When I installed torch according to the instructions, I encountered some problems. The following is the relevant version information of Xavier I currently use:
nvidia@Xavier:~$ nvcc --version
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_21:14:42_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
The version of torch I installed is pytorch v1.7.0.
When I check the torch installation, python reports the following error:
>>> import torch
File "<stdin>", line 1, in <module>
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/__init__.py", line 189, in <module>
_load_global_deps()
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/__init__.py", line 142, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcurand.so.10: cannot open shared object file: No such file or directory
Libcurand.so.10 does not seem to be installed in my Xavier. I found that the previous discussion on the forum did not involve jetpack4.5.1, so I would like to know whether I also encountered the problem of version adaptation. Looking forward to an answer.
Hi @vesvenh, you should still have a libcurand.so.10 symbolic link on your system:
ls -ll /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcurand*
lrwxrwxrwx 1 root root 15 Oct 29 2019 /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcurand.so -> libcurand.so.10
lrwxrwxrwx 1 root root 22 Oct 29 2019 /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcurand.so.10 -> libcurand.so.10.1.2.89
-rw-r--r-- 1 root root 62596184 Oct 29 2019 /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcurand.so.10.1.2.89
-rw-r--r-- 1 root root 62751508 Oct 29 2019 /usr/local/cuda-10.2/targets/aarch64-linux/lib/libcurand_static.a
