poorpong_nvmm.cpp
#include <cstdlib>
#include <gst/gst.h>
#include <gst/gstinfo.h>
#include <gst/app/gstappsrc.h>
#include <glib-unix.h>
#include <dlfcn.h>
#include <stropts.h>
#include <poll.h>
#include <cstring>
#include <iostream>
#include <sstream>
#include <thread>
#include <vector>
#include "nvbuf_utils.h"
#include <cuda.h>
#include <cuda_runtime.h>
#include <cudaEGL.h>
#include "X11/Xlib.h"
#include <opencv2/core.hpp>
#include <opencv2/core/cuda.hpp>
#include "opencv2/imgproc.hpp"
#include "opencv2/highgui.hpp"
using namespace std;
#define USE(x) ((void)(x))
typedef struct {
int left_bar_ypos;
int ball_xpos;
int ball_ypos;
int digits_xpos;
int count10_idx;
int count1_idx;
} pongDisplayData;
const int frame_width = 1920;
const int frame_height = 1080;
const int ball_size = 50;
const int initial_speed = 30;
const int bar_width = 50;
const int bar_height = 300;
const int digit_height=200;
const int digit_width=(digit_height*60)/100;
// R, G, B, A
const cv::Scalar background_color(0,0,255,255);
const cv::Scalar ball_color(255,255,0,255);
const cv::Scalar bar_color(255,0,0,255);
const cv::Scalar digits_color(0,255,0,255);
static GstPipeline *gst_pipeline = nullptr;
static string launch_string;
static GstElement *appsrc_;
GstClockTime timestamp = 0;
EGLDisplay egl_display;
static int display_w;
static int display_h;
static int GetPointer_Y (Display *display, Window *root_window) {
Window r, c;
int x, y, rx, ry;
unsigned int m;
bool b = XQueryPointer(display, *root_window, &r, &c, &rx, &ry, &x, &y, &m);
if (b) {
// Scale from display to frame
return (int)((frame_height - bar_height)*(y/(double)display_h));
else
return (-1);
static cv::cuda::GpuMat d_ball_mask(ball_size, ball_size, CV_8UC1);
static cv::cuda::GpuMat d_bar_mask(bar_height, bar_width, CV_8UC1);
static std::vector< cv::cuda::GpuMat > d_numbers_mask(10);
static void PrepareMasks(void)
// Bar mask
cv::Mat h_bar_mask = cv::Mat(bar_height, bar_width, CV_8UC1);
h_bar_mask.setTo(cv::Scalar(255));
d_bar_mask.upload(h_bar_mask);
// Ball mask
cv::Mat h_ball_mask = cv::Mat::zeros(ball_size, ball_size, CV_8UC1);
cv::circle(h_ball_mask, cv::Point(ball_size/2, ball_size/2), ball_size/2, cv::Scalar(255), cv::FILLED, 8, 0);
d_ball_mask.upload(h_ball_mask);
// [0-9] digits masks
for(unsigned int i=0; i <10; ++i)
char buf[2];
sprintf(buf, "%d", i);
cv::Mat h_digit_mask = cv::Mat::zeros(digit_height, digit_width, CV_8UC1);
cv::putText (h_digit_mask, buf, cv::Point (0,digit_width), cv::FONT_HERSHEY_SIMPLEX, digit_height/40, cv::Scalar(255), digit_height/10);
d_numbers_mask[i].upload(h_digit_mask);
static void notify_to_destroy (gpointer user_data)
GST_INFO ("NvBufferDestroy(%d)", *(int *)user_data);
NvBufferDestroy(*(int *)user_data);
g_free(user_data);
static gboolean feed_function(gpointer d) {
GstBuffer *buffer;
GstFlowReturn ret;
GstMapInfo map = {0};
int dmabuf_fd = 0;
gpointer data = NULL, user_data = NULL;
NvBufferParams par;
GstMemoryFlags flags = (GstMemoryFlags)0;
static int frame_num=0;
NvBufferCreate(&dmabuf_fd, frame_width, frame_height, NvBufferLayout_Pitch, NvBufferColorFormat_ABGR32);
//CUDA process
EGLImageKHR egl_image;
egl_image = NvEGLImageFromFd(egl_display, dmabuf_fd);
CUresult status;
CUeglFrame eglFrame;
CUgraphicsResource pResource = NULL;
cudaFree(0);
status = cuGraphicsEGLRegisterImage(&pResource,
egl_image,
CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
if (status != CUDA_SUCCESS)
printf("cuGraphicsEGLRegisterImage failed: %d \n",status);
status = cuGraphicsResourceGetMappedEglFrame(&eglFrame, pResource, 0, 0);
status = cuCtxSynchronize();
// CUDA code here
cv::cuda::GpuMat dmat(frame_height, frame_width,CV_8UC4,eglFrame.frame.pPitch[0]);
pongDisplayData *data = (pongDisplayData*) d;
// Set background
dmat.setTo(background_color);
// Draw Count digits
cv::cuda::GpuMat roi(dmat, cv::Rect(cv::Point(data->digits_xpos, 10), cv::Size(digit_width, digit_height)));
roi.setTo(digits_color, d_numbers_mask[data->count10_idx]);
cv::cuda::GpuMat roi(dmat, cv::Rect(cv::Point(data->digits_xpos + digit_width, 10), cv::Size(digit_width, digit_height)));
roi.setTo(digits_color, d_numbers_mask[data->count1_idx]);
// Draw left bar
cv::cuda::GpuMat roi(dmat, cv::Rect(cv::Point(50, data->left_bar_ypos), cv::Size(bar_width, bar_height)));
roi.setTo(bar_color, d_bar_mask);
// Draw ball
cv::cuda::GpuMat roi(dmat, cv::Rect(data->ball_xpos, data->ball_ypos, ball_size, ball_size));
roi.setTo(ball_color, d_ball_mask);
// Safety check
if (dmat.data != eglFrame.frame.pPitch[0])
fprintf (stderr, "Error: re-allocated dmat\n");
status = cuGraphicsUnregisterResource(pResource);
NvDestroyEGLImage(egl_display, egl_image);
user_data = g_malloc(sizeof(int));
GST_INFO ("NvBufferCreate %d", dmabuf_fd);
*(int *)user_data = dmabuf_fd;
NvBufferGetParams (dmabuf_fd, &par);
data = g_malloc(par.nv_buffer_size);
buffer = gst_buffer_new_wrapped_full(flags,
data,
par.nv_buffer_size,
0,
par.nv_buffer_size,
user_data,
notify_to_destroy);
GST_BUFFER_PTS(buffer) = timestamp;
GST_BUFFER_DTS(buffer) = timestamp;
GST_BUFFER_OFFSET(buffer) = frame_num++;
GST_BUFFER_DURATION(buffer) = ((double)1/30) * GST_SECOND;
gst_buffer_map (buffer, &map, GST_MAP_WRITE);
memcpy(map.data, par.nv_buffer, par.nv_buffer_size);
gst_buffer_unmap(buffer, &map);
g_signal_emit_by_name (appsrc_, "push-buffer", buffer, &ret);
gst_buffer_unref(buffer);
// Free pongDisplayData
g_free(d);
timestamp += 33333333;
return G_SOURCE_CONTINUE;
typedef struct {
int count;
int left_bar_ypos;
int left_bar_yspeed;
int ball_xpos;
int ball_ypos;
int ball_xspeed;
int ball_yspeed;
} pongCtrlData;
int PoorPongController_onePlayer(pongCtrlData& ctrlData) {
// ball projection for next step
int ball_xnext = ctrlData.ball_xpos + ctrlData.ball_xspeed;
int ball_ynext = ctrlData.ball_ypos + ctrlData.ball_yspeed;
if ((ball_xnext < 50 + bar_width) && (ball_ynext + ball_size > ctrlData.left_bar_ypos) && (ball_ynext < ctrlData.left_bar_ypos + bar_height)) {
// Ball is in bar zone... reverse xspeed
ctrlData.ball_xspeed = -ctrlData.ball_xspeed;
// Set new xpos
ctrlData.ball_xpos = 50 + (ctrlData.ball_xpos - ball_xnext);
// Add 50% of bar yspeed
ctrlData.ball_yspeed += (int)(0.5*ctrlData.left_bar_yspeed);
// Increase count ane both speeds with 10%
++ctrlData.count;
ctrlData.ball_xspeed = (int)(1.1*ctrlData.ball_xspeed);
ctrlData.ball_yspeed = (int)(1.1*ctrlData.ball_yspeed);
else if (ball_xnext < 0) {
// Ball reached left of the frame...Game over
return -1;
else if ((ball_xnext > frame_width - ball_size) || (ball_xnext < 0)) {
// Ball reached right of the frame... reverse xspeed
else {
// Ball moved on x, update
ctrlData.ball_xpos = ball_xnext;
if ((ball_ynext > frame_height - ball_size) || (ball_ynext < 0)) {
// Ball reached top or bottom of the frame... reverse yspeed
ctrlData.ball_yspeed = -ctrlData.ball_yspeed;
else {
// Ball moved on y, update
ctrlData.ball_ypos = ball_ynext;
return 0;
int main(int argc, char** argv) {
USE(argc);
USE(argv);
Display *display;
display = XOpenDisplay(0);
display_w = DisplayWidth(display, 0);
display_h = DisplayHeight(display, 0);
Window root_window;
root_window = XRootWindow(display, 0);
egl_display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
eglInitialize(egl_display, NULL, NULL);
PrepareMasks();
gst_init (&argc, &argv);
GMainLoop *main_loop;
main_loop = g_main_loop_new (NULL, FALSE);
ostringstream launch_stream;
launch_stream
<< "appsrc name=mysource ! "
<< "video/x-raw(memory:NVMM),width="<< frame_width <<",height="<< frame_height <<",framerate=30/1,format=RGBA ! "
<< "nvegltransform ! nveglglessink";
//<< "nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! nvoverlaysink";
//<< "nvvidconv ! video/x-raw(memory:NVMM),format=NV12 ! nv3dsink";
//<< "nvvidconv ! video/x-raw, format=YUY2 ! xvimagesink";
launch_string = launch_stream.str();
g_print("Using launch string: %s\n", launch_string.c_str());
GError *error = nullptr;
gst_pipeline = (GstPipeline*) gst_parse_launch(launch_string.c_str(), &error);
if (gst_pipeline == nullptr) {
g_print( "Failed to parse launch: %s\n", error->message);
return -1;
if(error) g_error_free(error);
appsrc_ = gst_bin_get_by_name(GST_BIN(gst_pipeline), "mysource");
gst_app_src_set_stream_type(GST_APP_SRC(appsrc_), GST_APP_STREAM_TYPE_STREAM);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_PLAYING);
// Set initial state
pongCtrlData ctrlData;
ctrlData.count = 0;
ctrlData.left_bar_ypos = GetPointer_Y(display, &root_window);
ctrlData.left_bar_yspeed = 0;
ctrlData.ball_xpos = 50 + bar_width;
ctrlData.ball_ypos = ctrlData.left_bar_ypos + bar_height/2;
ctrlData.ball_xspeed = initial_speed;
ctrlData.ball_yspeed = initial_speed/5;
while (1) {
double startTime = (double)cv::getTickCount();
// Get pointer Y pos
int ret = GetPointer_Y(display, &root_window);
if (ret >= 0) {
ctrlData.left_bar_yspeed = ret - ctrlData.left_bar_ypos;
ctrlData.left_bar_ypos = ret;
// Update state
ret = PoorPongController_onePlayer(ctrlData);
if (ret < 0)
break;
// Set display data
pongDisplayData *dispData = (pongDisplayData *)g_malloc(sizeof(pongDisplayData));
dispData->left_bar_ypos = ctrlData.left_bar_ypos;
dispData->ball_xpos = ctrlData.ball_xpos;
dispData->ball_ypos = ctrlData.ball_ypos;
dispData->digits_xpos = (int)(frame_width/2 - digit_width);
dispData->count10_idx = (ctrlData.count/10)%10; // supports only up to 99
dispData->count1_idx = ctrlData.count%10;
// Draw into NVMM frame
feed_function(dispData);
// Compute processing + drawing time, and sleep until next frame if we're early
double endTime = (double)cv::getTickCount();
double process_time_us = ((endTime - startTime)/cv::getTickFrequency())*1e6;
double sleep_us = (33333.3 - process_time_us)/1.01;
if (sleep_us >= 0)
usleep(sleep_us);
else
printf("Late...\n");
/* Game over... show last scene for 2 seconds before exit */
for (int i = 0; i < 60; i++)
// Draw frame
// Sleep until next frame if we're early
if (sleep_us >= 0)
usleep(sleep_us);
else
printf("Game Over - Count: %d\n", ctrlData.count);
// Wait for EOS message
gst_element_send_event ((GstElement*)gst_pipeline, gst_event_new_eos ());
GstBus *bus = gst_pipeline_get_bus(GST_PIPELINE(gst_pipeline));
gst_bus_poll(bus, GST_MESSAGE_EOS, GST_CLOCK_TIME_NONE);
gst_element_set_state((GstElement*)gst_pipeline, GST_STATE_NULL);
gst_object_unref(GST_OBJECT(gst_pipeline));
g_main_loop_unref(main_loop);
eglTerminate(egl_display);
g_print("going to exit \n");
return 0;
Makefile
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
APP:= poorpong_nvmm
CUDA_VER?=10.2
OPENCV_DIR=/usr/local
ifeq ($(CUDA_VER),)
$(error "CUDA_VER is not set")
endif
CXX:= g++
SRCS:= poorpong_nvmm.cpp
CFLAGS:= -Wall -std=c++11 -ggdb\
-I/usr/src/jetson_multimedia_api/include \
-I/usr/local/cuda-$(CUDA_VER)/include \
-I$(OPENCV_DIR)/include/opencv4
LIBS:= -Wall -std=c++11 \
-L/usr/lib/aarch64-linux-gnu/tegra/ -lEGL -lGLESv2 \
-L/usr/lib/aarch64-linux-gnu/tegra/ -lcuda -lnvbuf_utils \
-L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
-L$(OPENCV_DIR)/lib -lopencv_core -lopencv_imgproc -lopencv_highgui -lX11
OBJS:= $(SRCS:.cpp=.o)
PKGS:= gstreamer-app-1.0
CFLAGS+= `pkg-config --cflags $(PKGS))`
LIBS+= `pkg-config --libs $(PKGS)`
all: $(APP)
%.o: %.cpp
@echo "Compiling: $<"
$(CXX) $(CFLAGS) -c $< -o $@
$(APP): $(OBJS)
@echo "Linking: $@"
$(CXX) -o $@ $(OBJS) $(CFLAGS) $(LIBS)
clean:
rm -rf $(OBJS) $(APP)
