Dear all;
I had downloaded this code for the batcher odd even merge sort, how can I run this method, specifically what are the means of the method parameters?
* Copyright 1993-2012 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
//Based on http://www.iti.fh-flensburg.de/lang/algorithmen/sortieren/networks/oemen.htm
#include <assert.h>
#include <helper_cuda.h>
#include "sortingNetworks_common.h"
#include "sortingNetworks_common.cuh"
// Monolithic Bacther's sort kernel for short arrays fitting into shared memory
__global__ void oddEvenMergeSortShared(
uint *d_DstKey,
uint *d_DstVal,
uint *d_SrcKey,
uint *d_SrcVal,
uint arrayLength,
uint dir
//Shared memory storage for one or more small vectors
__shared__ uint s_key[SHARED_SIZE_LIMIT];
__shared__ uint s_val[SHARED_SIZE_LIMIT];
//Offset to the beginning of subbatch and load data
d_SrcKey += blockIdx.x * SHARED_SIZE_LIMIT + threadIdx.x;
d_SrcVal += blockIdx.x * SHARED_SIZE_LIMIT + threadIdx.x;
d_DstKey += blockIdx.x * SHARED_SIZE_LIMIT + threadIdx.x;
d_DstVal += blockIdx.x * SHARED_SIZE_LIMIT + threadIdx.x;
s_key[threadIdx.x + 0] = d_SrcKey[ 0];
s_val[threadIdx.x + 0] = d_SrcVal[ 0];
s_key[threadIdx.x + (SHARED_SIZE_LIMIT / 2)] = d_SrcKey[(SHARED_SIZE_LIMIT / 2)];
s_val[threadIdx.x + (SHARED_SIZE_LIMIT / 2)] = d_SrcVal[(SHARED_SIZE_LIMIT / 2)];
for (uint size = 2; size <= arrayLength; size <<= 1)
uint stride = size / 2;
uint offset = threadIdx.x & (stride - 1);
__syncthreads();
uint pos = 2 * threadIdx.x - (threadIdx.x & (stride - 1));
Comparator(
s_key[pos + 0], s_val[pos + 0],
s_key[pos + stride], s_val[pos + stride],
dir
stride >>= 1;
for (; stride > 0; stride >>= 1)
__syncthreads();
if (offset >= stride)
Comparator(
s_key[pos - stride], s_val[pos - stride],
dir
__syncthreads();
d_DstKey[ 0] = s_key[threadIdx.x + 0];
d_DstVal[ 0] = s_val[threadIdx.x + 0];
d_DstKey[(SHARED_SIZE_LIMIT / 2)] = s_key[threadIdx.x + (SHARED_SIZE_LIMIT / 2)];
d_DstVal[(SHARED_SIZE_LIMIT / 2)] = s_val[threadIdx.x + (SHARED_SIZE_LIMIT / 2)];
// Odd-even merge sort iteration kernel
// for large arrays (not fitting into shared memory)
__global__ void oddEvenMergeGlobal(
uint *d_DstKey,
uint *d_DstVal,
uint *d_SrcKey,
uint *d_SrcVal,
uint arrayLength,
uint size,
uint stride,
uint dir
uint global_comparatorI = blockIdx.x * blockDim.x + threadIdx.x;
//Odd-even merge
uint pos = 2 * global_comparatorI - (global_comparatorI & (stride - 1));
if (stride < size / 2)
uint offset = global_comparatorI & ((size / 2) - 1);
uint keyA = d_SrcKey[pos - stride];
uint valA = d_SrcVal[pos - stride];
uint keyB = d_SrcKey[pos + 0];
uint valB = d_SrcVal[pos + 0];
Comparator(
keyA, valA,
keyB, valB,
dir
d_DstKey[pos - stride] = keyA;
d_DstVal[pos - stride] = valA;
d_DstKey[pos + 0] = keyB;
d_DstVal[pos + 0] = valB;
else
uint keyA = d_SrcKey[pos + 0];
uint valA = d_SrcVal[pos + 0];
uint keyB = d_SrcKey[pos + stride];
uint valB = d_SrcVal[pos + stride];
Comparator(
keyA, valA,
keyB, valB,
dir
d_DstKey[pos + 0] = keyA;
d_DstVal[pos + 0] = valA;
d_DstKey[pos + stride] = keyB;
d_DstVal[pos + stride] = valB;
// Interface function
//Helper function
extern "C" uint factorRadix2(uint *log2L, uint L);
extern "C" void oddEvenMergeSort(
uint *d_DstKey,
uint *d_DstVal,
uint *d_SrcKey,
uint *d_SrcVal,
uint batchSize,
uint arrayLength,
uint dir
//Nothing to sort
if (arrayLength < 2)
return;
//Only power-of-two array lengths are supported by this implementation
uint log2L;
uint factorizationRemainder = factorRadix2(&log2L, arrayLength);
assert(factorizationRemainder == 1);
dir = (dir != 0);
uint blockCount = (batchSize * arrayLength) / SHARED_SIZE_LIMIT;
uint threadCount = SHARED_SIZE_LIMIT / 2;
if (arrayLength <= SHARED_SIZE_LIMIT)
assert(SHARED_SIZE_LIMIT % arrayLength == 0);
oddEvenMergeSortShared<<<blockCount, threadCount>>>(d_DstKey, d_DstVal, d_SrcKey, d_SrcVal, arrayLength, dir);
else
oddEvenMergeSortShared<<<blockCount, threadCount>>>(d_DstKey, d_DstVal, d_SrcKey, d_SrcVal, SHARED_SIZE_LIMIT, dir);
for (uint size = 2 * SHARED_SIZE_LIMIT; size <= arrayLength; size <<= 1)
for (unsigned stride = size / 2; stride > 0; stride >>= 1)
//Unlike with bitonic sort, combining bitonic merge steps with
//stride = [SHARED_SIZE_LIMIT / 2 .. 1] seems to be impossible as there are
//dependencies between data elements crossing the SHARED_SIZE_LIMIT borders
oddEvenMergeGlobal<<<(batchSize * arrayLength) / 512, 256>>>(d_DstKey, d_DstVal, d_DstKey, d_DstVal, arrayLength, size, stride, dir);
Framed Display Ad
