Basic LED Example with Jetson AGX Orin
Hello, I was wondering if anyone knows a good resource to start my first led blink example with the jetson orin. Currently, I am using this code but it does not seem to be working with the defined pins. I am also using Jetpack 6. Any guidance would be greatly appreciated!
# GPIO library
import Jetson.GPIO as GPIO
# Handles time
import time
# Pin Definition
led_pin = 7
# Set up the GPIO channel
GPIO.setmode(GPIO.BOARD)
GPIO.setup(led_pin, GPIO.OUT, initial = GPIO.HIGH)
print ( "Press CTRL+C when you want the LED to stop blinking" )
# Blink the LED
while True :
time.sleep( 2 )
GPIO.output(led_pin, GPIO.HIGH)
print ( "LED is ON" )
time.sleep( 2 )
GPIO.output(led_pin, GPIO.LOW)
print ( "LED is OFF" )
Hi cbso,
Are you using Jetpack 6 DP(r36.2) or Jetpack 6 GA(R36.3)?
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
Which pin would you like to use to connect with LED?
Hi. When I do the command you suggested, I get this output:
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
I believe this is Jetpack 6 GA(R36.3). Additionally, my led is connected to physical pin 7.
Do you mean the PIN7 of 40-pin header as following?
If so, this pin is configured as Input/PD in pinmux spreadsheet by default.
Please configure it as Output/Drive 0 instead
After applying the change for pinmux, please run the following commands to control it HIGH.
$ sudo su
# gpioset --mode=wait `gpiofind "PQ.06"`=1
There’s another thread discussing about this, you can also refer to it.
Issue with GPIO on Jetson Orin Nano with Jetpack 6 - #9 by KevinFFF
