ImportError: libc10.so: cannot open shared object file: No such file or directory
What am I supposed to do?
Thank you.
Thank you.
Which PyTorch package do you install?
It’s recommended to use the package from the below topic:
With that package, we can locate the libc10.so file correctly.
$ sudo find / -iname libc10.so
find: ‘/run/user/1000/gvfs’: Permission denied
/home/nvidia/.local/lib/python3.6/site-packages/torch/lib/libc10.so
I’m using nx emmc module,
I have installed jetpack component using below command.
command : apt depends nvidia-jetpack | awk ‘{print $2}’ | xargs -I {} sudo apt install -y {}
I have installed PyTorch v1.7.0
Thank you.
Could you check if the library is installed in your environment first?
