what is the best way to gain accsess to a buffer without using memcpy?
NvBufferMemMap (fd, 0, NvBufferMem_Read,
&mapped_ptr) != 0)
using NvBufferMemMap only allows cpu accsess
&mapped_ptr) != 0)
You may try nvivafilter:
https://devtalk.nvidia.com/default/topic/963123/jetson-tx1/video-mapping-on-jetson-tx1/post/4979740/#4979740
https://devtalk.nvidia.com/default/topic/978438/jetson-tx1/optimizing-access-to-image-data-acquired-with-nvcamerasrc/post/5026998/#5026998
https://devtalk.nvidia.com/default/topic/1046218/jetson-tx2/unable-to-overlay-text-when-using-udpsrc-/post/5310313/#5310313
https://devtalk.nvidia.com/default/topic/1022543/jetson-tx2/gstreamer-nvmm-lt-gt-opencv-gpumat/post/5311027/#5311027
In our case, we get a cudaEglFrame from the file descriptor. This contains pointers that can be used on GPU and avoids memory copies if the buffer is on shared memory. The steps are:
We provide an out of the box solution for CUDA algorithm integration into GStreamer pipelines called GstCUDA. Please check our wiki page if you are interested on GstCUDA:
https://developer.ridgerun.com/wiki/index.php?title=GstCUDA
I have followed your advice and the linked you provided. with the example code
input_params.width = 1000;
input_params.height = 1000;
input_params.layout = NvBufferLayout_Pitch;
input_params.colorFormat = NvBufferColorFormat_ABGR32;
input_params.payloadType = NvBufferPayload_SurfArray;
input_params.nvbuf_tag = NvBufferTag_NONE;
NvBufferCreateEx (&mobileplugin->conv_dmabuf_fd, &input_params) ;
static EGLDisplay egl_display = EGL_NO_DISPLAY;
EGLImageKHR egl_image;
// Init egl_display if not initialized
if (egl_display == EGL_NO_DISPLAY) {
egl_display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
flow_ret = GST_FLOW_ERROR;
goto done;
// Create an EGLImage from the FD
egl_image = NvEGLImageFromFd (egl_display, mobileplugin->conv_dmabuf_fd);
if (!egl_image) {
goto done;
but i am getting NvEGLImageFromFd: Failed to create EGLImage from dma-buf fd (1265) error
what am i missing ? what can cause this error?
Can you please share a full code so that we can build and run to reproduce the error? Are you on r28.2/TX1?
