We do have the prebuilt PyTorch package for the Jetson user.
You can find the package here or a container here.
| I run into this error while installing pytorch : libmpi_cxx.so.20: cannot open shared object file: No such file or directory | 8 | 1990 | December 5, 2023 | |
| Cannot install pytorch Jetson xavier nx | 4 | 909 | June 4, 2023 | |
| Jetson agx orin torch 1.11.0 install | 5 | 919 | November 6, 2023 | |
| Libopenmpi-dev: Depends:libiverbs-dev- Broken packages error while installing Pytorch v2.1.0 | 7 | 101 | December 16, 2025 | |
| Installing Pytorch in Orin (libmpi.so.20 issue) | 6 | 2030 | January 18, 2023 | |
| What is the way to install Libtorch on my jetson xavier? | 2 | 341 | May 29, 2025 | |
| Not able to install torchvision v0.6.0 on Jetson jetson xavier nx | 2 | 2215 | April 13, 2021 | |
| Cannot install pytorch | 4 | 13956 | October 18, 2021 | |
| Import of pytorch does not work | 4 | 1131 | April 25, 2022 | |
| OSError: libmpi_cxx.so.40: cannot open shared object file: No such file or directory | 7 | 6557 | December 13, 2023 |
