clEnqueueNDRangeKernel() returns CL_OUT_OF_RESOURCES and I have no idea why
I’m trying to run my program, and it worked at first with these args. If I change the size of unifiedSrcValid, it may (or may not) return the CL_OUT_OF_RESOURCES error. I can’t find a reason why it wouldn’t work. I’m running on a GTX 285, so I should have plenty of GPU memory. My machine is a Mac Pro with 16 GB of RAM running 10.6.3. It gives the same error if I run it on the CPU vs the GPU.
Does anyone else get this error (or another error) with this code? Am I doing anything wrong?
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <OpenCL/opencl.h>
#define TRUE 1
#define FALSE 0
struct oclWarper {
	cl_command_queue queue;
	cl_context context;
	cl_kernel kern;
	cl_device_id dev;
	int srcWidth;
	int srcHeight;
	int dstWidth;
	int dstHeight;
	unsigned int xyChSize;
	cl_channel_order xyChOrder;
	unsigned int imgChSize;
	cl_channel_order imgChOrder;
	cl_channel_type imageFormat;
// Simple compute kernel which computes the square of an input array
const char *KernelSource = "\n"
"__kernel void resamp(read_only image2d_t srcCoords,\n"
					"read_only image2d_t srcReal,\n"
					"read_only image2d_t srcImag,\n"
					"__constant float *fUnifiedSrcDensity,\n"
					"__constant int *nUnifiedSrcValid,\n"
					"__constant char *useBandSrcValid,\n"
					"__constant int *nBandSrcValid,\n"
					"__global char *dstReal,\n"
					"__global char *dstImag,\n"
					"__constant float *fDstNoDataReal,\n"
					"__constant float *dstDensity,\n"
					"__constant int *nDstValid,\n"
					"const int bandNum)\n"
"{}\n";
#define handleErr(err) if((err) != CL_SUCCESS) { \
printf("Error at file %s line %d; Err val: %d\n", __FILE__, __LINE__, err); \
printCLErr(err); \
while(1){}\
return err; \
void printCLErr(cl_int err)
	switch (err)
		case CL_SUCCESS:
			printf("CL_SUCCESS\n");
			break;
		case CL_DEVICE_NOT_FOUND:
			printf("CL_DEVICE_NOT_FOUND\n");
			break;
		case CL_DEVICE_NOT_AVAILABLE:
			printf("CL_DEVICE_NOT_AVAILABLE\n");
			break;
		case CL_COMPILER_NOT_AVAILABLE:
			printf("CL_COMPILER_NOT_AVAILABLE\n");
			break;
		case CL_MEM_OBJECT_ALLOCATION_FAILURE:
			printf("CL_MEM_OBJECT_ALLOCATION_FAILURE\n");
			break;
		case CL_OUT_OF_RESOURCES:
			printf("CL_OUT_OF_RESOURCES\n");
			break;
		case CL_OUT_OF_HOST_MEMORY:
			printf("CL_OUT_OF_HOST_MEMORY\n");
			break;
		case CL_PROFILING_INFO_NOT_AVAILABLE:
			printf("CL_PROFILING_INFO_NOT_AVAILABLE\n");
			break;
		case CL_MEM_COPY_OVERLAP:
			printf("CL_MEM_COPY_OVERLAP\n");
			break;
		case CL_IMAGE_FORMAT_MISMATCH:
			printf("CL_IMAGE_FORMAT_MISMATCH\n");
			break;
		case CL_IMAGE_FORMAT_NOT_SUPPORTED:
			printf("CL_IMAGE_FORMAT_NOT_SUPPORTED\n");
			break;
		case CL_BUILD_PROGRAM_FAILURE:
			printf("CL_BUILD_PROGRAM_FAILURE\n");
			break;
		case CL_MAP_FAILURE:
			printf("CL_MAP_FAILURE\n");
			break;
		case CL_INVALID_VALUE:
			printf("CL_INVALID_VALUE\n");
			break;
		case CL_INVALID_DEVICE_TYPE:
			printf("CL_INVALID_DEVICE_TYPE\n");
			break;
		case CL_INVALID_PLATFORM:
			printf("CL_INVALID_PLATFORM\n");
			break;
		case CL_INVALID_DEVICE:
			printf("CL_INVALID_DEVICE\n");
			break;
		case CL_INVALID_CONTEXT:
			printf("CL_INVALID_CONTEXT\n");
			break;
		case CL_INVALID_QUEUE_PROPERTIES:
			printf("CL_INVALID_QUEUE_PROPERTIES\n");
			break;
		case CL_INVALID_COMMAND_QUEUE:
			printf("CL_INVALID_COMMAND_QUEUE\n");
			break;
		case CL_INVALID_HOST_PTR:
			printf("CL_INVALID_HOST_PTR\n");
			break;
		case CL_INVALID_MEM_OBJECT:
			printf("CL_INVALID_MEM_OBJECT\n");
			break;
		case CL_INVALID_IMAGE_FORMAT_DESCRIPTOR:
			printf("CL_INVALID_IMAGE_FORMAT_DESCRIPTOR\n");
			break;
		case CL_INVALID_IMAGE_SIZE:
			printf("CL_INVALID_IMAGE_SIZE\n");
			break;
		case CL_INVALID_SAMPLER:
			printf("CL_INVALID_SAMPLER\n");
			break;
		case CL_INVALID_BINARY:
			printf("CL_INVALID_BINARY\n");
			break;
		case CL_INVALID_BUILD_OPTIONS:
			printf("CL_INVALID_BUILD_OPTIONS\n");
			break;
		case CL_INVALID_PROGRAM:
			printf("CL_INVALID_PROGRAM\n");
			break;
		case CL_INVALID_PROGRAM_EXECUTABLE:
			printf("CL_INVALID_PROGRAM_EXECUTABLE\n");
			break;
		case CL_INVALID_KERNEL_NAME:
			printf("CL_INVALID_KERNEL_NAME\n");
			break;
		case CL_INVALID_KERNEL_DEFINITION:
			printf("CL_INVALID_KERNEL_DEFINITION\n");
			break;
		case CL_INVALID_KERNEL:
			printf("CL_INVALID_KERNEL\n");
			break;
		case CL_INVALID_ARG_INDEX:
			printf("CL_INVALID_ARG_INDEX\n");
			break;
		case CL_INVALID_ARG_VALUE:
			printf("CL_INVALID_ARG_VALUE\n");
			break;
		case CL_INVALID_ARG_SIZE:
			printf("CL_INVALID_ARG_SIZE\n");
			break;
		case CL_INVALID_KERNEL_ARGS:
			printf("CL_INVALID_KERNEL_ARGS\n");
			break;
		case CL_INVALID_WORK_DIMENSION:
			printf("CL_INVALID_WORK_DIMENSION\n");
			break;
		case CL_INVALID_WORK_GROUP_SIZE:
			printf("CL_INVALID_WORK_GROUP_SIZE\n");
			break;
		case CL_INVALID_WORK_ITEM_SIZE:
			printf("CL_INVALID_WORK_ITEM_SIZE\n");
			break;
		case CL_INVALID_GLOBAL_OFFSET:
			printf("CL_INVALID_GLOBAL_OFFSET\n");
			break;
		case CL_INVALID_EVENT_WAIT_LIST:
			printf("CL_INVALID_EVENT_WAIT_LIST\n");
			break;
		case CL_INVALID_EVENT:
			printf("CL_INVALID_EVENT\n");
			break;
		case CL_INVALID_OPERATION:
			printf("CL_INVALID_OPERATION\n");
			break;
		case CL_INVALID_GL_OBJECT:
			printf("CL_INVALID_GL_OBJECT\n");
			break;
		case CL_INVALID_BUFFER_SIZE:
			printf("CL_INVALID_BUFFER_SIZE\n");
			break;
		case CL_INVALID_MIP_LEVEL:
			printf("CL_INVALID_MIP_LEVEL\n");
			break;
		case CL_INVALID_GLOBAL_WORK_SIZE:
			printf("CL_INVALID_GLOBAL_WORK_SIZE\n");
			break;
int main(int argc, char** argv)
	cl_device_id device_id;			 // compute device id
	cl_context context;				 // compute context
	cl_command_queue commands;		  // compute command queue
	cl_program program;				 // compute program
	cl_kernel kernel;				   // compute kernel
	struct oclWarper warperStack;
	struct oclWarper *warper = &warperStack;
	cl_image_format imgFmt;
	warper->srcWidth = 2703;
	warper->srcHeight = 2685;
	warper->dstWidth = 2248;
	warper->dstHeight = 3086;
	warper->xyChSize = 4;
	warper->xyChOrder = 4277;
	warper->imgChOrder = 4280;
	warper->imageFormat = 4306;
	warper->imgChSize = 1;
	cl_int err = CL_SUCCESS;
	size_t numSrcPx = warper->srcWidth * warper->srcHeight;
	int validSrcSz = sizeof(int) * (1 + (numSrcPx >> 5));
	size_t numDstPx = warper->dstWidth * warper->dstHeight;
	cl_mem xy, unifiedSrcDensityCL, unifiedSrcValidCL;
	cl_mem dstDensityCL, dstValidCL, dstNoDataRealCL;
	cl_mem useBandSrcValidCL, nBandSrcValidCL;
	cl_mem srcImag, srcReal;
	cl_mem dstReal, dstImag;
	size_t ceil_runs[2];
	size_t group_size[2];
	int bandNum = 0;
	// Connect to a compute device
	int gpu = 0;
	err = clGetDeviceIDs(NULL, gpu ? CL_DEVICE_TYPE_GPU : CL_DEVICE_TYPE_CPU, 1, &device_id, NULL);
	if (err != CL_SUCCESS)
		printf("Error: Failed to create a device group!\n");
		return EXIT_FAILURE;
	// Create a compute context
	context = clCreateContext(0, 1, &device_id, NULL, NULL, &err);
	if (!context)
		printf("Error: Failed to create a compute context!\n");
	// Create a command commands
	commands = clCreateCommandQueue(context, device_id, 0, &err);
	if (!commands)
		printf("Error: Failed to create a command commands!\n");
	// Create the compute program from the source buffer
	program = clCreateProgramWithSource(context, 1, (const char **) & KernelSource, NULL, &err);
	if (!program)
		printf("Error: Failed to create compute program!\n");
	// Build the program executable
	err = clBuildProgram(program, 0, NULL, NULL, NULL, NULL);
		size_t len;
		char buffer[2048];
		printf("Error: Failed to build program executable!\n");
		clGetProgramBuildInfo(program, device_id, CL_PROGRAM_BUILD_LOG, sizeof(buffer), buffer, &len);
		printf("%s\n", buffer);
		exit(1);
	// Create the compute kernel in the program we wish to run
	kernel = clCreateKernel(program, "resamp", &err);
	if (!kernel || err != CL_SUCCESS)
		printf("Error: Failed to create compute kernel!\n");
		printCLErr(err);
		exit(1);
	warper->context = context;
	warper->queue = commands;
	warper->dev = device_id;
	warper->kern = kernel;
	//Copy coord data to the device
	imgFmt.image_channel_order = warper->xyChOrder;
	imgFmt.image_channel_data_type = CL_FLOAT;
	xy = clCreateImage2D(warper->context, CL_MEM_READ_ONLY, &imgFmt,
						 (size_t) warper->dstWidth, (size_t) warper->dstHeight,
						 (size_t) sizeof(float) * warper->xyChSize * warper->dstWidth,
						 NULL, &err);
	handleErr(err);
	//Set up argument
	handleErr(err = clSetKernelArg(warper->kern, 0, sizeof(cl_mem), &xy));
	//Set up image vars
	unifiedSrcDensityCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY,
										 sizeof(float) * numSrcPx, NULL, &err);
	handleErr(err);
	//Copy unifiedSrcValid if it exists
	if (FALSE) {
		//Alloc dummy device RAM
		unifiedSrcValidCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
		handleErr(err);
	} else {
		//Alloc & copy all validity data
										   validSrcSz, NULL, &err);
		handleErr(err);
	//Make a fake image so we don't have a NULL pointer
	useBandSrcValidCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
	handleErr(err);
	nBandSrcValidCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
	handleErr(err);
	//Set up arguments
	handleErr(err = clSetKernelArg(warper->kern, 3, sizeof(cl_mem), &unifiedSrcDensityCL));
	handleErr(err = clSetKernelArg(warper->kern, 4, sizeof(cl_mem), &unifiedSrcValidCL));
	handleErr(err = clSetKernelArg(warper->kern, 5, sizeof(cl_mem), &useBandSrcValidCL));
	handleErr(err = clSetKernelArg(warper->kern, 6, sizeof(cl_mem), &nBandSrcValidCL));
	//Set up image vars
	imgFmt.image_channel_order = warper->imgChOrder;
	imgFmt.image_channel_data_type = warper->imageFormat;
	srcReal = clCreateImage2D(warper->context, CL_MEM_READ_ONLY, &imgFmt,
							  (size_t) warper->srcWidth, (size_t) warper->srcHeight,
							  warper->srcWidth * warper->imgChSize * sizeof(char),
							  NULL, &err);
	handleErr(err);
	srcImag = clCreateImage2D(warper->context, CL_MEM_READ_ONLY, &imgFmt,
							  1, 1, warper->imgChSize * sizeof(char), NULL, &err);
	handleErr(err);
	//Set up per-band arguments
	handleErr(err = clSetKernelArg(warper->kern, 1, sizeof(cl_mem), &srcReal));
	handleErr(err = clSetKernelArg(warper->kern, 2, sizeof(cl_mem), &srcImag));
	//Make dummy memory
	dstReal = clCreateBuffer(warper->context, CL_MEM_READ_WRITE,
							 numDstPx * warper->imgChSize * sizeof(char), NULL, &err);
	handleErr(err);
	dstImag = clCreateBuffer(warper->context, CL_MEM_READ_WRITE, 1, NULL, &err);
	handleErr(err);
	handleErr(err = clSetKernelArg(warper->kern, 7, sizeof(cl_mem), &dstReal));
	handleErr(err = clSetKernelArg(warper->kern, 8, sizeof(cl_mem), &dstImag));
	//Make dummy memory
	dstNoDataRealCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
	handleErr(err);
	dstDensityCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
	handleErr(err);
	dstValidCL = clCreateBuffer(warper->context, CL_MEM_READ_ONLY, 1, NULL, &err);
	handleErr(err);
	//Set up arguments
	handleErr(err = clSetKernelArg(warper->kern,  9, sizeof(cl_mem), &dstNoDataRealCL));
	handleErr(err = clSetKernelArg(warper->kern, 10, sizeof(cl_mem), &dstDensityCL));
	handleErr(err = clSetKernelArg(warper->kern, 11, sizeof(cl_mem), &dstValidCL));
	handleErr(err = clSetKernelArg(warper->kern, 12, sizeof(int), &bandNum));
	ceil_runs[0] = 1;
	ceil_runs[1] = 1;
	group_size[0] = 1;
	group_size[1] = 1;
	handleErr(err = clEnqueueNDRangeKernel(warper->queue, warper->kern, 2, NULL,
										   ceil_runs, group_size, 0, NULL, NULL));
	return 0;
Hey all, I figured it out. I’m overusing ‘__constant’. I removed the ‘__constant’ qualifiers on the larger arrays in the kernel and it works fine now.
