Extracting GPU pointer from gstreamer output file (multifilesink)
I am trying to get the gpu pointer from the output file generated by gstreamer (1008 bytes struct).
This is what I’m doing:
  1. I run the following command to generate the files:
gst-launch-1.0 filesrc location=file.mp4 ! decodebin ! videorate max-rate=4 ! multifilesink location="/tmp/frame%d.buffer"
  1. I read the buffer (1008 bytes) from file and extract the file descriptor:
FILE* fp = fopen("/tmp/frame0.buffer", "rb");
void* buff = malloc(1008);
fread(buff, 1008, 1, fp);
ExtractFdFromNvBuffer(buff, &dmabuf_fd);
  1. I extracted the parameters and printed the values:
NvBufferParams par;
NvBufferGetParams(dmabuf_fd, &par);
I can see that the par.width, par.height matches the source video resolution (file.mp4).
  1. I tried to get EGLImage from FD but it fails:
EGLImageKHR egl_image = NvEGLImageFromFd(NULL, dmabuf_fd);
But I get the following error:
NvEGLImageFromFd: Failed to create EGLImage from dma-buf fd (1066)
(dmabuf_fd = 1066 in this example)
I also tried this, but I got the same error:
static EGLDisplay egl_display = EGL_NO_DISPLAY;
if (egl_display == EGL_NO_DISPLAY)
    egl_display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
        exit(-1);
EGLImageKHR egl_image = NvEGLImageFromFd(egl_display, dmabuf_fd);
What am I doing wrong?
It is information to the buffer, not real YUV data. You would need to call ExtractFdFromNvBuffer() when running the application. For saving to a file, you would need to save the real YUV data.
Hi DaneLL, thank you!
I called ExtractFdFromNvBuffer() in step 2, and I was able to retrieve the file descriptor, but it fails to create the EGLImage from the retrieved descriptor.
If I understand correctly, what I saved only contains information to the buffer, and there is no way to extract a GPU pointer from it since it holds no real data?!
We generally access NvBuffer in appsink. Please refer to
Gstreamer pipeline using nvv4l2h264enc to write from shared memory - #6 by DaneLLL
For dumping YUV data to a file, please try to link the pipeline like
… ! nvv4l2decoder ! nvvidconv ! video/x-raw ! multifilesink
Thank you, actually I was using the decoder.cpp, modified it so that I get the NvBuffer from file, but as you said it only holds information about the buffer with no real data.
