I’m trying to get running a program in CL, but i have some weird errors.
I have a picture with a laser line in it. I have to get some points of that laser line to compute distances to the objects.
I’m giving an array of all the lines i need to check, the parameters, and i need to compute the distances, and i want to get back an array of the coordinates of the pixels choosen to represent the laser.
I’m not computing the distances yet because the call to the findLaserPoint function returns an error. Here is the opencl code :
(it transforms a pixel into the HLS mode and then i get the pixel that represents the laser in the line)
[codebox]typedef struct cameraParams
float h;
float d;
float rcp1;
float r0_1;
float rcp2;
float r0_2;
} cameraParams;
enum bgr
BLUE = 0,
GREEN,
RED
typedef struct size
int height;
int width;
} size;
typedef struct coord
int x;
int y;
} coord;
typedef struct uchar3
// With opencv : c1 = blue, c2 = green, c3 = red
// In RGB mode : c1 = red, c2 = green, c3 = blue
// In HLS mode : c1 = hue, c2 = lightness, c3 = saturation
unsigned char c1;
unsigned char c2;
unsigned char c3;
} uchar3;
typedef struct pixel
coord xy;
uchar3 value;
} pixel;
typedef struct line
pixel * pixels;
float angle;
} line;
coord getCoord(pixel pix)
return pix.xy;
uchar3 transformToHls(pixel pix)
uchar3 hls;
float blue = pix.value.c1 / 255.;
float green = pix.value.c2 / 255.;
float red = pix.value.c3 / 255.;
float vMax, vMin;
float h, l, s;
int maxColor;
if(blue > red)
if(red > green)
vMax = blue;
vMin = green;
maxColor = BLUE;
else if(blue > green)
vMax = blue;
vMin = red;
maxColor = BLUE;
else
vMax = green;
vMin = red;
maxColor = GREEN;
vMax = red;
vMin = green;
maxColor = RED;
else if(red > green)
vMax = red;
vMin = green;
maxColor = RED;
else
vMax = green;
vMin = blue;
maxColor = GREEN;
l = (vMin + vMax) / 2.;
if(vMin == vMax)
h = 0;
s = 0;
else if(maxColor == RED)
h = (int)((60 * (green - blue) / (vMax - vMin) + 360.)) % 360;
else if(maxColor == GREEN)
h = 60 * (blue - red) / (vMax - vMin) + 120;
else
h = 60 * (red - green) / (vMax - vMin) + 240;
if(l > 0.5)
s = (vMax - vMin) / (vMax + vMin);
else if(l <= 0.5)
s = (vMax - vMin) / (2 - (vMax + vMin));
hls.c2 = (int)(l * 255.);
hls.c1 = (int)(h / (360. / 255.));
hls.c3 = (int)(s * 255.);
return hls;
bool checkPixel(unsigned char hue, unsigned char saturation)
if(hue > 30 && hue < 170)
return false;
if(saturation < 170)
return false;
return true;
coord findLaserPoint(line l)
coord point;
point.x = -1;
point.y = -1;
int index = -1;
uchar3 hls;
unsigned char lightness_prev = 0;
int nValidPixels = 0;
int before = 0;
for(int i = 0; i < 240 ; i++)
hls = transformToHls(l.pixels[i]);
if(!checkPixel(hls.c1, hls.c3))
continue;
l.pixels[nValidPixels] = l.pixels[i];
nValidPixels++;
if(point.x == -1)
point.x = l.pixels[i].xy.x;
point.y = l.pixels[i].xy.y;
lightness_prev = hls.c2;
else if(hls.c2 > lightness_prev)
index = nValidPixels - 1;
if(index >= 0)
int laserMin = index;
int laserMax = index;
int start = max(0, index - 1);
if(index > 0)
for(int i = start; i >= 0; i--)
int tx = abs((l.pixels[i].xy.x - l.pixels[i + 1].xy.x));
int ty = abs((l.pixels[i].xy.y - l.pixels[i + 1].xy.y));
if(tx == 1 || ty == 1)
laserMin = i;
else
break;
start = min(nValidPixels - 1, index + 1);
if(index < nValidPixels - 1)
for(int i = start; i < nValidPixels; i++)
int tx = abs((l.pixels[i].xy.x - l.pixels[i - 1].xy.x));
int ty = abs((l.pixels[i].xy.y - l.pixels[i - 1].xy.y));
laserMax = i;
else
break;
int laserMid = (laserMax + laserMin) / 2;
point.x = l.pixels[laserMid].xy.x;
point.y = l.pixels[laserMid].xy.y;
return point;
__kernel void
analyse(__global line * lines,
__global line * hlsPixels,
const cameraParams params,
__global coord * pixelCoords)
int nIndex = get_global_id(0);
pixelCoords[nIndex] = findLaserPoint(lines[nIndex]);
}[/codebox]
And now the code C++ (yeah i know it’s mainly C code) :
[codebox]#define __CL_ENABLE_EXCEPTIONS
#define __NO_STD_VECTOR
#define __NO_STD_STRING
#include <stdlib.h>
#include <CL/opencl.h>
#include “Image.h”
#include “Source.h”
#include “utils.h”
void randomInit(float * data, int size)
for (int i = 0; i < size; ++i)
data[i] = rand() % 100 + 1 / (float)RAND_MAX;
void showErrors(int err)
switch(err)
case CL_SUCCESS:
std::cout << "OK" << std::endl;
break;
case CL_INVALID_PROGRAM_EXECUTABLE:
std::cout << "error : CL_INVALID_PROGRAM_EXECUTABLE" << std::endl;
break;
case CL_INVALID_COMMAND_QUEUE:
std::cout << "error : CL_INVALID_COMMAND_QUEUE" << std::endl;
break;
case CL_INVALID_KERNEL:
std::cout << "error : CL_INVALID_KERNEL" << std::endl;
break;
case CL_INVALID_CONTEXT:
std::cout << "error : CL_INVALID_CONTEXT" << std::endl;
break;
case CL_INVALID_KERNEL_ARGS:
std::cout << "error : CL_INVALID_KERNEL_ARGS" << std::endl;
break;
case CL_INVALID_WORK_DIMENSION:
std::cout << "error : CL_INVALID_WORK_DIMENSION" << std::endl;
break;
case CL_INVALID_WORK_GROUP_SIZE:
std::cout << "error : CL_INVALID_WORK_GROUP_SIZE" << std::endl;
break;
case CL_INVALID_WORK_ITEM_SIZE:
std::cout << "error : CL_INVALID_WORK_ITEM_SIZE" << std::endl;
break;
case CL_INVALID_GLOBAL_OFFSET:
std::cout << "error : CL_INVALID_GLOBAL_OFFSET" << std::endl;
break;
case CL_OUT_OF_RESOURCES:
std::cout << "error : CL_OUT_OF_RESOURCES" << std::endl;
break;
case CL_MEM_OBJECT_ALLOCATION_FAILURE:
std::cout << "error : CL_MEM_OBJECT_ALLOCATION_FAILURE" << std::endl;
break;
case CL_INVALID_EVENT_WAIT_LIST:
std::cout << "error : CL_INVALID_EVENT_WAIT_LIST" << std::endl;
break;
case CL_OUT_OF_HOST_MEMORY:
std::cout << "error : CL_OUT_OF_HOST_MEMORY" << std::endl;
break;
case CL_INVALID_MEM_OBJECT:
std::cout << "error : CL_INVALID_MEM_OBJECT" << std::endl;
case CL_INVALID_VALUE:
std::cout << "error : CL_INVALID_VALUE" << std::endl;
default:
std::cout << "error not found" << std::endl;
int main()
cl_int err;
const int nPoints = 1;
const float angle = (float)(60. * PI / 180.);
const cameraParams params = {3., -1.9, 0.00132331, -0.03630043, 0.00089212,
-0.01771631};
cv::VideoCapture cap(0);
cap.set(CV_CAP_PROP_FRAME_WIDTH, 640);
cap.set(CV_CAP_PROP_FRAME_HEIGHT, 480);
while(42)
cv::Mat image;
cap >> image;
cv::Mat image_ = image.clone();
cv::line(image_, cv::Point(image_.cols / 2, 0),
cv::Point(image_.cols / 2, image_.rows - 1),
cv::Scalar(255, 255, 255));
cv::line(image_, cv::Point(0, image_.rows / 2),
cv::Point(image_.cols - 1, image_.rows / 2),
cv::namedWindow("test", 0);
cv::imshow("test", image_);
char c = cvWaitKey(40);
if(c == 'q' || c == 27)
cap.release();
break;
else if(c == 'c')
imwrite("img_test.png", image);
Image * img = new Image(image.size().height, image.size().width,
image.channels());
img->setData(image.data);
const size imgSize = {img->getHeight(), img->getWidth()};
const unsigned int cnBlockSize = sizeof(pixel) * img->getHeight() / 2;
const unsigned int cnBlocks = nPoints;
const unsigned int cnDimension = cnBlocks * cnBlockSize;
bool even = false;
float a = 0.;
if(nPoints > 1)
if(!(nPoints % 2))
even = true;
a = angle / nPoints;
else
a = angle / (nPoints - 1);
// Get platforms & device
cl_platform_id clPlatform;
cl_device_id clDeviceId;
err = clGetPlatformIDs(1, &clPlatform, NULL);
std::cout << "clGetPlatformIDs... ";
showErrors(err);
err = clGetDeviceIDs(clPlatform, CL_DEVICE_TYPE_GPU, 1, &clDeviceId, NULL);
std::cout << "clGetDeviceIDs... ";
showErrors(err);
Source program(“test_tmp.cl”);
const char * programSource = program.get();
// create OpenCL context
cl_context hContext;
hContext = clCreateContext(0, 1, &clDeviceId, NULL, NULL, &err);
std::cout << "clCreateContext... ";
showErrors(err);
// query all devices available to the context
size_t nContextDescriptorSize;
clGetContextInfo(hContext, CL_CONTEXT_DEVICES, 0, 0,
&nContextDescriptorSize);
cl_device_id * aDevices = (cl_device_id *)malloc(nContextDescriptorSize);
nContextDescriptorSize, aDevices, 0);
// create a command queue for first device the context reported
cl_command_queue hCmdQueue;
hCmdQueue = clCreateCommandQueue(hContext, aDevices[0], 0, &err);
std::cout << "clCreateCommandQueue... ";
showErrors(err);
// create & compile program
cl_program hProgram;
//const char * s = programSource.get();
hProgram = clCreateProgramWithSource(hContext, 1,
(const char **) &programSource,
0, &err);
std::cout << "clCreateProgramWithSource... ";
showErrors(err);
err = clBuildProgram(hProgram, 0, NULL, NULL, NULL, NULL);
std::cout << "clBuildProgram... ";
showErrors(err);
// create kernel
cl_kernel hKernel;
hKernel = clCreateKernel(hProgram, "analyse", &err);
std::cout << "clCreateKernel... ";
showErrors(err);
// allocate host vectors
line * lines = new line[cnBlocks];
coord * pixelCoords = new coord[cnBlocks];
// initialize host memory
for(int i = 0; i < nPoints / 2; i++)
int dist = (int)fabs(tan(a * (double)(i + 1.)) * img->getHeight() / 2.);
lines[i].pixels = img->Bresenham(img->getWidth() / 2, 0,
img->getWidth() / 2 - dist,
img->getHeight() / 2);
lines[i].angle = a;
lines[nPoints - 1 - i].pixels = img->Bresenham(img->getWidth() / 2, 0,
img->getWidth() / 2 + dist,
lines[nPoints - 1 - i].angle = a;
if(!even)
lines[nPoints / 2].pixels = img->Bresenham(img->getWidth() / 2, 0,
lines[nPoints / 2].angle = a;
// allocate device memory
cl_mem hDeviceMemLines, hDeviceMemPixelCoords;
hDeviceMemLines = clCreateBuffer(hContext, CL_MEM_READ_WRITE,
cnBlocks * sizeof(line), lines,
&err);
std::cout << "hDeviceMemLines clCreateBuffer... ";
showErrors(err);
err = clEnqueueWriteBuffer(hCmdQueue, hDeviceMemLines, CL_TRUE, 0,
cnBlocks * sizeof(line), lines, 0,
NULL, NULL);
std::cout << "hDeviceMemLines clEnqueueWriteBuffer... ";
showErrors(err);
hDeviceMemPixelCoords = clCreateBuffer(hContext, CL_MEM_READ_WRITE,
cnBlocks * sizeof(coord), 0,
&err);
std::cout << "hDeviceMemPixelCoords clCreateBuffer... ";
showErrors(err);
// setup parameter values
err = clSetKernelArg(hKernel, 0, sizeof(cl_mem),
(void *)&hDeviceMemLines);
std::cout << "hDeviceMemLines clSetKernelArg... ";
showErrors(err);
err = clSetKernelArg(hKernel, 1, sizeof(cameraParams),
(void *)¶ms);
std::cout << "params clSetKernelArg... ";
showErrors(err);
err = clSetKernelArg(hKernel, 2, sizeof(cl_mem),
(void *)&hDeviceMemPixelCoords);
std::cout << "hDeviceMemPixelCoords clSetKernelArg... ";
showErrors(err);
// execute kernel
err = clEnqueueNDRangeKernel(hCmdQueue, hKernel, 1, 0, &cnDimension,
NULL, 0, 0, 0);
std::cout << "clEnqueueNDRangeKernel... ";
showErrors(err);
err = clEnqueueReadBuffer(hCmdQueue, hDeviceMemPixelCoords, CL_TRUE,
0, cnBlocks * sizeof(coord),
(void *)pixelCoords, NULL, NULL, NULL);
std::cout << "hDeviceMemPixelCoords... ";
showErrors(err);
delete lines;
delete[] pixelCoords;
clReleaseMemObject(hDeviceMemLines);
clReleaseMemObject(hDeviceMemPixelCoords);
return 0;
}[/codebox]
For now i’m using opencl to get a picture. I checked if the lines were properly passed by making a copy of the lines and print it in the main and there was no problem (i.e all functions used return CL_SUCCESS).
I tryed to look everywhere, to use different way to implement this, but still i get this error :(
clGetPlatformIDs… OK
clGetDeviceIDs… OK
clCreateContext… OK
clCreateCommandQueue… OK
clCreateProgramWithSource… OK
clBuildProgram… OK
clCreateKernel… OK
hDeviceMemLines clCreateBuffer… OK
hDeviceMemLines clEnqueueWriteBuffer… OK
hDeviceMemPixelCoords clCreateBuffer… OK
hDeviceMemLines clSetKernelArg… OK
params clSetKernelArg… OK
hDeviceMemPixelCoords clSetKernelArg… OK
clEnqueueNDRangeKernel… OK
hDeviceMemPixelCoords clEnqueueReadBuffer… error : CL_OUT_OF_RESOURCES
The funny thing is that this function should not return this error…
I tryed to debug a bit the opencl code. When the findLaserPoint function is cut as
[codebox]coord findLaserPoint(line l)
coord point;
point.x = -1;
point.y = -1;
int index = -1;
uchar3 hls;
int before = 0;
continue;
return points
}[/codebox]
everything works well.
