Batched cublas matrix inverses with matrices stored in a derived type
I am using cublas with nvfortran to calculate batched matrix inverses and determinants. I am using nvfortran 25.7-0 64-bit target on x86-64 Linux -tp haswell
I have a set of different classes which can have different dimensions and batch sizes. I would like to be able to store the matrices, and their inverses, and the device pointers needed by cublas in these derived types.
Currently, if I define them as module arrays in the same module with the classes, the inverse works fine, but only one class can use these arrays. I think there may be more than one problem, but to start, a minimal test code is below. This code is able to have the matrices and their stored inverses in the derived type, but trying to move the pointers to device arrays in the derived type fails. My full code is also unable to work with the matrices in the derived type.
Here I get a compiler error if I compile with -DFAILS.
$nvfortran -cuda cmat.F90 -DFAILS
Lowering Error: symbol dp_smat_d$sd is an inconsistent array descriptor
Lowering Error: symbol dp_smati_d$sd is an inconsistent array descriptor
NVFORTRAN-F-0000-Internal compiler error. Errors in Lowering 8 (cmat.F90: 119)
NVFORTRAN/x86-64 Linux 25.7-0: compilation aborted
Compiling with no defines uses pointer variables not in the defined type and gives the correct inverses as tested by multiplying them together and comparing with the unit matrix.
$./a.out
max inverse error 5.1636710387543281E-014
Here is the test code
module precision
   use, intrinsic :: iso_fortran_env
   implicit none
   integer, public, parameter :: i4=int32
   integer, public, parameter :: i8=int64
   integer, public, parameter :: r8=real64
   complex(kind=r8), public, parameter :: czero=(0.0_r8,0.0_r8)
   complex(kind=r8), public, parameter :: ci=(0.0_r8,1.0_r8)
   complex(kind=r8), public, parameter :: cone=(1.0_r8,0.0_r8)
end module precision
   program cmattest
   use cudafor
   use cublas_v2
   use, intrinsic :: iso_c_binding
   use precision
   implicit none
!host
   integer(kind=i4) :: istat,nbatch,i,iwf,id
   type(c_devptr), allocatable :: hp_smat_d(:,:),hp_smati_d(:,:)
   complex(kind=r8), allocatable :: smat_h(:,:,:,:),smati_h(:,:,:,:)
   complex(kind=r8), allocatable :: test(:,:)
   real(kind=r8) :: err
   integer, allocatable :: seed(:)
   integer :: seedsize
   type(cublasHandle) :: h
   type :: t_test
      integer(kind=i4) :: npart,ndet,nwf
      complex(kind=r8), device, allocatable :: smat_d(:,:,:,:),smati_d(:,:,:,:)
      integer(kind=i4), device, allocatable :: ipvt_d(:,:,:),info_d(:,:)
      type(c_devptr), device, allocatable :: dp_smat_d(:,:),dp_smati_d(:,:)
   end type
   type(t_test) :: m
!device for working version
!set up random number generator
   call random_seed(size=seedsize)
   allocate(seed(seedsize))
   seed=17171717
   call random_seed(put=seed)
!problem size
   m%npart=16
   m%ndet=3
   m%nwf=97
   nbatch=m%nwf*m%ndet
! host allocate
   allocate(hp_smat_d(m%ndet,m%nwf),hp_smati_d(m%ndet,m%nwf))
   allocate(smat_h(m%npart,m%npart,m%ndet,m%nwf))
   allocate(smati_h(m%npart,m%npart,m%ndet,m%nwf))
   allocate(test(m%npart,m%npart))
! fill input matrices with random values for test
   smat_h=reshape(cr(m%npart**2*m%ndet*m%nwf),shape(smat_h))
! device allocate with and without derived type
   allocate(m%dp_smat_d(m%ndet,m%nwf),m%dp_smati_d(m%ndet,m%nwf))
   allocate(m%smat_d(m%npart,m%npart,m%ndet,m%nwf))
   allocate(m%smati_d(m%npart,m%npart,m%ndet,m%nwf))
   allocate(m%ipvt_d(m%npart,m%ndet,m%nwf),m%info_d(m%ndet,m%nwf))
! need these to avoid compile errors
   allocate(dp_smat_d(m%ndet,m%nwf),dp_smati_d(m%ndet,m%nwf))
! transfer to device
   m%smat_d=smat_h
! create cublas handle
   istat=cublasCreate(h)
   if (istat.ne.0) write (*,*) 'cuda error',istat
   istat = cudaDeviceSynchronize()
! set up pointers needed by cublas_v2
   do iwf=1,m%nwf
      do id=1,m%ndet
         hp_smat_d(id,iwf)=c_devloc(m%smat_d(1,1,id,iwf))
         hp_smati_d(id,iwf)=c_devloc(m%smati_d(1,1,id,iwf))
      enddo
   enddo
#if defined(FAILS)
   m%dp_smat_d=hp_smat_d
   m%dp_smati_d=hp_smati_d
! batched lu decomposition
   istat=cublasZgetrfBatched(h,m%npart,m%dp_smat_d,m%npart,m%ipvt_d &
      ,m%info_d,nbatch)
! batched inverse from lu
   istat=cublasZgetriBatched(h,m%npart,m%dp_smat_d,m%npart,m%ipvt_d &
     ,m%dp_smati_d,m%npart,m%info_d,nbatch)
#else
   dp_smat_d=hp_smat_d
   istat=cublasZgetrfBatched(h,m%npart,dp_smat_d,m%npart,m%ipvt_d &
      ,m%info_d,nbatch)
   istat=cublasZgetriBatched(h,m%npart,dp_smat_d,m%npart,m%ipvt_d &
     ,dp_smati_d,m%npart,m%info_d,nbatch)
#endif
   smati_h=m%smati_d
   smati_h=m%smati_d
   err=0.0_r8
   do iwf=1,m%nwf
      do id=1,m%ndet
         test=matmul(smat_h(:,:,id,iwf),smati_h(:,:,id,iwf))
         do i=1,m%npart
            test(i,i)=test(i,i)-cone
         enddo
         err=max(err,maxval(abs(test)))
      enddo
   enddo
   write (*,*) 'max inverse error ',err
! clean up
   istat=cublasDestroy(h)
   contains
      function cr(n)
      integer(kind=i4) :: n,i
      complex(kind=r8) :: cr(n)
      real :: r1(n),r2(n)
      call random_number(r1)
      call random_number(r2)
      cr=(r1-0.5)+ci*(r2-0.5)
      end function cr
      function rr(n)
      real(kind=r8) :: rr(n)
      real :: r1(n)
      rr=r1
      end function rr
   end program cmattest
Hi Kevin,
Thanks for the report and reproducing example. I was able to get the same error here so filed a problem report, TPR #37865, and sent it to engineer for review.
Unfortunately, I don’t have a better work around than what you already have.
-Mat
I think I have found a workaround to this problem, but I need to run more tests. Changing the c_devptr in the derived type from allocatable to pointer seems to be working. That is I changed
type :: t_test
   end type
to
   type :: t_test
      type(c_devptr), pointer, device :: dp_smat_d(:,:),dp_smati_d(:,:)
   end type
and I get the correct inverses.
Just to update this for anyone else with the same sort of problem, for my actual code with a more complex class structure, I also needed to change the two arrays, pointed to by the c_devptr, to pointers. In my test code the t_test type needs to be:
   type :: t_test
      complex(kind=r8), device, pointer :: smat_d(:,:,:,:),smati_d(:,:,:,:)
      type(c_devptr), device, pointer :: dp_smat_d(:,:),dp_smati_d(:,:)
   end type
which makes my full code work properly.
