I’m new to OpenCL and have a problem with the porting of an existing inverse-DCT program into OpenCL. As I’m trying not change the whole program, I’m not working with any opencl image types. The informations about the image to perform my calculation on is an array of one dimension.
My implementation works fine with the intel sdk on the CPU but the nvidia sdk returns -5 (CL_OUT_OF_RESOURCES) as error value when I’m calling clEnqueueReadBuffer to get my results.
As a result I get a driver crash: NVIDIA Windows Kernel Driver, Version 267.21
The problem seems to be the amount of calculations to be done in each kernel.
To reproduce this error I wrote a small test. I didn’t reproduce the CL_OUT_OF_RESOURCES error because I don’t read from a buffer. The following code produces -36 ([i]CL_INVALID_COMMAND_QUEUE[i]) as error.
Host code:
size_t globalThreads[1]={32767};
size_t localThreads[1]={1};
ret = clEnqueueNDRangeKernel(command_queue, kernel, 1, NULL, globalThreads, localThreads, 0, NULL, NULL
// wait for all commands to end
ret = clFlush(command_queue);
ret |= clFinish(command_queue);
if (ret) {
debugOut("Error: Failed to wait for the executed commands!\n");
return false;
Kernel code:
__kernel void inverseDct() {
int indexX = get_global_id(0);
float Cm = 0.0f;
float Cn = 0.0f;
float c1 = 0.0f;
float c2 = 0.0f;
float sum = 0.0f;
// y is not used in the following lines, remove the loop and it works fine.
for (unsigned int y=0; y<8; y++) {
for (unsigned int x=0; x<8; x++) {
for (unsigned int m=0; m<8; m++) {
Cm = (float) (m ? 1 : (1 / sqrt(2.0)));
for (unsigned int n=0; n<8; n++) {
Cn = (float)(n ? 1 : (1 / sqrt(2.0)));
c1 = (float)half_cos(((2 * x + 1) * M_PI * m) / 16);
c2 = (float)half_cos(((2 * 1 + 1) * M_PI * n) / 16);
sum += Cn * Cm * indexX * c1 * c2;
Some informations about my system:
OpenCL SW Info:
CL_PLATFORM_NAME: NVIDIA CUDA
CL_PLATFORM_VERSION: OpenCL 1.0 CUDA 3.2.1
OpenCL SDK Revision: 7027912
OpenCL Device Info:
1 devices found supporting OpenCL:
Device NVS 3100M
CL_DEVICE_NAME: NVS 3100M
CL_DEVICE_VENDOR: NVIDIA Corporation
CL_DRIVER_VERSION: 267.21
CL_DEVICE_VERSION: OpenCL 1.0 CUDA
CL_DEVICE_TYPE: CL_DEVICE_TYPE_GPU
CL_DEVICE_MAX_COMPUTE_UNITS: 2
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
CL_DEVICE_MAX_WORK_ITEM_SIZES: 512 / 512 / 64
CL_DEVICE_MAX_WORK_GROUP_SIZE: 512
CL_DEVICE_MAX_CLOCK_FREQUENCY: 1468 MHz
CL_DEVICE_ADDRESS_BITS: 32
CL_DEVICE_MAX_MEM_ALLOC_SIZE: 128 MByte
CL_DEVICE_GLOBAL_MEM_SIZE: 218 MByte
CL_DEVICE_ERROR_CORRECTION_SUPPORT: no
CL_DEVICE_LOCAL_MEM_TYPE: local
CL_DEVICE_LOCAL_MEM_SIZE: 16 KByte
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64 KByte
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE
CL_DEVICE_QUEUE_PROPERTIES: CL_QUEUE_PROFILING_ENABLE
CL_DEVICE_IMAGE_SUPPORT: 1
CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
CL_DEVICE_SINGLE_FP_CONFIG: INF-quietNaNs round-to-nearest round-to-zero round-to-inf fma
CL_DEVICE_IMAGE <dim> 2D_MAX_WIDTH 4096
2D_MAX_HEIGHT 32768
3D_MAX_WIDTH 2048
3D_MAX_HEIGHT 2048
3D_MAX_DEPTH 2048
CL_DEVICE_EXTENSIONS: cl_khr_byte_addressable_store
cl_khr_icd
cl_khr_gl_sharing
cl_nv_d3d9_sharing
cl_nv_d3d10_sharing
cl_khr_d3d10_sharing
cl_nv_d3d11_sharing
cl_nv_compiler_options
cl_nv_device_attribute_query
cl_nv_pragma_unroll
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
CL_DEVICE_COMPUTE_CAPABILITY_NV: 1.2
NUMBER OF MULTIPROCESSORS: 2
NUMBER OF CUDA CORES: 16
CL_DEVICE_REGISTERS_PER_BLOCK_NV: 16384
CL_DEVICE_WARP_SIZE_NV: 32
CL_DEVICE_GPU_OVERLAP_NV: CL_TRUE
CL_DEVICE_KERNEL_EXEC_TIMEOUT_NV: CL_TRUE
CL_DEVICE_INTEGRATED_MEMORY_NV: CL_FALSE
CL_DEVICE_PREFERRED_VECTOR_WIDTH_<t> CHAR 1, SHORT 1, INT 1, LONG 1, FLOAT 1, DOUBLE 0
2D Image Formats Supported (71)
# Channel Order Channel Type
1 CL_R CL_FLOAT
2 CL_R CL_HALF_FLOAT
3 CL_R CL_UNORM_INT8
4 CL_R CL_UNORM_INT16
5 CL_R CL_SNORM_INT16
6 CL_R CL_SIGNED_INT8
7 CL_R CL_SIGNED_INT16
8 CL_R CL_SIGNED_INT32
9 CL_R CL_UNSIGNED_INT8
10 CL_R CL_UNSIGNED_INT16
11 CL_R CL_UNSIGNED_INT32
12 CL_A CL_FLOAT
13 CL_A CL_HALF_FLOAT
14 CL_A CL_UNORM_INT8
15 CL_A CL_UNORM_INT16
16 CL_A CL_SNORM_INT16
17 CL_A CL_SIGNED_INT8
18 CL_A CL_SIGNED_INT16
19 CL_A CL_SIGNED_INT32
20 CL_A CL_UNSIGNED_INT8
21 CL_A CL_UNSIGNED_INT16
22 CL_A CL_UNSIGNED_INT32
23 CL_RG CL_FLOAT
24 CL_RG CL_HALF_FLOAT
25 CL_RG CL_UNORM_INT8
26 CL_RG CL_UNORM_INT16
27 CL_RG CL_SNORM_INT16
28 CL_RG CL_SIGNED_INT8
29 CL_RG CL_SIGNED_INT16
30 CL_RG CL_SIGNED_INT32
31 CL_RG CL_UNSIGNED_INT8
32 CL_RG CL_UNSIGNED_INT16
33 CL_RG CL_UNSIGNED_INT32
34 CL_RA CL_FLOAT
35 CL_RA CL_HALF_FLOAT
36 CL_RA CL_UNORM_INT8
37 CL_RA CL_UNORM_INT16
38 CL_RA CL_SNORM_INT16
39 CL_RA CL_SIGNED_INT8
40 CL_RA CL_SIGNED_INT16
41 CL_RA CL_SIGNED_INT32
42 CL_RA CL_UNSIGNED_INT8
43 CL_RA CL_UNSIGNED_INT16
44 CL_RA CL_UNSIGNED_INT32
45 CL_RGBA CL_FLOAT
46 CL_RGBA CL_HALF_FLOAT
47 CL_RGBA CL_UNORM_INT8
48 CL_RGBA CL_UNORM_INT16
49 CL_RGBA CL_SNORM_INT16
50 CL_RGBA CL_SIGNED_INT8
51 CL_RGBA CL_SIGNED_INT16
52 CL_RGBA CL_SIGNED_INT32
53 CL_RGBA CL_UNSIGNED_INT8
54 CL_RGBA CL_UNSIGNED_INT16
55 CL_RGBA CL_UNSIGNED_INT32
56 CL_BGRA CL_UNORM_INT8
57 CL_BGRA CL_SIGNED_INT8
58 CL_BGRA CL_UNSIGNED_INT8
59 CL_ARGB CL_UNORM_INT8
60 CL_ARGB CL_SIGNED_INT8
61 CL_ARGB CL_UNSIGNED_INT8
62 CL_INTENSITY CL_FLOAT
63 CL_INTENSITY CL_HALF_FLOAT
64 CL_INTENSITY CL_UNORM_INT8
65 CL_INTENSITY CL_UNORM_INT16
66 CL_INTENSITY CL_SNORM_INT16
67 CL_LUMINANCE CL_FLOAT
68 CL_LUMINANCE CL_HALF_FLOAT
69 CL_LUMINANCE CL_UNORM_INT8
70 CL_LUMINANCE CL_UNORM_INT16
71 CL_LUMINANCE CL_SNORM_INT16
3D Image Formats Supported (71)
1 CL_R CL_FLOAT
12 CL_A CL_FLOAT
23 CL_RG CL_FLOAT
34 CL_RA CL_FLOAT
45 CL_RGBA CL_FLOAT
oclDeviceQuery, Platform Name = NVIDIA CUDA, Platform Version = OpenCL 1.0 CUDA 3.2.1, SDK Revision = 7027912, NumDevs = 1, Device = NVS 3100M
I used different setups to test:
global threads: ~32k; with y-loop! → crash!
global threads: ~16k; with y-loop! → works
global threads: ~32k; with y-loop! → works
global threads: ~65k; with y-loop! → works
global threads: ~130k with y-loop! → works
global threads: ~260 with y-loop! → crash!
Is there a connection between the global thread size and the amount of calculations to be done in the kernels?
My assumption is that I’m running out of local or private memory. But how can that happen if I’m just looping and doing some calculations?
I hope my explanation is understandable. Thanks in advance, appreciate any help.
