mandelbrot.cl");
// save file to string
std::string prog(std::istreambuf_iterator<char>(file), (std::istreambuf_iterator<char>()));
// make OpenCL C file to OpenCL source
cl::Program::Sources source(1, std::make_pair(prog.c_str(), prog.length()+1));
// build OpenCL source
cl::Program program(context, source);
error = program.build(devices,"");
checkErr(error, "cl::Program program.build()");
// define entry point
cl::Kernel kernel(program, "mandelCalcCL", &error);
checkErr(error, "Kernel::Kernel()");
// set arguments
error = kernel.setArg(0, maxCL);
checkErr(error, "Kernel::setArg(max)");
error = kernel.setArg(1, mCL);
checkErr(error, "Kernel::setArg(m)");
error = kernel.setArg(2, nCL);
checkErr(error, "Kernel::setArg(n)");
error = kernel.setArg(3, cxCL);
checkErr(error, "Kernel::setArg(cx)");
error = kernel.setArg(4, cyCL);
checkErr(error, "Kernel::setArg(cy)");
error = kernel.setArg(5, widthCL);
checkErr(error, "Kernel::setArg(width)");
error = kernel.setArg(6, heightCL);
checkErr(error, "Kernel::setArg(height)");
error = kernel.setArg(7, imageCL);
checkErr(error, "Kernel::setArg(image)");
// initialize queue
cl::CommandQueue queue(context, devices[0], 0, &error);
checkErr(error, "CommandQueue::CommandQueue()");
// create event
cl::Event event;
error = queue.enqueueNDRangeKernel(kernel, cl::NullRange, cl::NDRange(N*M*sizeof(GLubyte)), cl::NDRange(1/*, 1*/), NULL, &event);
checkErr(error, "ComamndQueue::enqueueNDRangeKernel()");
// wait until computation is finished
error = event.wait();
checkErr(error, "event.wait()");
// read image buffer
error = queue.enqueueReadBuffer(imageCL, CL_TRUE, 0, N*M*sizeof(GLubyte), &image);
checkErr(error, "ComamndQueue::enqueueReadBuffer(image)");
May be you can help me to figure out this problem.
Greets
Henrik
PS:
I’m running Ubuntu 10.04 x64
on Q9450 (4 x 2,4 GHz) with 3962 MB RAM and GeForce 8600 GT (256 MB RAM, 32 CUDA cores)
CUDA is the latest version available
