Hello, hope you are having a good day…
I have a problem calling CUBLAS functions, as I am clueless to how they are called in fortran.
I have followed the way CULA routines were followed and read the advice from the “CUDA Library Interfaces” pdf.
However, the rest does not come intuitively with me.
I am trying to get the inverse of Matrix A (using cublasDgetriBatched and cublasDgetrfBatched) which its dimension and cell values are called from a text file.
The code is bellow and I get this error… “PGF90-S-0148-Reference to derived type required (inverse.cuf: 43)”
Could you kindly give me an example that uses a similar function… the “isamax” example in the pdf is quite easy to understand yet different.
I am grateful for any help.
Ahmed
! Compile with "pgfortran -Mlarge_arrays inverse.cuf -Mcudalib=cublas -lblas"
PROGRAM MatrixInverse
use cudafor
use cublas
use iso_c_binding
IMPLICIT NONE
CHARACTER*1000 infile,outfile
type(c_devptr),ALLOCATABLE, device :: A(:,:),C(:,:)
INTEGER,ALLOCATABLE, device :: ipiv(:)
INTEGER istat, status
type(cublasHandle) :: h
INTEGER :: n
INTEGER :: lda
INTEGER :: ldc
INTEGER, device :: info(:)
INTEGER :: batchCount
INTEGER DI, I, J
Real time1,time2
DOUBLE PRECISION,ALLOCATABLE :: mat(:,:)
! input file names from $INV$
OPEN(5,FILE='$INV$')
READ(5,'(A)') infile
READ(5,'(A)') outfile
close(5)
! input matrix data to be inversed
OPEN(1,FILE=infile)
READ(1,*) DI
n=DI
lda=DI
ldc=DI
write(*,*) 'Matrix size is : ',DI,'x',DI
ALLOCATE(mat(DI,DI))
DO I=1,DI
DO J=1,DI
READ(1,*)mat(I,J)
END DO
END DO
close(1)
! Allocate
Allocate (A(DI,DI))
Allocate (C(DI,DI))
A = mat
! initialize cublas
print *, 'Cublas starts'
! cublas SOLVES
allocate(ipiv(DI))
open (99, file='Inverse_GPU_Time.txt',status='unknown')
! start
call CPU_Time(time1)
print *, 'Starting CUBLAS (Host interface)'
status = cublasCreate(h)
! call cublas
status = cublasDgetrfBatched(h, DI, A, DI, ipiv, info,batchCount)
status = cublasDgetriBatched(h, DI, A, DI, ipiv, C, DI,info, batchCount)
! stop
mat = A
status=cudaDeviceSynchronize()
call CPU_Time(time2)
write(99,*) 'Time spent GPU: ', time2-time1
OPEN(4,FILE=outfile)
DO 6 I=1,DI
DO 7 J=1,DI
write(4,*)mat(I,J)
7 END DO
6 END DO
status = cublasDestroy(h)
close(4)
END
